Question about Yamaha RX-V463 Receiver
RX-V463 On Screen Display
How do I get the On Screen Display to work? All connections to components are with high grade HDMI cables.
Take a standard rca video cable from rcvr video out jack to an av input on your tele....when you press menu you will get the osd via av input
Posted on Oct 28, 2008
You have to puch the amp button then menu
Posted on Nov 02, 2008
I am using a logitech harmony one remote. i have a yamaha rx-v463 hooked up to a phillips hdtv, i am running hdmi from revr to tv. i have cable box hooked upi hdmi to recvr and bluray player hooked up to...
The remote has nothing to do with this.
Get into the manual. Page 14 says Component Video In will go to Component Video Out, not HDMI. No analog-digital video conversion is implied.
Jul 08, 2011 | Yamaha RX-V463 Receiver
Connection Problem with HDTV, Receiver, DVR, and DVD
check the setup menu to direct your inputs from the hdmis. its all in the setup menu. good luck
Feb 10, 2010 | Yamaha RX-V463 Receiver
Connect my xbox on reicever
If your xbox has HDMI connector then you HDMI cable to connect it to the receiver and another HDMI cable to connect receiver to the TV. Receiver should support both video and audio over HDMI.
If your xbox doesn't have HDMI, connect the video directly to your TV using whatever connector/cable is available (in terms of quality from best to worst: HDMI, component, s-video/scart, composite).
Then connect audio to the receiver via optical spdif cable.
Jan 29, 2010 | Yamaha RX-V463 Receiver
I need to hook up a yamaha 465 receiver
It has two HDMI inputs and one HDMI monitor output for the TV, so assuming all your devices are HDMI-capable, YES.
http://www.crutchfield.com/p_022RXV463/Yamaha-RX-V463.html?tp=179&tab=features_and_specs
Nov 28, 2009 | Yamaha RX-V463 Receiver
With Cable connected to the rx-465 input, I'm not getting HDMI output to a Samsung plasma TV. With DVD HDMI input I get HDMI output to the TV. Any suggestions on what I'm missing. Thanks, Greg
is the cable connection hdmi? is the unit capable of upconversion to hdmi, if you use a component connection? probably not. if it is capable of upconversion, check your input menu settings
Nov 03, 2009 | Yamaha RX-V463 Receiver
The Yamaha RX-V463 AV does not playsound from the blue ray player
"I am also having difficulties in try to display the yamaha set up menu on the tv."
According to the manual the display menu for TV will not work with HDMI hook up.
I also have a Panasonic HD TV and can't get TV sound through my Yamaha AVR on "TV Sound" mode.  Trying to use HDMI cable for this also.  Do I need a digital optical cable or do I not have something set right?
Apr 07, 2009 | Yamaha RX-V463 Receiver
Yamaha RX-V463 and LG DTV
I solve this problem by using an optical cable.
The only OUT socket from the TV was this one so i connected the optical cable to the optical input in my amp and it's ok now.
If your TV has another type of Out socket (HDMI OUT e.g) i think you can use it as well
Feb 23, 2009 | Yamaha RX-V463 Receiver
Can't get to onscreen display for auto set up
on page 15 of user manual there's info about it. Unfortunately, there is no OSD on HDMI connection.
Best regards!
Nov 16, 2008 | Yamaha RX-V463 Receiver
Yamaha RX-V463 component hook ups
This receiver does not have video conversion capabilities. In the owners manual it mentions this. So HD in = HD out. Analog in = analog out on the video portion
Nov 02, 2008 | Yamaha RX-V463 Receiver
Yamaha RX-V463 Receiver Logo
548 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
