Question about Garden
I would like to know if the transmission has to be tore apart on a 6400 jd tractor to replace the transmission front drive shaft seal
  • Garden Master
  • 2,478 Answers
No, remove driveline, replace seal.
Posted on Feb 19, 2012
Farmall tractor
split the tractor or course to get to that seal
Jul 01, 2016 | Cars & Trucks
Need Drive Shaft for JD 317 with 17hp Kohler engine, 1981 year bought
The I had I just replaced the U Joints in it. But yours might have been let go to long and tore up the ends . You can buy them new on ebay link attached. Has some good picture JOHN DEERE OEM UNIVERSAL DRIVE SHAFT AM37875 317
Mar 17, 2016 | Garden
Jd 8530 transmission vibration
Worn bearings or shaft joints would cause this, I would look at the drive joints first, transmissions in most cases don't vibrate.
Dec 30, 2011 | RC John Deere 8530 Tractor
1997 geo metro torque converter seal replacement how to remove seal and make sure we are removing only the seal.the car is a 1.3 l at.
This seal is located in the front of the transmission. Its called a front input shaft seal. You will need to drop the transmission and remove the torque converter. Once the converter is off if you look at the shaft protruding from the transmission just at the base of the input shaft you will see this seal.
you can rent a seal remover from you parts store, IE Autozone or Oriely's and rent the seal installer tool. This will insure that you do not damage the seal housing or the seal when installing the new one.
One word of advice would be to take the torque converter to a transmission shop and have it checked before reinstalling it. If it has a worn seal face or has a bad set of blades you would be money ahead to replace it while your doing it the first time and not have to pull it back apart 3 months later.
Jul 30, 2010 | 1997 Geo Metro
Replaceing the front seal in transmission
You will have to remove the transmission.that would include removing drive shaft ,possibly exhaust.
Apr 07, 2010 | 1992 Mercury Grand Marquis
Transmission leaking through drive shaft
the rear seal on the tail shaft must have gotten damaged when you removed the shaft. it is available at any good parts store, easy to change. you have to pull the drive shaft back out, then you can use a small hook / prybar to pull the seal out, then tap the new one into place. pay close attention to the install height of the old seal before you remove it, so you know how far to drive the new seal in. good luck!
Mar 27, 2010 | 1996 GMC Sierra
1962 JD 4010. TRANS SHAFTS TURNING, WON'T MOVE. SUSPECT REAREND PROBLEMS. ANY IDEAS?
Try removing the the transmission shaft and you will likely find that the splines are missing from either the input or output shafts.
Dec 20, 2009 | John Deere 4020 Gas & Diesel Tractor...
JD 6400 tractor, PTO light flashes when engaged but PTO does not work.
The most likely problem is the pto solenoid valve on the rear of the tractor.It could be the speed sensor but you won't know until you get the codes read by the dealer.I have had to replace the b.c.u. for this problem but it is not common.
Aug 30, 2009 | John Deere 6300,6300l,6400,6400l Tractor...
2000 DODGE CARAVAN TRANSMISSION LEAK
A good mechanic should replace the seal with in 2-3 hours, mainly tearing apart your drive wheel on that side along with the drive shaft. This is a good time to replace the drive shaft if any of your CV joints are leaking.
Good Luck!! PHX
Oct 30, 2008 | 2000 Dodge Caravan
Garden Logo
48 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
