I want to fix the power input sokect in lgw4 laptop
I feel that that the sokect for the charger in the LAPTOP is dry solder and i need to open the back cover, i need to know how to open the cover of laptop
  • 72 Answers
SOURCE: HP Pavilion zv5000: Screen blan, power light, fans are on.
lala linda is right. . . repairing the power pin isn't that expensive ... In fact I've fixed some myself and it's really not that hard. It is time consuming and tedious to make sure that all the bits and pieces fo back in the right place. Take some pix as you take it apart and you will find that's it much easier when you go to re-assemble the unit. btw . . . The power pins are available on the net for $ 10 or less usually.
Also . . .Once you get it fixed get a Cable retention device to make sure you don't damage the pin a second time. Personally I recommend (and use) this one.
Posted on Sep 24, 2008
  • 71 Answers
SOURCE: Cannot open laptop LG LS70 to fix the power input connector
you will need to open the upper part of your laptop starting by detaching horizontal panel at the top of your keyboard and removing your keyboard. there should be screws that you should open.
Posted on Nov 03, 2008
  • 199 Answers
SOURCE: Does a laptop charger need a voltage regulator?
No. Your charger is designed to correct for input fluctuations and has a certain tolerances to meet for output voltage and current ripple.
Posted on Jun 17, 2009
joegoldman
  • 335 Answers
SOURCE: I have a vaio pcg-7l1m which will not power up.
When you say you checked the adapter, I assume you mean you put a meter to it and it is giving 18-19 volts. I also assume that no power means no led's, no fans, no nothing.
Before you tear it apart, please try the following to try and get some signs of life.
Remove the battery and try to boot. Leave the battery off for the rest of the testing. Remove the hard drive, and the optical (dvd) drive. There is likely a screw on the bottom that will release the optical drive. Try to boot. If no good, remove the ram and try again. The ram stick(s) are located under an access panel on the bottom of the laptop.
If all this produces nothing, your last effort may be to resolder the dc power jack on the mainboard. This is not that difficult but you need to be careful while doing this:
I like to keep two separate containers for screws...one for those from the bottom, and one for those from the top. If you own a video camera, maybe video the laptop as you do this. It could be a valuable reference when re-assembling it :)
First, remove the access panel from the bottom that provides access to the wireless antennas (2 wires). Pop the connectors off of the wireless card. You must do this to remove the display, as the wireless antennas are in the display. Next you need to remove the top bezel (strip of plastic above the keyboard. You may need to remove some screws from the bottom to release it. Gently, insert a small flat head screwdriver under one of the hinge covers (plastic bump over hinges) and pry up . Usually it is just plastic clips holding it on and it will pop off. You should be able to remove the bezel easily.....gently, remember? With the top bezel off, you can remove the keyboard (may have screws on the bottom holding it, but likely not. Remove keyboard screws on top, disconnect the ribbon cable and remove the keyboard. Now, snake the antenna wires that you removed earlier up through the top of the laptop. Remove any connector cables going from the display to the laptop. Remove the hinge screws holding the display on and remove the display. There might be two screws on the bottom securing the display as well.
Now, remove all screws on the bottom of the laptop and try to gently pop the plastic case apart. There may be screws under the keyboard (on the top side) that hold it together too. Take your time here, paying close attention to any connector wires....BE VERY MINDFUL OF TINY WIRES AND CONNECTORS.
Once you get the case apart, there will likely be a few screws securing the mainboard to the plastic case. Remove these (circle the empty holes from the screws with a marker so you know where they go back in)
With the mainboard out, locate the dc power jack. It likely has 3 or 4 solder joints securing it to the board. With a magnifying glass, inspect the solders for cracks in the solder joint. If they are cracked, that's likely the issue. If not, resolder them anyways. Using thin electronic solder wire (do not substitute with plumbing solder) heat each solder joint, and apply a SMALL drop of solder. Not too much, or it can run down into the connector and bugger things up. Be careful not to touch/heat up any other components near the jack too.
With this done, dry fit (without all the screws) the laptop back together. Make sure all the little connectors have been re-connected and while thinking happy, positive thoughts, try to power it up :)
If this won't get it to power up, then you likely need a new main board. If you can't find one for a reasonable price on ebay, get a new laptop. In my experience, Sony will not sell a mainboard to anyone other than an authorized Sony service shop, and even if they will, it will likely cost $400 or more.....too much to spend on a part (likely refurbished) with a 90 day warranty.
Hope this helps! Post a comment and let me know how you made out.
Posted on Aug 23, 2009
  • 19 Answers
SOURCE: I need to open my sony vaio model pcg-8f1l laptop.
unscrew the back panel
Posted on Nov 27, 2009
My laptop was plugged in and lit up showing it was charging but when I pressed power button nothing happened. I unplugged from charger and no lights at all and pressed button and nothing happened. Is
plug where Check for loose power where power cord connects.
A computer repair shop can replace the power on/off button and he power plug input jack if required. Make sure the laptop power charger has the correct voltage for the computer if it is universal power supply/charger.
Feb 08, 2013 | Toshiba Satelite 4000CDS Laptop AC Power...
Laptop is charging but cant turn on
When you say "you fixed the thingy" (ac jack), how did you fix said "thingy", did you open the laptop and replace the damaged/broken "thingy"? Need more info. Perhaps the "thingy" isn't fixed? Try remove any DVD,CD, USBs from the laptop, removing the "thingy" , remove the battery, Hold down the on/off button for 10 seconds, replace the battery, replace the "thingy" push the on/off button. That said, When you fixed the "thingy" was ALL power removed from the laptop AC plug, Battery, If not a short may have occurered.
Nov 06, 2012 | Lenovo G470 Core I5 4gb 500gb Hdd Laptop...
The pin that u put the charger in has went back in the laptop. how to open it to get to it to fix it.
The power socket on a laptop is usually soldered directly to the mainboard. Sometimes the socket is on a seperate smaller daughterboard or on a cable that connects to the mainboard, but usually this is not the case. Opening the laptop to perform this repair can be very trick and time consuming. I would certainly not recommend an amateur attempting this repair as usually the entire board needs to be removed, the socket de-soldered and a new socket soldered in place. Not for the faint hearted! If you wish to provide laptop model details I may be able to provide the screw locations etc and disassembly guide.
May 29, 2011 | Computers & Internet
My battery charger input
When you connect the power adapter into the laptop, does the power LED light up? If not then -
The battery adapter or the adapter's power lead or the laptop's power socket could be faulty.
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Jul 19, 2010 | Lenovo ThinkPad T61 Notebook
The charger for my laptop will not charge it. I used the charger from another Gateway laptop that I know works and yet it didn't on the 1st laptop. It appears that the male section which is inside the...
No, you can remove the battery, if the AC adapter is supplying power to the laptop.
Since _two_ AC adapters do not work, it's most-likely that the problem is your laptop.
Take the laptop to a qualified technician; they can try to disassemble the laptop, and fix the "bad" connector.
Apr 18, 2010 | Audio Players & Recorders
GERICOM laptop power charger - Liteon model PA-1900-005
yes this is common rating for laptop any laptop adapter can be replaced see the output voltage and current of another adapter matching . if connector is not matching then solder the matching connector
Mar 03, 2010 | Computers & Internet
Inspiron 1720 is shorting ac adapter? laptop has
It can be the AC power jack on your laptop. Believe me I have an inspiron myself and this problem is a real pain. However you can easily fix it by un-soldering the old jack, re-soldering the new one in. You can find a replacement on e-bay. If you are not good at soldering,I suggest you take professional assistance. Its a very inexpensive repair.
Oct 24, 2009 | Dell Inspiron 1720 Notebook
How do i fix my power cord for hp pavillian zd 8000 i need to re solder to the board
Just open the charger case (It might be void your warranty!) and re-solder it with a very good lead on your charger PC-Board, please doi it very carefully! If you think you cannot do this, just buy another laptop charger, better buy an "UNIVERSAL laptop charger" that come with several lead-jack and a variable output voltage. Remember, this part is very important, otherwise it will damage your laptop in a whole! GoodLuck!
May 11, 2009 | Computers & Internet
I have a Dell Inspiron B130. I have brought 3 chargers. The computers has to always be pushed in or wiggled around to actually be charging. I think that it is the input prong. It seems to be loose and have...
The problem is not the chargers, it is the power connector on the laptop. Yes it can be fixed, laptop need to be dismantled to get access to this connector and a new one to be soldered in.
If you can't do it yourself the cost of fixing it may be expensive and if the laptop is a fews years old, it might be better putting this money towards a new laptop.
Nov 30, 2008 | Dell Inspiron B130 Notebook
The charger connecting point on my compaq laptop is loose and so the laptop does not alway charge
This is the DC power jack. Some solder points have most likely come undone. If it's in warranty have Compaq fix it for you. If not, you can call around and get the cheapest price you can to fix it. If your handy with a soldering iron and feel comfortable enough to take apart the laptop yourself, we can provide instructions on opening the case. You can purchase a new jack if need be for about $25 - $30. Just remember this most likely the problem. I can't say for sure without looking at it. You may want to take it in to get fixed just be on the safe side. Hope this helped.
Mar 17, 2008 | Computers & Internet
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
