Heatsinkfan on the bottom they like 100 prikels that plug in to the unit if 1 or 2 of the prikel break off will my computer not work ? than you help
  • 34 Answers
Yes it will
Posted on Oct 27, 2008
Where is my back up battery in my acer T671
You'll need to disassemble the laptop to see the motherboard. Is your main battery charged? May have a blown diode on the power input.
Sep 03, 2014 | Acer hi.3670c.001 - Aspire T671...
Compaq 1420 nx turns on then turns off immediately
A brief primer if I may;
Electrolytic Capacitors are used on the motherboard, and in the Power Supply, in the Compaq Presario 1420nx Desktop PC;
HP Support > Compaq Presario SR1420nx Desktop PC > Main Support page,
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&dlc=en&lc=en&product=457247&
Product information > Product specifications > Motherboard Specifications, P4GV-LA (Guppy),
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00363478&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=457247
Scroll down to the motherboard Photo.
http://capacitorlab.com/visible-failures/index.htm
General example of a Switched-Mode Power Supply, (SMPS), case open,
http://en.wikipedia.org/wiki/File:ATX_power_supply_interior-1000px_transparent.png
Personal computers have used this style of Power Supply, for quite some time.
The one in your computer is just an ATX style, and is the type used in MANY personal computers. (Not Small Form Factor, however)
THIS IS NOT an invite to open your Power Supply, and attempt repair.
The capacitors used are Radial Aluminum Electrolytic Capacitors.
The blue ones marked by the letter B, are high voltage. MAY have Up To 100 Volts stored.
Your fingers touch the terminals on the bottom, of one of these babies; the shock can be BAD to FATAL!
Your fingers touch a circuit, that one or more capacitors are in, and the shock can be BAD to FATAL.
There is a Proper method to discharge them, BEFORE working on the unit. Am not going to post.
(Does NOT involve a metal screwdriver, or other metallic object! Good way to have hot molten metal spray in your face!)
The method of repair is to REPLACE.
Inside an Electrolytic Capacitor is Electrolytic Paste.
This paste breaks down over time. Chemical composition breaks down.
Computer engineers know this, and use capacitors that are rated at twice, or 200 percent; of what is needed.
This way when the capacitor breaks down to 50 percent good, it is still 100 percent good for the application it is used in.
Unplug an electronic unit from power, and the chemical composition of the paste breaks down more rapidly. All electronic units need a trickle charge when being stored. (Pawn shops know this)
To summarize;
FOLLOW Anti-Static Precautions after unplugging your computer from power, BEFORE reaching inside your computer. (Don't know, and would like to? Post in a Comment)
Check the 'caps' on the motherboard.
Note* Sometimes the Electrolytic Paste dries up, and shows NO outward visual signs of failure.
'Caps' on motherboard found to be good, suspect the Power Supply.
I can guide you in testing it, or you may have a KNOWN to be good, Compatible power supply, from a working computer that you can borrow for a test unit.
Regards,
joecoolvette
Dec 04, 2012 | HP Compaq Presario SR1420nx...
Window installer error
Problem caused by using anything made by Microsoft. Go to Linix.
Jun 12, 2012 | Dell Inspiron 531 531s CPU HeatsinkFan...
How to fix my toshiba loptop blank screen
Here are the fix steps:
1. Turn off your computer
2. Disconnect every wire from it (including power)
3. Disconnect the battery from the bottom of the computer. There will be two tabs labeled 1 and 2.
4. Re-plug in the power wire. (the battery should not be in the computer)
5. Turn on the power. The screen will work. Choose start windows normally. (if you get that screen)
6. Go to Control Panel -> (Mobile PC) -> Power Options -> Under Balanced choose change plan settings
7. Choose Change advanced power settings
8. Find Processor power management and change the minimum processor state from 5% to 100% for each On battery and Plugged in.
9. Click Apply then OK
10. Shut down you computer.
11. Disconnect the power cord.
12. Re-install the battery on the bottom of the laptop, plug in the power cord, and restart the computer.
You should be good to go.
Oct 12, 2011 | Toshiba Satellite A135-S2276 Notebook
Powers on but will not boot up
Try the following otherwise a comprehnsive troubleshooting might have to be done as there are several reasons system might not boot:
Sep 13, 2011 | Toshiba Computers & Internet
How to change the given decimal to fractions
Hi, Divide the top into the bottom number and you should get a decimal. 1/4 is .25 1/2 is .50 .....
To change the decimal in to to a fraction. Put the decimal over 100 and multiply.and then break that down.
Jun 28, 2011 | Computers & Internet
LOOKING FOR THE FELTS AT THE BOTTOM OF THE PRINT HEAD CARRIAGE.(1 IS MISSING) PRINT HEADKEEPS DRYING OUT. I'VE LOOKED EVERYWHERE ON LINE. ALL THE PARTS PLACES DON'T SEEM TO KNOW WHAT I'M TALKING ABOUT....
hello, yes i do know what your talking about, sometimes paper will get blocked into this capping/purge/cleaning station, out of all the ones i have here, the one side for the cyan/magenta #88 printhead, there is no pad there. is it the cyan/magenta printhead thats drying up, or is it the yellow/black printhead. i would check to make sure that this unit is working 100%. i do know that this machine has issues with the electronics for the printheads, as well as the printheads seem to only last a few months after warranty, though, i have seen some last 1 year after warranty, but i would check to make sure there is nothing in the way of the capping unit, paper will get caught in there and some gears will break. i hope this helps
Oct 08, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
What does it mean when a d 4 light is on
This problem can be solved by replacing an AT Control Unit, which is located underneath the passenger side floorboard. There are two computers underneath the floorboard. It is the one on the right, the smaller unit. The numbers must match exactly. The numbers vary according to whether the car is an LX, DX or EX. Simply disconnect the battery, take out the two plugs that plug into the bottom of the computer, and replace the unit. The problem should be solved. The Control Unit can be purchased from a salvage yard for $50-100. We think that the numbers match on 90-93 and are therefore interchangeable
Jul 11, 2010 | 1994 Honda Accord
Leaking and then it stoped working
You may want to buy one with a 6 or 10 year warranty. If you have a ISE Pro install it you will get another 2 years warranty on the 6 yr model. That is 8 year of in-home, 100% parts and labor warranty.
Jun 04, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Takes forever to pressure up
Double check that the drain valve is fully closed on the bottom of the tank. Once it reached 100 PSI, did it stay pressurized or did the pressure drop? Did you run the initial break-in procedure described in the manual? Do you hear any air leaks?
Oct 26, 2008 | Makita MAC2400 13 Amp 2 1/2 Horsepower 4...
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
