Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Frigidaire stove steam extraction problem.
Frigidaire stove. Instead of the steam being extracted from the oven while cooking, it stays in there. I recently changed one of the heating elements and may have caused the problem then. Any help would be great.
  • 116 Answers
SOURCE: Frigidair Gallery self cleaning stove
Hey charles
This often happens after you have gone through a cleaning cycle. In most cases the relay contacts has been welded shut to one side or burnt off. The relay can be replaced or the contact freed. Otherwise the controller (clock) has to be replaced (easier).
Regards
Posted on Nov 22, 2008
aborcass
  • 2651 Answers
SOURCE: Frigidaire double oven has one element not working in each oven
sounds as if perhaps there has been a thermal overload(switch) tha has gone bad, refer to part number 119 on bothe the lower and upper oven for refernce , you should have continuity trough the switches.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/5995383394.pdf
Posted on Dec 21, 2008
barkencoa
  • 3463 Answers
SOURCE: CPES389AC3 - Frigidaire Gallery Oven - Element and broiler
The element has blown in the oven you will need to fit a new one,and possibly the broiler one as well.
Plz rate this solution.Thanks.
Posted on Dec 24, 2008
  • 30 Answers
SOURCE: Display not working nor oven frigidaire gallery
needs a new control. Easy to replace.
Posted on Oct 23, 2009
  • 1891 Answers
SOURCE: Frigidaire ES200/300 316257123
look for a shorted bake element .. you should be able to see where it poped. ( some times ) if you have ohm meter you can ck for an open element . **** //
Posted on Dec 04, 2009
Water / steam leaking from front
Is there a stove on top. If so, you may have water dripping from the top down into the area just above the oven. Does this moisture form when cooking or is it present all the time.
Mar 06, 2013 | Siemens Ovens
Have a frigidaire gas stove has worked great for 6 years. Now we are getting a strong smell of gas when it is heating up or cooking. Have checked to make sure flame is on and it is. It also seams like it...
Try changing out the regulator for the stove. Does the flame seem weaker than it used to? If so, your regulator is probably going out and the gas you smell is the residual leaking out when the stove is on.
Jul 01, 2011 | Frigidaire Ovens
Does this tappan stove require a hood for ventilation? The one I have is intalled in the center island of the kitchen.
You don't have to have a hood over a stove. If you do though it removes all steam and odours. The grill also catches all the cooking fats. Your kitchen will stay a lot cleaner if you have one.
Feb 11, 2011 | Tappan 30IN ELEC IGNa Oven
Gets hot too quickly food cooks too quickly
no oven heats to what the dial says, all are to hot or to cold. try reducing the cooking temperature by 50 *, so instead of cooking a roast at 350, set at 300. i have never seen a stove that is heating to the temperature of the setting.
Jul 05, 2009 | Zanussi ZBF260 Electric Single Oven
Hit the "clean " button on my gas stove. Not only did it not clean but the Door locked button has been flashing for 2 weeks. Everytime I go to cook and it the Bake, Broil key it flashes DR then F9 I h
Personal opinion. Do not mess with settings on a gas stove. Call a gas oven repair tech and have them come out and fix it. That way if it happens again you have someone to call
Nov 03, 2017 | Frigidaire (FEB30S7D) Oven
Gas oven that cooks unevenly
clean your orifaces.
Also make sure that it's the correct stove for your gas type. If you're using a NG stove on Propane, you're wrong. It's making a lot of soot, and could potentially blow up your house. Stop using it until you're sure.
Dec 05, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
106 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
