Samsung monitor menu controls (contrast & brightness) inoperable
I just installed on my G5 PowerMac running Leopard OS (10.5.8), connected with a DVI cable. When I push the 'menu' button on the Samsung's front panel, it appears just as expected, but when I run the mouse over the control area the cursor disappears (poof!), and thus I cannot adjust the two controls (contrast and brightness). Help!
  • Curt Scott Feb 24, 2012
    I did indeed first attempt (with the monitor buttons) to adjust the (brightness) control to "max" (i.e., 100%) so I could calibrate the color. Contrast was already at 100%, but brightness increased (with the button on the monitor) only from 80% to 83%; it refuses to adjust any higher.
  • Jeffrey Groves
    Jeffrey Groves Feb 24, 2012
    It sounds like the monitor may be defective. You may want to take it back for a replacement.
  • 536 Answers
You're not supposed to be able to use the mouse to adjust these settings. These settings can only be adjusted from the buttons on the monitor!
Please read the user manual for your monitor for exact instructions.
Posted on Feb 22, 2012
Upgrade for a 2005 apple mac desktop tiger 10.4
The highest you can get up to is leopard 10.5. Unfortunately, after 10.5 Apple moved to Intel getting rid of the powermac processors.
Depending on your specs I would recommend sticking with tiger, but leopard should run fin on your powermac. It runs great on mine.
Jul 22, 2013 | Apple Power Mac G5 Desktop
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
Brightness and contrast symbols
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
Automatically adjusting the display control, such as contrast & brightness.
if you want to adjust the contrast and brightness press the Menu button on the front of the monitor then select management and then change the contrast and brightness
Mar 16, 2010 | Computers & Internet
Viewsonic VA902b too bright. menu control greyed out
open the monitor draw the screw and there is a big black part called E.H.T.to which has preset to rotate it with screwdriver in on condition of monitor untill sufficient brightness will come
Mar 09, 2010 | Computers & Internet
Contrest & brightness menu always pops up and
there is a problem in micro controller chip in the monitor replace that biggest chip in the monitor problem will be solved
Feb 28, 2010 | ViewSonic VP920b 19" LCD Monitor
Frontbuttons function details
These buttons are used to control the various setting of the screen, such as Brightness, Contrast, Height, Width, Pincushion, and various others.Usually one button, usually the MENU will bring up the master menu, the other buttons are Left & Right. are used to go up or down with the settings, or + & -, Repeated presses of the button(s) will advance it on to the next setting.
Feb 11, 2010 | Samsung SyncMaster 912N 19" Flat Panel LCD...
Color calibration
All monitors have a brightness control. Click the menu button and from the on screen menu choose the brightness and set it to your liking. There should also be a contrast control and may or may not be a backlight control. All the user controlled setting are in the OSM.
Nov 27, 2009 | Computers & Internet
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
