Question about Goodman GMS80903BNA Heater
Furnace short cycles
I had a new 80% 70,000 BTU heater installed. During start up, the burner would light and burn for 40 seconds. The flame would go out, the cycle would complete itself, and no blinks on the red indicator light (LED) on the circuit board. The book says that I either have a 115 volt, or 24-volt VDC problem, which we don't have, or the circuit board is bad. Is this a common problem or should I be looking for something else? Thank you. Ted
Turn electric off to heater, there should be a light switch on the side of the heater that cuts electric off to the heater. find the flame sensor, unplug wire to it and remove from heater being careful not to touch it with your hands or fingers, because of the oils in our skin. you can touch the part that the wire plugs to. when you get it out take fine emery cloth and clean the probe side or the sensor side real good and reinstall it. plug the wire back in and try heater. it should work fine. the sensors sole purpose is to detect flame and when it gets dirty with carbon it cant. so the sensor false reads and tells the heater its shooting raw gas into the heater and the heater shuts down, or short cycles, its there incase the ignighter fails. hope this helps you. it cost me 105.00 for this info. write it down in your owners manual so you dont forget it. the symptoms and the cure.
Posted on Jan 27, 2009
Why does it start, then shut down followed by 3 clicks?
  • Thermostat calls for heat
  • Venter motor starts
  • Air switch verifies vacuum
  • Igniter sparks, or glows - depending on furnace
  • Flame starts in burner
  • Flame rod senses flame
  • Burner continues to burn until thermostat stops calling for heat
By your description, I would polish your flame rod, it will be a metal rod that is insulated from the bracket that is screwed to the furnace case and it will have a single wire attached to flame rod,
Sep 29, 2015 | Intertherm 56000 Btu Gas Furnace
Have a goodman lp gas furnace modelgmpn060-3 furnance starts up get main flame for about 5 seconds then shutsoff
i would start by checking the flame sensor ...if the unit is actually firing off just not staying lit sounds like a faulty or dirty flame sensor.... if you look inside at burner assembly there will be a metal rod ranging from 1 1/2 to 4 inches in length.... it ia in burner assembly and has (1) wire that connects to it and usually one 1/4 inch screw on it.... remove this and lightly /let me emphasize lightly sand it and clean it ...to much will actually damage it...re-install and see if it helps... this senses the flame and tells the control board to keep gas valve open most likely your culprit....good luck to you...
Feb 13, 2011 | Rinnai RHFE-431FAIII 16,700 BTU Direct...
Hello, I have a Amana Air Command 80 model #GHI90A50, 22 years old. This furnace is on its third ingnition module (last one two yeras ago). The symptom I am trying to diagnose has been ongioing since this...
If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
Dec 05, 2010 | Heating & Cooling
I have a Goodman GDT045-3A heater and the burner is cycling on and off. The error / control LED is on constantly. Turn the heater on everything starts up and after 3-5 minutes the burner shuts down then...
Hello ,
"Usually" a faulty flame sensor will cause the unit turn burns off and on. The furnace usually goes through its start up and burners turn on as they should then if the flame sensor/rod doesn't to sense anything and the furnace doesn't get a signal it will usually cut the burners off and re-attempt the burner sequence again because it looking for that signal from the sensor. The flame sensor is usually located opposite of the ignitor. The flame sensor/rod is usually in from of the burner. Sometimes you can get away with "GENTLY" cleaning the flame rod with some sand paper since its always in direct contact with the flame. Try to get it looking nice and new but do clean too hard as it may break which Iv seen. Make sure you turn off power to the furnace before working on it. Work safe.
Now, as for the LED error light. Usually the owners manual will have something in the troubleshooting section referring the the LED error lights. Perhaps it may have a different issue which corresponds to the LED indication. I would start here first to get you going in the right direction. If it does mention something about the flame sensor/rod then proceed to do the above that I mentioned. Worst case scenario if it does mention this, you will need a new one.
Hope this helps.
Oct 21, 2017 | Goodman Heating & Cooling
COLEMAN FURNACE BURNER NOT LIGHTING
There is a thermocouple "wire" that is supposed to be touching the pilot flame.
The thermocouple senses a flame (hot) and allows the heater to operate. If the thermocouple does not sense that the pilot is on, then it will not allow the furnace to operate.
Bend the thermocouple wire (or the pilot tube) so that the pilot flame is touchingg the thermocouple.
That shouls work now.
The air from the fan should not be blowing through the same cxavity that the pilot is in.
If it is, then you may have a leaking furnace whereby carbon monoxide may be seeping into your living quarters.
If the fix above works and the pilot stays on after the heater starts, then there is probably no leak.
Let us know the results ... post a comment or "RATE" this or another expert's solution.
Sep 16, 2009 | Coleman Propane Forced Air Heater...
Short cycling..continually..minimal heat
Is this furnace standing pilot or electronic? if standing pilot turn power off then take t-stat off wall and connect the wires labeled r and c together and see if that keeps furnace working. If electronic check flame sensor you can check flame sensor buy cleaning with steel wool. if that doesn't work then try t-sat.
Jan 21, 2009 | Coleman Propane Forced Air Heater...
Coleman presidential II furnace blower on and off
Sounds like the flame sensor. But it could be the thermostat. Is the furnace standing pilot or electronic spark or hot surface ignition. I would start by checking thermostat. Turn power off to furnace take thermostat off wall and take wires marked r & w and connect them together. Turn power back on if furnace works then change out thermostat.Most eclectronic ignition Furnaces have a flam sensor, You could take flame sensor out and clean it up with steel wool or wire brush. If you need anymore help just reply back .
Jan 17, 2009 | Coleman Propane Forced Air Heater...
Coleman Presidential II mobile home furnace. When burner lights the blower cycles on and off instead of blowing constant through burner cycle.
Is this furnace standing pilot or electronic ignition. If standing pilot i would check furnace filter then the thermastat. To test themostat first turn power off to furnace. Take thermostat off wall and take wires labled R & W and connect them together. If you have electronic ignition I would start with cleaning the flame sensor with steel wool or wire brush.If you have and more questions i will be glad to help.
Pilot lights and one panel burns
Empire faw 40 makes a loud bang when starting up. There are three burners. The pilot light is on one burner. When the furnace starts, gas is lit on that burner and the flame is passed on to the other burners by a small channel that can get stopped up. You just have to remove the burners and clean the channel with a small file, like on a finger nail clipper. This can be difficult due to the pilot assemble being attached with two bolts. The bolt on the right has to be removed with a short screw driver. You can not get a socket on it. After you remove it there is enough play to remove the bracket and gas burners.3_4_2012_5_06_50_am.jpg
Nov 23, 2008 | Empire DV-215 Direct Vent Natural Gas...
Heating & Cooling Logo
527 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
