Question about Cuisinart DLC-5 Food Processor
How to download the cuisinart dlc-7 super pro instruction manual?
ThaMp3Doctor
  • 8596 Answers
SOURCE: need manual for food processor
The manual is available for free at Cuisinart's website
www.cuisinart.com
-Tha Mp3 Doctor
Posted on Jan 17, 2009
  • 122 Answers
SOURCE: Need instruction manual for Cuisinart DLC-7 food
pl. see www.manualnguide.com/brand/cuisinart/
Posted on Apr 16, 2009
SOURCE: replace the spindle on Cuisinart DLC-7 Food Processor
Did you contact Cuisinart? I just sent my DLC-7 to Cuisinart for repair. The start switch does not latch and works as a pulse switch.
Posted on Jan 07, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: How to put new shaft on cuisinart food processor model DLC-7E
Initial disclaimer: I am not recommending this course of action - my recommendation is to buy a new food processor. These units weren't designed for DIY repair, so this is going to be a difficult task. The final product probably isn't even going to be pretty. You are well out-of-warranty, or I wouldn't even consider posting this. First, make sure you have a DLC-7E shaft - the only way to get one at this point would be to buy a DLC-7E base from eBay or an after-market seller, as all of these were manufactured well over 20 years ago. I don't currently see any eBay listings for one, but they do crop up from time-to-time. Make sure the DLC-7E you are repairing and the old one from which you are wrenching the old shaft are unplugged and have been unplugged for an hour or longer just to be on the safe side. Unscrew the four screws on the bottom of the base on both units. If the bottom base does not come off after this, carefully pry out the four feet and unscrew any hidden screws that might be hidden underneath the feet (Careful - original feet cannot be ordered by normal means, and damage will only add to your total repair cost). Take note of the guts on the inside of both food processor bases - if you have to unscrew the motor body (4 screws that sit just underneath the top of the base), take note of everything that you are taking out so that you can put it back in its proper place when done. Wear leather gloves for safety. Please be aware that even an unplugged unit still has the potential to send several volts of electricity through your body - this is a potentially hazardous task. Once the motor body has been unscrewed and removed slightly (don't disconnect any wires or cables - just get the motor body out of your way), you will notice the old shaft that you intend on replacing. Look for any damage to the gears/bearing that surround this shaft. Try dabbing a small amount of USP-grade mineral oil on any bearings - clear away any dust or debris that may be obstructing the shaft from turning. Don't overapply the oil, or the wetness will seep into other electronic components in the motor and cause them to fail. Put your food processor back together, turn it on, and press the button/buttons on top of the base of the food processor with a pen with the food processor plugged in. If the shaft still won't turn, you definitely need to replace the old shaft (you can disregard some of these previous steps if your problem is that the spindle on the old shaft is worn).
Remove the screws and disassemble the processor base as described above. Since there is a layer of paint/coating surrounding the old motor shaft, removing the old shaft may cause paint flecking. Take the shaft from the one food processor base and insert it in the food processor you are trying to repair. Strip away any excess paint/coating from the new shaft. Make sure no paint flakes remain in the body of the food processor, or they will later cause more serious problems that will permanently damage your food processor - potential fire hazard as well. You will probably notice that the new shaft does not look as pretty as your original shaft, since the paint/coating will almost invariably get damaged in this process. Reassemble the base of the food processor, making sure no wires, etc. were knocked out of place in the process. This paint flecking will add to the cost of the repair - you may need to buy appliance body paint that dries to almost a rubbery consistency to make the final project look nice. All of the materials listed above could cost you $40 or more.
Like I said, I don't reccomend this course of action, but there's your answer.
Posted on Mar 17, 2009
  • 17 Answers
SOURCE: no manual or instructions for pro classic
Go to the following website. You will find a downloadable copy of your manual there, for free:
http://safemanuals.com/user-guide-instructions-owner-manual/CUISINART/DLC-10C-_E
Posted on Jul 09, 2009
Is the Cuisinart DLC 7 Super Pro Manual available to download?
Manuals can be found here:
Food Processors Product Manuals Cuisinart com
You'll have to look around at the options and pick one that looks like the one you have.
If you have an older one, the handle for the bowl generally goes in front, and check the base to see if the button that gets pushed down when the top is in locked position is in the front or the back... and try to match that. The DLC-10s has it in the front (7 cup machine), but many of the larger machines have it in the back. The feed tube matches up with the button when you put the lid on. If you put the lid on with the feed tube 180 degrees off, you can break the lid/bowl getting them apart again.
Getting this right is the most important thing... otherwise they just kind of work. The link for the 7-cup Pro Classic Food Processor (DLC-10s) has really good technique information with color photos. It's worth grabbing regardless of the machine you have.
http://www.cuisinart.com/share/pdf/manuals/dlc-10s.pdf
Other manuals have other recipes... so you might want to download more than one manual.
Jul 03, 2014 | Cuisinart DLC-5 Food Processor
Is an instruction manual for Cuisinart DLC-7 Super Pro Food Processor available to download?
You can go to: Food Processors Product Manuals Cuisinart com
Find one that is at least close, if they don't have your exact one. The manuals for each shape-size are pretty much the same... so find the one with the closest picture and size.
The chrome (DFP-7BC) is probably very close... (I'm guessing yours is the same only in white??)
Jul 03, 2014 | Cuisinart Food Processors
Motor base cover for dlc 7 super pro
Try buying a new motor base on eBay. It's actually quite cheap. If you are daunted by the shipping cost of this monster, you can always ask the seller to sell you just the brown bottom cover. Under each foot is a screw which attaches the molded base it to the rest of the assembly. It's a lot cheaper to just have that part sent to you. This works as long as you are handy in making the switch of the base.
May 27, 2014 | Cuisinart DLC-7SFP Pro Food Processor
Need instructions for cuisenart 7 cup processor
To to:
and look for a machine that is from the same generation as yours (check the shape of the base).
For your 7-cup machine, a good manual might be the following:
Pro Classic Food Processor (DLC-10S)
Manual
Apr 26, 2014 | Cuisinart Food Processors
Need the instruction manual for a cuisinart dlc-8 plus.
http://www.cuisinart.com/share/pdf/manuals/dlc-8s.pdf
Cuisinart.com also has the How-To video and a product demo if either of those things help. Just go to the home page and search under Entire Site for DLC-8S.
May 28, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Need manual for food processor
Found it at:
http://safemanuals.com/user-guide-instructions-owner-manual/CUISINART/DLC-10S-_E
Apr 08, 2008 | Cuisinart DLC-10S Pro Classic Food...
Cuisinart DLC-5 Food Processor Logo
1,720 people viewed this question
Top Cuisinart Food Processors Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
