Question about Bulova Watches
Caprice quartz ladies watch battery - Bulova Watches
diddydaveh
  • 154 Answers
SOURCE: Timex indiglo. Indiglo feature died.
The indiglo technology is time limited (it dims over the years with use) and cannot be repaired - have you had the watch a long time? if so, I'm afraid it's time to get a new one. Sorry!
Posted on Jan 02, 2009
slp11508
  • 43 Answers
SOURCE: can't get my croton watch to work.
There are a few possible reasons why your watch is not working:
  1. The battery is dead (sometimes even new watches have a dead battery in them).
  2. The plastic piece between the crown and the watch case was not removed (this protects the battery from wearing down until you receive the watch).
  3. You bought a watch with a damaged movement and it just will not work period so you may have to return it, exchange it, or have it repaired
These are the 3 reasons why your watch could not be working. The reason will fall into one of these 3 categories, so I hope this helps!
Posted on Jan 05, 2009
  • 183 Answers
SOURCE: Fake or not
Generally you have to open the watch to see the movement but a lot of fakes are plain workmanship flaws.
A real Cartier will not be made from base metal. It will be made from stainless steel or precious metal.
A real Cartier will most likely be built with screws in the band instead of cotter pins.
When you pull the crown to set there will be no play in the set lever. In other words when you spin it, it will begin to turn the hand immediately and there will be a slight resistance. It will not feel loose.
As stated, the best way to tell is to look at the movement. Cartier uses a high grade Swiss movement most likely marked ETA.
Posted on Sep 17, 2009
mcdevito75
  • 1970 Answers
SOURCE: which battery does a ladies citizen quartz watch #
mcdevito75 here Possibly a 377 or 364 Battery, see a small watch repair shop in your area for help, or Citizen online at Citizen.com
Posted on Jun 25, 2010
SOURCE: I recently bought a Ladies
Check the battery. These are cheap watches the Eurodam is allowing to be peddled to its passengers as if they are valuable. A scam.
Posted on Nov 20, 2010
My omega deville ladies prestige quartz is losing time. There is no second hand on the watch and the minute hand seems to tick every 10 secs or so. It has just had a new battery replaced by omega...
Yes. The minute hand ticking every 10 seconds is normal. Losing time is either battery or a movement malfunction. Only a trained watchmaker (or presumably Omega) can determine which. Take it back to Omega
Oct 10, 2012 | Omega De Ville Prestige Quartz Small...
I have a geneve quartz 14k gold mans watch dont no how to take apart to put battery in.
mcdevito75 here, Battery usually lasts 1 year and longer, even if you did change the battery yourself now, you"d forget for a year or even longer next time battery needeed to be changed, I know I did. Add to this you can easily destroy your watch with in-correct handleing. BEST BET, look for a small watch repair shop in your area for this battery change $10--$15.00 and peace of mind.
Oct 26, 2010 | Geneve 14K Gold Ladies Diamond Panther...
My dkny ladies watch stops when I take it off. After resetting and putting back on, it works again. Why does it do this?
mcdevito75 here, It"s possible the battery could be so ever slightly loose, or the battery could be weak and need changeing. Also possible, the quartz mechanism could be going bad and movement of the watch while wearing it keeps it going, with the watch off your wrist and at rest, it's just to weak to keep moving on it"s own. Best Bet is to look for a small watch repair shop in your area and have them check out your watch.
Aug 22, 2010 | DKNY Modern Edge Lady Watch # NY3901
Which battery does a ladies citizen quartz watch # GN-0-S 10 use?
Jun 25, 2010 | Citizen Bracelet Quartz Watch
Ladies rolex quartz geneve 59312
There is no such thing as Rolex Quartz 59312. Ether you got yo numbers wrong or it is a fake watch.
Rolex made quartz watches only in men's size.
W-Precision
Mar 16, 2010 | Rolex Daytona 116520 Wrist Watch
I have an old ladies dress Chopard watch - oval shaped gold with diamonds on the band. I inherited the watch from an estate. I wore the watch from a month and then it just stopped. Should I take it to a...
You need to first know if it is a Quartz watch or an older Wind Up type. I am guessing, since you have been wearing it and do not mention winding it, that itt is probably a Quartz movement in the watch. However, to be clear, If it is older than about 1970 then it is definitely Not Quartz. Then might be what is called an Automatic movement, which is actually a Self Winding Movement mechanism. If newer than 70, could be either Quartz or WindUp. If it is Quartz then the problem is most probably that the watch needs a New Battery. This can be done at a local jewelry shop for around $8 to $15. If it is a Wind Up style then it would need a more complex repair. But sending it to Chopard is still the Last Resort as Chopard could charge you $400 to repair it, I am not kidding, haha. But take heart, most probably you have simply got a Dead Battery and your friendly local watchmaker or jewelry store can fix it for you fast and cheap. Good Luck, W.
Mar 16, 2010 | Watches
Can't get my croton watch to work.
Jan 05, 2009 | Croton Watches
Watches Logo
123 people viewed this question
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
