Question about Toys
How to fix imaginext batcave elevator
Elevator string isnt pulling up elevator and i cant figur out how to repair it. string is completely loose.
3 Suggested Answers
SOURCE: Imaginext batcave elevator string came out
I had the same issue, my son used his all of half a day and the elevator stopped working. If you take the top of the cave off, and unscrew it from the elevator shaft you will see a black wheel. The string needs to be wrapped around this twice, there should be very little play in the string. What I had to do was take out the 3 screws that held it to the knob on top, then wrap the string back around the wheel making sure not to tangle the string more. once the string is wrapped 2 times you can reassemble.
Posted on Dec 27, 2011
  • 11800 Answers
SOURCE: The top of the elevator
The plastic parts on which the elevator moves have been badly moulded - you will have to file then into shape yourself. Use a fine file - one for nails will do if you don't have something else . Look from the top, they should be straight and parallel.
The chandelier uses a very small bulb connected with some very fine wires. Again, bad manufacturing: you will have to gently take it apart and verify the bulb and redo the wire connections.
Posted on Dec 22, 2010
Imaginext Batcave drawbridge won't go all the way up.
Turn the batcave over and remove the long black piece in the center section (5 screws). Re-align the two white gears so that the drawbridge stays shut. Then put everything back together. Easy 2 min. fix.
Jan 06, 2013 | Fisher Price Imaginext DC Super Friends...
Imaginext Batcave lift sticks and doesn't go up and down. Does anyone know how to fix this?
the thread is too long, so you have to remove the top, screws (x2) on either side, then unscrew the lift reel (black disc) from the red twister (on top where figures feet fits into).
Take lift to top of run until it comes off runners, pull two halves apart and trim thread behind knot to shorten to required length), retie knot and re assemble.
Dec 26, 2011 | Toys
Dec 18, 2011 | Toys
I'm looking for book one of the lego 7783 Batcave set. all the online scans are simply horrible... you cant tell what pieces go where. I only really need the pages for the batman ski vehicle. Is there...
I have had similar problems when helping my son navigate the seemingly endless world of lego pieces with poor diagrams. I did however locate this site with color pictures and was able to easily zoom in on them with my netbook making the pictures much less confusing. I hope this helps and good luck.
http://www.toysperiod.com/lego-set-reference/batman/lego-7783-the-batcave-the-penguin-and-mr-freezes-invasion/
Mar 24, 2011 | Toys
Does anyone have the instruction manual for Trio Batcave?? Thanks!!!
Here's the pdf from Fisher Price:
http://www.fisher-price.com/us/trio/product.aspx?pid=54574&cat=4
Feb 03, 2011 | DC Shoes Fisher Price Trio Dc Super...
Lost directions on how to build fisher price imaginex batman batcave.where can i download building directions for this toy?
hi you will find imaginext instructions here
http://service.mattel.com/us/results.aspx?x=0&Ntx=mode%2bmatchany&Ntk=Product&Nty=1&y=0&Ntt=imaginext&ContentType=Product&N=0&No=0&SubContentType=IS&showall=true
Oct 25, 2010 | Fisher Price Imaginext Bat Cave Batman...
The pull string coil came loose cant figure out how to get the piece that connects to the shaft off on the ryobi ss30 weedeater
There is a cover that you loosen you pull back the handle then youll see a clamp I think its 5/16 loosen it will move but there is a thottle cable you have to loose off the thottle on thr carberator then it will slide off ,if it is a clutch ,the clutch has to be removed by the way of the the arrow then you can get to the rewind
Nov 04, 2009 | Ryobi Garden
"G" string tunning problems,
hi there .... flat means does the string go lower in pitch ...needing the string to be tightend after you have bent it ?
Do you give the strings a real good pull a few times after fitting? this often corrects the problem .... let me know ..as there could be a few other reasons
cheers Pete
Feb 02, 2009 | Epiphone Les Paul 100 Electric Guitar
Toys Logo
1,762 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
