Question about Car Audio & Video
NEED TO FIND 2 CHIPS FOR MY AMP
I HAVE A VX2200D CAR AMP THAT I NEED TO FIX THE 2 CHIPS THAT I NEED THE NUMBERS ON IT IS FMU-34R IF ANY BODY KNOWS WHERE I CAN GET THESE AT PLEAS
  • 631 Answers
Kenwoodparts.com shows them as being available but they're $11+ each.
Did the legs break at the body or did they break at some other point?
Posted on Oct 27, 2008
Philips 55pp9363 H/17
They cannot be replaced with the boards left in and even they could you should not do that. There are a lot of considerations to replacing the chips. You need to keep in mind that the static electricity that is present in your body can ruin the new chips.
They might be SMT and those have to be soldered in. You did not list the chip numbers so it is hard to tell
Aug 27, 2012 | Philips Televison & Video
Need the type of transisters for the schematic diaphraM for the vx2200d monoblock amp
open the case and look at the transistor itself.
all transistors have unique product id numbers.
goto http://www.digikey.com
and type in the transistor number in the search box.
select quantity and order your replacement part.
May 08, 2011 | Car Audio & Video
I Need VX2200D Diagram by Planet Audio
You can find a user manual with the wiring diagram at planet audio's website. Here is a link to a pdf of the manual: http://docs.google.com/viewer?a=v&q=cache:5d-Vrte2v9UJ:www.planetaudiousa.com/support/index.php%3F_m%3Ddownloads%26_a%3Ddownloadfile%26downloaditemid%3D20+VX2200D+manual+planet+audio&hl=en&gl=us&pid=bl&srcid=ADGEESgVApyeRutzYOkF2zFvcSYjjx41jGcX_cCMcEpLsVlrXErVQDZ4CvvrR7zZKYO9gfqRUH4Mk_f_GA4cud4DHa_0ppWSMZxObDvKW6NeIF5f38SmVxRNkvG6vmNXlOgJtzkNJI6G&sig=AHIEtbSePXlAvmQDU-Lflxtlb6xnQFDNyg">http://docs.google.com/viewer?a=v&q=cache:5d-Vrte2v9UJ:www.planetaudiousa.com/support/index.php%3F_m%3Ddownloads%26_a%3Ddownloadfile%26downloaditemid%3D20+VX2200D+manual+planet+audio&hl=en&gl=us&pid=bl&srcid=ADGEESgVApyeRutzYOkF2zFvcSYjjx41jGcX_cCMcEpLsVlrXErVQDZ4CvvrR7zZKYO9gfqRUH4Mk_f_GA4cud4DHa_0ppWSMZxObDvKW6NeIF5f38SmVxRNkvG6vmNXlOgJtzkNJI6G&sig=AHIEtbSePXlAvmQDU-Lflxtlb6xnQFDNyg
Mar 04, 2011 | Car Audio & Video
Does any body know many watts is a Phoenix Gold QX2180?
Normally the numbers give you a big hint. 2180 means this is a 2 CHANNEL AMP EACH CHANNEL CAN PRODUCE 180 WATTS OR 360 WATTS BRIDGED.
Apr 05, 2010 | Phoenix Gold QX2180 Car Audio Amplifier
Engine rev "noise" coming through
Hi first check the ground wire from the amp. It needs to be to a body bolt that's less then 18" from the amp and is clean no paint ect. raw metal. Also the rca wire to the amp should be ran on the opposite side of the car then the power wires. This should reduce engine noise. They also sell a noise reducer that helps in vehicles that are wired correctly but still have a engine noise.
Feb 05, 2010 | Kenwood KVT-715DVD Car DVD Player
I need 2 chips for an mtx roadthunder 4250d amp the number on the chips are 75339p then there is a y1 and a 44 if u could tell me were i can get them it would be apreciated both chips are the same
HUF75339P3-ND
THE ABOVE LINK WILL TAKE YOU TO THE DIGIKEY PAGE THAT HAS YOUR MOSFETS YOU ARE LOOKING FOR IN THIS AMPLIFIER. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE....V
Oct 27, 2009 | MTX Thunder 4250D Car Audio Amplifier
Fmu
There are lots of mustang "club" sites, google mustang club st. louis and away you go, I am sure you will run across someone that could expertly help you out.
Jun 28, 2008 | 1987 Ford Mustang
Convergence intermittently bad
Are you talking about the heat sink?  The chips normally screw on to this "board" you're talking about? (silver, aluminum looking?)  I dont want to speculate here but did you use heat sink compound (also know as thermal grease)on the chips?  If so, the answer to your question for a known fix would be: you have a heat problem and all you might need to do is get some 5 dollar heat sink compound and get a quick fix.  Meaning, apply some of that stuff between the chips and the heat sink.
Oct 19, 2007 | Panasonic PT-47WX42 47" Rear Projection...
Guitar amp
You can order parts directly from Peavey. You'll have to call to place the order. You can use the followng email address to check price and availability.
parts@peavey.com
For more information, the third question/answer in the list of FAQs has the phone numbers.
http://www.peavey.com/support/faq/index.cfm
Oct 14, 2007 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Car Audio & Video Logo
70 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
