Question about Yamaha RX-V3900 Receiver
Yamaha RX-V3900 7.1 Channels Receiver - Yamaha RX-V3900 Receiver
  • 125 Answers
SOURCE: Yamaha RX-V995 receiver turns on & then powers off 2 seconds late
I suggest you run self diag.  press [FM/AM] key + [Input mode] key and press the [power/standby] switch.
ps prt = power supply problem
dc prt = shorted output or leakly cap in channel
tmp prt means to hot on heatsink
you'll likely have to measure the resistances of the output FETs to find a short,
Posted on Feb 03, 2009
SOURCE: Yamaha Rx-V870
I replaced it with a 6V lamp. Radio Shack part# 272-1140. It cost $1.49.
lynchms
  • 93 Answers
SOURCE: yamaha rx v663 receiver, turntable input
What you will need is a phono pre-amp, then you can run into the receiver with a line level input to an empty audio input on the receiver, you can try Radio Shack to obtain one.
Posted on Feb 11, 2009
SOURCE: zune and yamaha RX-V663 Receiver
Buy the Zune A/V kit and hook it up to a non used rca port on the back. Look for the older ones for the 30 gb units, they are much cheaper than the new ones and it takes 10 seconds to modify them to use on the newer units. The A/V kit has 3 rca plugs, one for sound and 2 for video. If you pick a source that can play video and sound on your receiver, then the screen on the zune will display on your television. The A/V kit has a remote with it also so you can control the zune from the room. I have not tried it, but since the Zune remote is IR then if you have a good all in one remote, such as a harmony, you may be able to program the codes from the Zune remote into it and even be able to control your stereo and Zune from one remote. Hope this helps.
Posted on Feb 28, 2009
hbsurfdawg
  • 95 Answers
SOURCE: Yamaha RX-V1400 receiver powers off, in case it becomes louder
Hey, yeah that can be frustrating.
When you turn it up do you hear the relay or a clicking sound, then you turn it on and it comes back below the +2db?
Try unplugging All the speaker wires from the unit. Turn on the unit and listen for the click.
after the click, turn it up past the 2+ db mark and see if you hear it click or shut down. If it did not click off, then suspect a shorted crossover on one of your speakers.
2nd test is to plug in One speaker, and test it at high volume, it will not harm it. If it shuts off disconnect that speaker and try another. Only one at a time.
If it works at high volume, you need to isolate one of your speakers and i bet it has a shorted crossover that has been cooked. P.S. If one is bad, suspect they will fail at a later date.
If they all fail, use a friends speaker and try it before sending it to a repair shop.
P.S. i found one on ebay i think you can get for under $100 bucks in the box.
http://cgi.ebay.com/Yamaha-RX-V1400-7-1-THX-Select-Receiver-MINT-Condition_W0QQitemZ330311512027QQcmdZViewItemQQptZReceivers_Tuners?hash=item330311512027&_trksid=p3286.c0.m14&_trkparms=72%3A570|66%3A2|65%3A12|39%3A2|240%3A1318
E
Posted on Mar 02, 2009
HOW DO I USE A EXTERNAL AMP LIKE A YAMAHA M-85 FOR MY CENTER CHANNEL ON MY RX-Z11 AV AMP
You should have preamp output jacks on the back of the receiver. Hook that up to your external amp input.
Jul 24, 2013 | Yamaha RX-Z11 11.2 Channels Receiver
Yamaha receiver picture disappears and reappears when changing volume
I had the same problem with HDMI input to the RX-V373 from a DirecTV receiver. The RX-V373 volume display and menus on the screen are HD only, which forces the monitor to switch modes when viewing SD.
My solution was to turn off 480i and 480p signals from the DirecTV receiver, and also turn off its native output. The DirecTV receiver then upconverts SD signals to HD. Changing RX-V373 volume then doesn't affect monitor video mode.
May 10, 2012 | Yamaha Audio Players & Recorders
When I set my Yamaha rx-v363 amplifier to 5ch Music Enhancer all my speakers (including the sub woofer) work fine except for the center speaker. I can't even adjust the center volume on the amp (but I can...
The receiver automatically pick the best configuration for the source audio. Most music is 2 channels being up-sampled to 4 channels. (Sub-out is separate.)
Mar 22, 2011 | Yamaha RX-V363 Receiver
Yamaha RX-V3000's front channels quit working
The front channels could still go out if one of them
is going out as the relay will shut em both down if it senses a problem! Check also for bad solder connections too!
Apr 13, 2010 | Yamaha HTR-6030 Receiver
Yamaha RX-V800 shuts down when any control button is pressed
What if you DON'T use the remote? Does it shut down when just using it?
If SO, you have a bigger problem.
If NOT, it sounds like the remote is hosed - sending a code to shut off.
Do you have another remote of any brand that you could set to do something simple, like change volume? Don't train it from the original, though, or it would do the same thing.
Feb 13, 2010 | Yamaha RX-V800 Receiver
Yamaha RX-V800 - No audio on left and right channels
I too am experiencing this problem.... and my receiver is only 5 months old. Its a RX-V661
Oct 30, 2007 | Yamaha RX-V2500 Receiver
RX-V596 center and rear channels do not have any sound
Nevermind... My center channel output was set to "NONE" I've had this receiver for a few years now, probably set it that way back when I got it. Oh well, Helps to re-read the user manual...
The info is in the "SET MENU" section of the manual, Pages 35-38. Should solve the issue for "almccrum" above as well.
If you don't have your manual it can be downloaded here:
www2.yamaha.co.jp/manual/pdf/av/english/re/RX-V596.pdf
Oct 06, 2007 | Yamaha RX-V596 Receiver
Yamaha RX-V3900 Receiver Logo
43 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
