Question about Alpine Car Audio & Video
How to bridge alpine mrp f250 amp to one 10 - Alpine Car Audio & Video
Mitco39
  • 62 Answers
SOURCE: Alpine mrp-350 amp
1) If you bridge on a non bridged amp your sound will be horrible as they sine waves comming out of the two teminals will be different... I suggest removing the bridge. 2) The gain knob is to adjust when the amp will reach its max volume with respect to the sterio;s volume. 3) the LP filter is a Low Pass filter and its purpose is to eliminate the higher frequencies that do not sound all the well when played over subwoofers.
Posted on Mar 26, 2007
ajdriver
  • 15 Answers
SOURCE: Alpine MRP-M650 : Power LED turns on but no sound
is the remote lead properly connected to the head unit? if the power led is on then the power cable and earth must be good, check the remote lead 2 your head unit first, if thats all good try looking at the amp to see whether theres a small switch to adjust the output going to the subs, if its very low or right off then nothing will be going through to the subs. if its on high and fine it only realy leaves the neg and pos inputs from the amp 2 the subs.
cheers, adam
Posted on Nov 18, 2007
  • 631 Answers
SOURCE: Wiring diagram for Alpine MRP-F300
From the Crutchfield site:
Owner's manual
You'll use fig.8 for the front speakers and fig.9 for the subs.
Posted on Sep 05, 2008
artbesio
  • 55 Answers
SOURCE: want to bridge my alpine 3555 amp to run my sub.
I'm assuming this atleast a 2 channel amplifier all you need to do is hook the negative side of the speaker wire coming from the sub to the negative channel one. and the positive to another positive on channel 2. Should indicate on your amplifier channel one and two. most amps provide a diagram right on the amplifier over top of the speaker inputs. let me know if this helps.
Posted on Mar 08, 2009
  • 133 Answers
SOURCE: Alpine mrp-m450 Amp won't stay on
Sounds to me like it might be the remote turn on because the first time i installed it, it did the same thing, and i found out that there is two blue wires coming out the stereo, one with a white stripe, i connected it to the blue wire, and it didnt work, then i connected it to the blue and white wire, and it worked. Well hope this solves your problem, goodluck.
Posted on Jul 06, 2009
How many watts does this amp put out
50 watts RMS x 4 at 4 ohms (75 watts RMS x 4 at 2 ohms)
150 watts RMS x 2 in bridged mode (4-ohm stable in bridged mode)
Feb 19, 2012 | Alpine MRP-M650 Car Audio Amplifier
Where can i find a wiring diagram, so i can bridge it?
hi u can bridge a amp only if it is a 4 channle amp .u put the left +and the right - together . i never bridged a mono amp so i hope this helps .
Feb 23, 2011 | Alpine MRP-T220 Car Audio Amplifier
Can this power a subwoofer and what is the rms wattage
Hello crucible19,
The Alpine MRP-F240 is a 4-channel amp that outputs 40 watts RMS per channel. It is more suited for powering normal speakers, but since it is bridgeable, you could power a small sub by bridging 2 of the channels.
Hope this helps.
Oct 02, 2009 | Alpine MRP-F240 Car Audio Amplifier
What is the best way to connect 4 speakers and a sub to a 4 channel amp.
I would connect the 4 speakers to channels 1-2 in stereo with high pass filter. Bridge the sub to channels 3-4.
A thumbs up would be greatly appreciated if this answer is helpful to you. best-way-connect-4-speakers-sub-4-zb4bomd1rt4qms0dqd12kkt2-3-0.jpg
May 01, 2009 | Car Audio & Video
Weak rear left amp output?
hey whats up bud i got an ALPINE V-POWER MRP-M350 these amps are great go to a walmart od any music shop buy a set of R.C.A cables that plug into your amp than that Ys off to a single connection its a male cable that run a set from the back of your cd player heres the trick ONLY PLUG YOUR BLACK COLORED RCA INTO HEAD UNIT MAKE SURE YOU RAP THE RED ONE WITH TAPE OR GET A RUBBER CAP TO PUT OVER IT SO YOU DONT GET ANY STATIC FREQUENCIES COMING OUT OF THE RED ONE THAN RUN THAT SET TO YOUR AMPLIFIER AND AGAIN ONLY TIE INTO THE LEFT CHANNEL OF YOUR AMPLIFIER.... Hope you know wnat i mean by that Y adapter ther is 2 prongs that tie into amplifier than it splits into 1 were your rca cables will plug into just that one thats how you bridge these confusing amps.... TRUST ME BOTH SUBS WILL SLAM HARD I RUN 2 JL AUDIO OFF OF MINE NO PROBLEM.... WRITE BACK TO ME IF YOU HAVE ANY PROBLEMS OR WHEN YOU GET IT HOOKED UP MY EMAIL ADDRESS IS gordo8785@yahoo.com hope to hear from you soon...
Dec 27, 2008 | Alpine MRP-M350 Car Audio Amplifier
Hi, I've just install an alpine power amp with JL 10inch subwoofer, everything seems to be working properly except for the subwoofer
If you have the RCA's running from the head unit to the amp, and the speaker wires running to the speakers then you have it hooked up right. Now If you still don't have any sound then you need to look at the amp to make sure that you have a green light. Still I would use 8 or 10 gauge power wire and then the same for the ground wire, make sure that you have a good ground.
Freakville03
Dec 21, 2008 | Alpine MRP-F250 Car Audio Amplifier
How many speakers can I use?
This should work if channel 3 & 4 are bridged at 4 ohm.
channel 1 should be stable at 2ohm
channel 2 should be stable at 2 ohm
You can hook up the right side speakers together ( + with + and - with - ) . same thing with the left side. this will give you 2 ohm each channel. this will cause your amp to run hot (this might be tuff on the amp). It will give you right (2 speakers) and left ( 2 speakers ), no front and rear adjustement if you need to balance your sound. I think you should be better buying another amp for your sub and take your 4 channels for your 4 car speakers. this amp as a rca output that can feed the other amp ( sub amp ). it is possible to do it.
Good luck
Nov 11, 2008 | Alpine MRP-F250 Car Audio Amplifier
Amp on but no sound from subs
Make sure that you have a good set of RCA cables. Then make sure that you have 14 gauge speaker wire. As for amp make sure that you use 8 or 10 gauge wire. Make sure you have a good GROUND.
May 21, 2008 | Alpine MRP-F250 Car Audio Amplifier
Alpine 250
And theres your problem. You can't run 3 speakers on it at once. BIG NO-NO! It can only have 2 ohms or more on each channel or 4 on the bridge. Three speakers is gonna be WAAAAYYYYY below that. You need to correct it ASAP, or it's ALL gona blow.
Sep 22, 2007 | Alpine MRP-F250 Car Audio Amplifier
Alpine mrp-350 amp
Feb 18, 2007 | Alpine MRP-M350 Car Audio Amplifier
Car Audio & Video Logo
161 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
