Question about Hitachi HDS721010CLA332 Deskstar 7K1000C SATA2 3GbS 1TB 7200rpm 32MB 0F10383 High Quality SATA II Hard Drive
HITACHI HDS721010CLA332 is there anyway i can do a clean ntfs format on said drive? it keeps tellintg me the format failed wheres formatting into fat32 works fine.
  • 10 Answers
SOURCE: Can't format HDD
Hey, please try to diconnect and reconnect the CD/DVD drive and check if this works.. Some times installation is incomplete if the file skip during installation.....
Posted on Feb 18, 2009
  • 81 Answers
SOURCE: I got a Hitachi PortableDrive,500GB. How does the
this is really simple NEVER TRUST BACKUP SOFTWARE for one
you will not be able to back the HDD image that only occurs when the OS is installed trusting your HDDs proprietary software for backing up your data will only save a bunch of **** you'll never need or use , when backing up data like your whole computer there are only 4 locations that need to be backed Your Documents (videos , movies , photos , music , Etc.) your program executables your internet favorites and any game profiles , everything else is on your operating system and can not be saved since those files run through the OS registry saving them wont
save the registry loaded items so saving is redundant . stick
with saving the 4 items I suggested to an external HDD . as your
data grows daily save new data to your ext. HDD , it will take
a few minutes and you will have backed your all that needs to
be saved data . if you have any questions about backing data email at
terminalconnection@gmail.comand I will be more
than happy to assist you .
David
Posted on Jan 28, 2010
davidmamian
  • 543 Answers
SOURCE: I have and hitachi HDS721010CLA332,
if not need you second operating system, format your second Hdd, if it IDE, see that in behind hdd it will be switched,,slave,,.
Posted on Jun 01, 2011
bronk50
  • 27725 Answers
SOURCE: I am trying to format
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem
follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
hope this helps
Posted on Jun 25, 2011
  • 224 Answers
SOURCE: My hitachi external hard drive
Sounds like you will need a data recovery. This guy does it remotely and only asks for donations.
http://FreeDataRecovery.us
Posted on Jun 29, 2011
Reformatting HCS725032VLA380
Is it your primary hard drive ?
Reformat hard drive to NTFS Windows XP allows you to easily format the hard drives with its inbuilt utility. Formatting the hard drive would forever delete all the files stored on it. There are two ways in which you can format the hard disk partition - from My Computer and from DOS. You cannot have a NTFS partition with allocation unit s above 4096.
Click on "Start," and then click on "My Computer." Right-click on the disk partition to format and then click on "Format." Click on the "File System" drop down box and select "NTFS." Click on the "Allocation unit " drop down box and select an allocation . It is recommended that you select the "Default allocation " option. Click on the "Start" button. b> Format the Partition from DOS b> Click on "Start," and then click on "Run." Type "cmd" in the 'Run' dialog box and then press "Enter." Type "format drive_letter: /FS:NTFS" at the command prompt and then press "Enter." Replace the 'drive_letter' here with the letter of the drive that you want to format (for example, format e: /FS:NTFS). For help on advanced formatting options, type "format/?'more" at the command prompt and then press "Enter." Keep pressing "Enter" as you read on. Hope it helps
Jan 24, 2013 | Hitachi CinemaStar 7K500 HCS725032VLA380...
I formatted my hitachi x.1000, oso2484, while trying to convert it over to ntfs ----- kept getting error messages with dos convert, Now the computer will not recognize the drive at all. did I remove a
What you need to do is that, make a backup from the HARD DRIVE onto another drive or computer then you will have to format the Hard drive. You are getting those errors because the conversion might not have been completed successfully or anything like that.
This is how you can format it
Go to start, Right - click on "My Computer" go to "Manage"
Then go to Disk Management in the Right pane. Then select the drive that you want to format to NTFS.
Go right at the bottom, right-click on the desired drive and select format. Formatting a drive n this manner will ERASE ALL DATA from the drive. This is why it is very important to Do a Backup of all your data before you do anything. Format your drive with NTFS
Apr 06, 2012 | Hitachi Computers & Internet
What format should I chose to grab it to a PC?
This will depend on which type of computer and operating system you have
if you are referring to formatting your hard drive to a specific format file system NTFS or FAT choose the Ntsf file system is more secure Ntfs is more powerful than Fat or Fat32 and includes features required for hosting Directory as well as other important security features . You can use features such as Active Directory and Domain - based security only by choosing Ntfs your file system Its easy to convert Partitions to Ntfs . The set up programs conversion makes it easy whether your partitions used Fat or Fat32 or the older version of Ntfs .This kind of conversion keeps your files intact (unlike formatting a partition). If you do not need to keep your files intact and you have a FAT or FAT32 partition, it is recommended that you format the partition with NTFS rather than convert from FAT or FAT32. Formatting a partition erases all data on the partition and allows you to start with a clean drive.
hope this helps you
Sep 03, 2011 | Computers & Internet
One of my 7K1000.C drives has extensive but minor corruption. I use QuickPar to make parity files in case of such corruption but I was quite upset to find 90% of my mp3s were damaged. Those which I had...
The best way to fix & prevent it would be to move everything off of it and wipe the drive clean and do a full format, not a quick format. The other thing could be, depending on what type of system you have and if its overclocked it can cause data corruption if the Pcie frequency is set above ~110. I have three of these without a single problem, with about 8,200, 8,080, and 5,400 hours on them.
May 24, 2011 | Hitachi Deskstar 7K1000.C HDS721010CLA332...
What is the formatting an a hitachi pro1000q
If the hard drive comes directly from the manufacturer or retailer in a sealed box, it is in RAW format. If you want to use it on a MAC, it has to be formatted FAT32, if you want to use it in a PC, then the usual format is NTFS.
Jun 28, 2010 | Hitachi Computers & Internet
I added an SATA HD to a system whose C and D drives are a WD 400GB PATA HD. The Hitachi 750GB drive has no jumpers for master/slave. After boot-up the system sees it but assigns no E or other letter...
  • Right Click [My Computer] and click Manage
  • Click Disk Management on the left side
  • Inspect the drives listed. The new drive may need to be formatted for the operating system to recognize it and assign it a letter.
  • To format the drive, right click the drive with no letter, and click Format. Choose your format (Preferred NTFS), and quick format the drive so that windows recognizes it.
Mar 10, 2009 | Hitachi Deskstar 7K1000 750 GB SATA Hard...
Can't format HDD
Feb 18, 2009 | Hitachi 500GB 7200RPM 16MB BUFFER SERIAL...
I have a 250 Gig WD hard drive originally hooked up to Mac OSX 10.5.6.  I put files on it and then a co-worker looks at those files on a PC. Now, she's given the drive back to me to add more files. These...
Greetings.
files bigger than 4 gigs cannot be save on fat32 drives. NTFS file system is capable of saving files bigger than 4 gigs.
The MAC - to PC did nothing to change it. It did not change while she look it at her pc.
If u want to be able to copy files bigger than 4 gigs to your drive, change the format to ntfs.
  • It is easy to convert partitions to NTFS. The Setup program makes conversion easy, whether your partitions used FAT, FAT32, or the older version of NTFS. This kind of conversion keeps your files intact (unlike formatting a partition). If you do not need to keep your files intact and you have a FAT or FAT32 partition, it is recommended that you format the partition with NTFS rather than convert from FAT or FAT32. Formatting a partition erases all data on the partition and allows you to start with a clean drive. Whether a partition is formatted with NTFS or converted using the convert command, NTFS is the better choice of file system. For more information about Convert.exe, after completing Setup, click Start, click Run, type cmd, and then press ENTER. In the command window, type help convert and then press ENTER.
Link to steps and other info
http://technet.microsoft.com/en-us/library/bb456984.aspx
Hope that helps.
Jan 10, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Hitachi HDS721010CLA332 Deskstar 7K1000C SATA2 3GbS 1TB 7200rpm 32MB 0F10383 High Quality SATA II Hard Drive Logo
Top Hitachi Computers & Internet Experts
Fotis Papastamatiou
steve morris
steve morris
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
