Question about GPS
Replacement car charger for a SW-87180500150A
Where can I purchase a charger for my POWER ON BOARD - BRIGHT BAR - MODEL WLB26P
That unit could be 10 years old!
VECTOR
4140 S.W. 30th Ave., Ft. Lauderdale, FL 33312
Toll Free: (800) 54-HOW-TO
WLB26P
Jan 31, 2016 | Computers & Internet
How do I get my charger replaced, it should be under warranty, how do I get a new one?
I would think through the company that made it . or perhaps the one that sold it . sure was not us here .
Feb 23, 2015 | Visual Land PRESTIGE 7 - Tablet - Android...
Need a replacement for linksys wireless-g wrtp54g power cord. Bought a 300mA adjustable one, but it didnt work; do I need the 600mA?
This is High Quality original LINKSYS AC Adapter Charger
Input Voltage: 100V-240VAC (50-60Hz)
Output Voltage: 12v1a
Model: AD12V/1A-SW
DC Plus Dimension: 5.0mmX2.1mm
Compatible Models:
WAG300N
WRT54G
WRT54GS
WRT300N
Linksys Routers
Sep 10, 2011 | Linksys Wireless-G WRT54G Router
Why does my olympus li-42b battery charger flash red?
this is either bad battery or bad connection with the charger. reverse polarity on the plug in, clean the contacts or purchase new battery.
Jun 05, 2011 | Olympus Stylus 770 SW Digital Camera
Olympus u770 sw 7.1 No power, battery fully charged, lens cover is open. No lights no screen nothing. Camera has been perfect for almost 4 years just shut down whilst being used hence lens cover open. Any...
Hi
Sorry to hear about your issue with the Olympus mju 770 SW. There's a couple of things you can check and try, before thinking about a repair or binning the camera and getting a new model.
1. Check the contacts on the battery are clean?
2. Clean the contacts inside the cameras battery compartment are clean?
3. Is the charger actually charging the battery? Try another battery or see if you can test the existing battery with a multi-meter to check there is some power in it.
It is fairly common for chargers to fail, so it's worth checking out but don't go spending money on a new charger unless you know it will fix your problem.
Hope this helps
David
Jan 13, 2011 | Olympus Stylus 770 SW Digital Camera
Where can you buy a charger for olympus 790 sw
ebay or from the company website, you can just type in the model number and google it, i'm sure there are stores selling this particular model charger
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Nov 15, 2009 | Olympus Stylus 790 SW / µ[mju:]790SW...
How can i charge 790sw without a charger
you can't. you need a charger since this camera doesn't charge via USB when connected to PC. If you need to buy one, i hope this link helps..
http://www.bizrate.com/digitalcameraaccessories/products__keyword--olympus+stylus+790+sw+battery+charger.html
cheers!
Jul 11, 2009 | Olympus Stylus 790SW Digital Camera
SanDisk Sansa m250 MP3 player
hey :
sir you damaged your battery by charging it with the razor charger.
the razor charger have more volts than your device sw the only solution you got is replacing your devise's battery .
click here to purchase one
Aug 12, 2008 | SanDisk Sansa m250 MP3 Player
OLYMPUS U770 SW TOUGH CAMERA / Olympus U770 SW -Camera 2007
You should be able to order what you want from most any photo products supply store. You can also get in contact with Olympus directly, and enquire for a local dealer for what you need. '
Jerry G.
Jul 01, 2008 | Olympus Stylus 710 Digital Camera
The power supply of olympus digital camera is on and off
what do you mean not functioning? Could you elaborate more, pls. I have this camera too, and thru extensive research and usage I might be able to help you using my own experience.
Apr 05, 2008 | Olympus Stylus 720 SW Digital Camera
GPS Logo
234 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
