Question about U-Line Refrigerator Ice Maker
U-line ice maker wiring diagram
I am unable to read faded wiring diagram on a u-line model 45A ice maker.I am trying to replace the front control module. would appreciate a diagram.
4 Suggested Answers
  • 286 Answers
SOURCE: I have an old U-line ice maker. I can not find
The mechanical parts of those models is the same as a BI 95 or BI98. If your looking for the faceplate that would be part number 150. This includes the timer motor,gears,water switch, and hold switch. You can order this thru a parts distributor. Appliance Parts Depot or All Brand Parts should be able to help. If you want to replace the complete icemaker assemly that part number is 402
Posted on Jul 07, 2009
  • 286 Answers
SOURCE: Our old RV U-Line Icemaker, model 45A has stopped
You need to check to see if the compressor is running and the fan is running. If both are then you need a new unit. The 45A has the r12 refrigerant in it and you wont be able to get parts for a r12 system. U-line makes a BI95 to replace that model. If the fan isnt running then I would replace the fan. If nothing is running then it could be a bad thermostat but first make sure the ejector blade on the icemaker is at the 12 oclock position.
Posted on Jul 20, 2009
  • 93 Answers
SOURCE: replacement ice bucket for the U-Line Ice Maker
U-Line 800-779-2547
Posted on Mar 03, 2010
Tip
The ice maker is not working, but ice water dispenser operates
Try defrosting the fridge completely, this will tell you ifd the icemaker lines are frozen.
The ice maker is actuated by a solenoid.
To check if the lines are frozen , defrost the unit.
Check the water valve connected to the hose at the back of the unit.
The ice maker solenoid is tested by reading the ohms on solenoid with a multimeter.
Other faults can concern the impeller pump that is sending water to ice maker, that is tested by energizing the pump.
to disassemble the icemaker click the diagram below:
Click on picture above to open diagram.
Here more diagrams:
CABINET PARTS
CONTROL
More diagrams for your model.
on Dec 03, 2009 | KitchenAid KSRG25FKSS Side by Side...
U line B195 compressor and fan are not coming on. I have 120 volts to all components that are accessable at the front. With water on , ice maker contuinues to cycle and dump water all the time unless you...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If this doesn't work Do this
That is probably the compressor relay
The relay is on the compressor and needs replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Aug 16, 2011 | U-Line Icemaker
Our old RV U-Line Icemaker, model 45A has stopped making ice and does not get cold. What does it need?
Jul 17, 2009 | U-Line Icemaker
Jul 04, 2009 | U-Line Icemaker
Water dispenser leaks, ice maker won't make ice. Hve disconnected line at bottom front, and tried blowing out the lines, no help. Model EDQ22DQFNX00
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
For the ice maker problem, Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.If it does, the problem is the ice maker and not the valve and line.
Jul 02, 2009 | Whirlpool ED2FHEXN Side by Side...
Wiring came unplugged need wiring scematic for uline ice maker
wiring diagram is on the back of the machine. If you have clear ice maker it may be on the back of the front plate.
Jun 01, 2009 | U-Line Uline Origins Series...
Kenmore ice maker filled with ice, but not dumping. light blinking next to ice maker switch
sounds like your ice maker heater may not be working, as there is no way to repair the heating element but to replace it with a new ice maker, you can probably jump the ice maker by removing the front cover of it
here is a link with more instructions good luck
http://www.davesrepair.com/DIYhelp/DIYicemakertips.htm
May 27, 2009 | Whirlpool GD2SHGX Refrigerator
U-Line BI-45A won't run
check the wiring diagram at the back panel. trace each component.
you could have disconnected one or two wires while replacing the fan, check the thermostat control. see if there is continuity. check the wirings also that went there.
tnx 4 using fixya,
drcool
Oct 19, 2008 | U-Line Icemaker
U-Line Refrigerator Ice Maker Logo
189 people viewed this question
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
billconfused
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
