Question about Kitchen Ranges
How to remove oven door from Southbend commercial range
Bought a used Southbend commercial range and we need to remove the door to get it into the house.
  • 1314 Answers
SOURCE: Clean Oven Door Glass
To remove oven door:
1. The oven door is held to the oven door hinges by two
screws. (One in each hinge.)
2. To remove the oven door remove the two screws.
Two screws
3. Close the door to the broil stop position and lift up.
then remove the door handle and take out all the screws around the edges of the door and pull the out side cover from the inner but a word of caution there are about three or 4 pieces of glass they are tempered and about 100 bucks a piece and most times they wont get real clean and will get messy again
Posted on May 24, 2008
  • 125 Answers
SOURCE: How do I remove the oven door on a Garland Range
Hi, is this unit a convection unit? usually you don't need to remove the door to replace the thermocouple, if it is convection unit, you will need to shut the gas off, remove the safety, and there are two metal plates covering the burner area, take those out, the next thing is to remove is the burner, it is usually just fitted in the back, once this is out, as the pilot is attached to it, you can replace the t'couple now, assemble reverse.
If you really need to remove the door, and you are really lucky, remember to undo the spring hooks holding the door so it does not snap the door closed during disassembly, usually you can just pry up on the triangle near the hook, releasing tension to unhook the door hooks, leaving the springs attached. You can just take the screws out that hold the top of the door, the bottom of the door, and I think the handle, then the door skins split, and on each side at the hinge, there is a set of bolts holding the hinge in place, remove these, and you should be able to remove the door, otherwise you need to take the bottom kick plate off, along each edge inside the door frame, are screws holding the outer channels in place, remove these, and down along the inside of the kick plate edge too. Easily pry these away from the oven body, older units had a solid piece from front to back, and you had to remove the entire side panels, or were spot welded altogether, all you can do then is pry them back best as possible, and hopefully they won't crease. Inside these channels are the hinge plates that the hinge goes into, unbolt them, slide the door out, and there you have a door in you hand. Garland has a kit to replace all of these parts as you go, if they are badly worn. I know, allot for a thermocouple. Hope that helps, and thank you.
Posted on Jan 04, 2009
  • 338 Answers
SOURCE: I get an "F1" code on my Maytag range.
you need a new temperature probe. its usually located in the upper left hand corner in the rear of the oven.
Posted on Mar 19, 2009
Kgt1962
  • 59 Answers
SOURCE: viking igniters door removal?
Remove the access panel below the door, there is a screw at either side below the door, the panel will pull forwards at the top giving you access to the wires
Posted on Mar 20, 2009
  • 193 Answers
SOURCE: southbend model : x436d need to connect to lpg
off the bottle you will need a regulator and at the back of the stove you will need a yellow gas tap as an isolator remember bottle pressure can reach as high as 1200kpa on a hot day and you only need 2.75kpa for the range and your line size is 1/2'' and use gas tape on all fittings and leak test with soapy water
Posted on Apr 26, 2010
The timer works sometimes and then other times it won't...any ideas?
Hello. Your issue might be a defective timer. REMOVE POWER FIRST!! Definitely check for loose(or burned) wiring connections. Over time, the contacts can oxidize and/or heat can loosen the spade lug connectors that attach the wires to the control. The exploded parts diagrams and parts lists can be found here: http://www.partstown.com/is-bin/INTERSHOP.enfinity/WFS/Reedy-PartsTown-Site/en_US/-/USD/ViewExplodedDiagram-Show?CategoryID=iCrUwxtSbaquiXjVOSUqRhaJMk
Parts Town Southbend Range SLES 20SC Electric Convection Ovens Parts Manual . I hope this helps you!
Sep 16, 2015 | Star Southbend "silver Double Convection...
From a cold start I do not get a spark to ignite the oven is it the igniter or thermostat
If you turn it all the way up it doesn't spark? Or push down on the knob? You should be able to hear it. If the timer on the front panel isn't on, the circuit breaker may be blown. It doesn't have a very good reputation. http://www.foodservicewarehouse.com/southbend/sles20sc/p2537.aspx
Jan 28, 2015 | Star Southbend "silver Double Convection...
Can you convert a 480 volt to 220 on a es/20sc double convection oven
You need a transformer to do that. I assume that you are in the USA and you have a 480V three phase service. With 480V three phase there is 277 volts between any two of the phases. There are transformers to drop 277V down to 220V.
A better solution is to ask your power company for 220V service. The power company owns the transformer and you only have to provide the in house wiring. .If you have a commercial establishment you have to meet all local codes and be inspected. If you don't the liability is very great.
Use a licensed electrician.
Oct 23, 2014 | Southbend Es-20sc Double Deck Convection...
How do I unlock the oven door on kitchenaid classical commercial style dual fuel convection range?
disconnect the range form the power source, you should hear a pomp and the door should open
Sep 02, 2014 | KitchenAid Kitchen Ranges
Southbend 460DD-2TR no pilot after replacing safety valve/thermo couple
Sounds like if you are not getting any kind of flame your pilot assembly will have to be taken out and cleaned. Your pilot orifice is clogged up with build up. Will need a screwdriver, 7/16 wrech and or a 1/2''.
Jun 30, 2012 | Southbend 460DD-2TR Gas Kitchen Range
I need to calibrate my southbend model #x436d standard gas oven
If you pull the knob off there is a very little screw in there that you can turn with a small screwdriver. I believe left is increase and right is decrease, but I could be wrong. Very little turns do a lot. You can tell if you are going the right way if the burners get bigger or not. This takes a while so do a 1/4 turn and let it sit for a while, take temp and adjust again if needed.
Jun 16, 2012 | Southbend Kitchen Ranges
We have a southbend gas range and the Pilot is not working . What needs to be done ? Is there any service center in Pittsburgh ?
Hi. Here is the nearest service center for your Southbend range.
PENNSYLVANIA
PITTSBURGH, STATE COLLEGE, ALTOONA (WESTERN AREA)
AIS Commercial Parts & Service of Pittsburgh
740 Vista Park Drive
Pittsburgh, PA 15205-1214
412-809-0244
800-726-6020
FAX 412-809-0246
Jun 24, 2010 | Kitchen Ranges
Southbend model : x436d need to connect to lpg bullet does not have a regulator on the range do i need 1 before connecting
Apr 25, 2010 | Southbend 436D-2GR Gas Kitchen Range
Do we need an exhaust flue for a southbend half size gas oven?
Depending on your local code, you will need an exhaust hood due to the byproducts of the gas burning. Some locals allow for electric ovens to go without hood. Gas units generally require a hood system with proper fire suppression equipment. You may want to check with your local fire and building inspectors.
Mar 22, 2009 | Southbend S560DD (Gas) Oven
Want a manual for my oven
google your model # youl see lots of links
Dec 31, 2008 | Southbend 436D-2GR Gas Kitchen Range
Kitchen Ranges Logo
323 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
