Question about Elna Sewing Machines
I have a Elna 344 serger. The stitch finger has broken. Out its the little piece that looks b like a fork and screws on under face, throat plate. Can you get this part our know who can. Elna been no help. I only have about 50 hours on this machine. Thanks so much for your time.
  • Elna Master
  • 7,365 Answers
Check with sewvacdoctor.com
Posted on Feb 20, 2012
snakehead
  • 1074 Answers
SOURCE: stitch and looper problems
CHECK your bobbin it needs to be replace probably it is broken or worn out
Posted on Jun 16, 2007
SOURCE: Kenmore sewing machine - uneven top stitches
Am about to buy this machine for my wife and the sewing machine cabinet I have chosen has parameters as far as the overall dimensions of the machine. Can you provide me with the width, depth and height of this sewing machine. The cabinet is offered for sale by Sears so it ought to work but still I will feel better with this information. Thank you.
Posted on Feb 05, 2008
SOURCE: Brother Serger 634d
where can i buy a new thread tree for my 1034d brother overlocker from betty c
Posted on Mar 23, 2009
Zenqi
  • 208 Answers
SOURCE: I need an Elna Pro 5 DC serger machine Owner's Manual
The original manual is out of print and all that is available now is photocopies and they cost about $15. Let me know if you still need it and your zip code so that I would know how much postage would be.
Posted on Jun 29, 2009
I have a Juki serger MO634DE that a "spacer pin" (not sure what it is called) next to the feed dogs on the throat plate slides out while stitching and ends up in the seam on the item I am sewing.
That is the "stitch finger." It should not slide easily. When activated, it helps prevent the edge of the fabric from curling from the tight stitching. You may want to have a tech take a look at it. It may be bent.
Jun 15, 2017 | Juki Sewing Machines
HELP! I have a brother 1034d the thread is stacking up on the little fingers on the needle plate
I have the same problem. The serger is making the chain, but it's not moving off the stitch finger! I have to pull it while im operating it (with force) and when i put fabric, it bunches up like crazy and i just broke a needle... Any clue anyone?? Here is a picture... https://goo.gl/fhqq15
Apr 23, 2017 | Brother Sewing Machines
I took the throat plate off to clean my Imagine serger. When I try to put bak on it has to be pushed back down and is against a small piece, seems to be too close.
THROAT PLATES ARE HELD ON EACH SIDE WITH A SMALL PIECE OF METAL (SPRING). 1. PLACE THE PLATE AT AN ANGLE OF THE THROAT. 2. AT THE SAME TIME CAREFULLY PUSH EACH SPRING UNDER THE PLATE. 3. SLIDE THE PLATE TOWARDS THE AREA WHERE THE PLATE SHOULD FALL INTO THE LOWER POSITION.
Feb 26, 2015 | Baby Lock Imagine
Older Elna machine-black stitch discs, how do I use them
These discs are either single or double discs, the doubles give forwards and backwards movement by the feed dogs moving the fabric as well as side to side movement of the needle. This gives you the "Supermatic" stitches, revolutionary in 1952 when Elna developed this technology.
I'm assuming that you have a Supermatic (green) or Star Series SU (white with blue top) Elna model? your model will have a code number on the side plate by the power point, it may be 62 if its a Star, there is some variation in how you select the automatic stitches between these models but the basics are similar.
Start first by turning the stitch width selector to zero and stitch length selector to zero.
You need to insert the disc into the Elnagraph carefully, lining up the dot marking on the disc with the finger within the elnagraph, there is a little hole underside of the disc where this finger goes into to lock the disc in place. You now turn the stitch selector to "A" for automatic, and turn the stitch width to 4. Always turn your dials back to zero before removing the disc as there is a little feeler that swings over to "read" off the disc and you won't want to damage this.
The very early Elna supermatic take a slightly different disc, the finger hole is slightly different to the later machines and they were removed using a little tool. Later models it got easier and you push the middle of the elnagraph silver ring to release the disc.
I hope I haven't confused you more, you may want to join the Swiss Elna user group called Elna Heirlooms under yahoo.com groups, its a very helpful group of members and you should find a thread on these machines there.
Mar 18, 2012 | Elna Sewing Machines
How do I set up my babylock serger for a rolled hem? What is the tension to be set at?
I don't know your babylock well, some of these have automatic tensions and electronic stitch selection. But a rolled hem is achieved on any overlocker in the following way; the actual dials and knobs might vary a bit.
Firstly there is a stitch finger that you need to change or retract so that the thread can roll the fabric rather than staying flat. For a normal seam this finger sticks out in the area where the loopers and needle form the stitch holding the cut edge flat until the seam is made over it. But for rolled hems you want to retract this finger so it does roll.
On the Bernettes this is a little lever in front of the stitching area that you pull back to retract the finger. Have a look around where the stitch forms and you should see the finger. Some machines, its a part you change on the needle plate with a screw driver, or just move a switch or lever.
You want the right hand needle in place, remove the left hand needle.
Thread upper looper with wooly overlock thread, this is a fluffy nylon that pulls flat under tension but relaxes and "fills" out once its stitched into place. Gives that lovely covered look you see on shop bought tablecloth edges. Your regular thread in needle and lower looper. Usually cutting blade to the right side as you want it to cut more fabric than in the seam so it rolls under. Now loosen off the tension on the top looper, (I use 2 on mine but this is something you need to finesse with each machine), and tighten up the tension on lower looper, (about 7). Leave needle tension alone.
Now test stitch on your fabric, and finess the upper and lower looper tensions until you get the lower looper thread almost not showing, it should be right up against the needle on the underside with the upper looper thread completely wrapping around top and bottom, pulling the fabric under.a seam like this.
Test stitch and adjust upper and lower looper until this is happening.
Now, turn stitch length down to close up the stitching, probably 1 or 0.8 if you want a real satin stitch look to the hem.
Because of the stitch density this uses thread so do the finessing first, then turn the length down.
That's it! Now right down the tension settings you used and keep handy for next time.
Sep 24, 2011 | Baby Lock Eclipse Serger
I need to switch to rolled hemming and can't find my manual
Is this on a serger?
Rolled hemming on a serger is usually achieved by doing the following: thread up for three thread overlock using right hand needle. Move blade to the right to trim fabric wider (so it rolls inside the seam). Put woolly overlock thread through top looper (this gives a smooth finish to the rolled hem). Loosen off top looper and tighten up bottom looper so the bottom looper is up tight against the needle thread on the underside. Test serge to get the stitch right, then turn the stitch length down to 0.5 to close it up tight (this uses loads of thread so I usually get everything else right first, then make this final adjustment). On my Bernette 334D tensions are R-Needle - 5, Top looper 7-8 and bottom looper is 3-4. Stitch length 0.5, differential zero.
And usually you flick a small lever or change a little finger on the foot or plate where the stitch forms, there is some variation here between models. Early Elna L4 and L5 locks you had a little finger you changed with a screwdriver on the pressure foot. Bernette has a little slide mechanicism near the blade that you flick forward to engage.
Hope this is of assistance to you - I went for a 2 hour lesson on my serger when I bought it and then came home and repeated all the techniques shown and then made notes and stapled all the stitch samples into a notebook so I could remember how I did it.
Also there are some great books on Serging, Nancy Zieman is one name that springs to mind. Or try You-Tube, she has some videos up there too showing different techniques.
Apr 27, 2011 | Janome Sewing Machines
New 344 elna overlocker - can't thread lower looper After aligning thread in V cut-out of automatic threader it will not move far enough to the left to engage the thread. There is a metal part of the...
I have been dealing with the exact same problem for 2 hours and no answers!! I have just discovered that if you move the stitch width finger to R instead of N, your threader will work!! Hope this helps :)
May 14, 2010 | Sewing Machines
Replacing needle on Elna Pro 905 DCX serger
Try and loosen the screw, and use a magnet to pullout the broken piece. It likely slightly bent in there so you may need a pair of tweezers as well
Jan 23, 2009 | Sewing Machines
Elna pro dc 5 stitch width lever
Hi Dawn,
That machine is a Hosea Serger right?
I looked at some specs but I can't find that part you have described. Is it on the front panal?
Sergers are tricky, you might want to have a someone look at it make sure it is balanced. I'm gonna look into a couple more options for you in the mean time.
Bonnie
Nov 06, 2008 | Elna Sewing Machines
Elna walking foot
If your SU is an Air Electronic model i.e. 80's model, Elna didn't make a walking foot to fit. However, if you've got a walking foot that is the same height from sole plate to the screw fitting as a standard Elna foot then you could give it a try. The walking foot connects to the presser bar with a screw but the needle bar also needs to hook into a secondary lever on the side of the walking foot to make the foot actually move. Probably sounds very confusing . Check the movement of the foot manually by hand turning the fly wheel to see how it works before you actually use with the motor to minimise any problems if the foot doesn't fit.
Also you'll probably only be able to do straight stitch with this foot due to the clearance around the needle plate.
Oct 27, 2008 | Elna 2007 Mechanical Sewing Machine
Sewing Machines Logo
145 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Derek Massey
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
