Question about Samsung SpinPoint V80 SV1203N 120 GB ATA-133 Hard Drive
No Hard Drive detected
All of a sudden no hard drive detected. I even putI even pulled it and installed on another machine, same thing. Hard Drive is very quiet did not kick in as they usually do.
Help...............
  • 2 more comments
  • patinvegas Oct 26, 2008
    No not when I cant get on and besides it is not even a year old..................
    Its a Samsung Spinpoint and I am sure warranty is gone but thank you so much
  • Anonymous Oct 26, 2008
    it wont work at all just says no hard drive detected
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    sounds like it ready for hard drive hospice..got it backed up?
    Master:
  • 568 Answers
If you have your important data on it you can try freezing your hard disk drive in a refrigerator in the freezer for may be 24 hours this may help you to detect your hard disk
Posted on Nov 07, 2008
  • 149 Answers
Just probably went out .. defective .. maybe u can contact western digital or seagate whoever made it and they might warrenty it out for you
Posted on Oct 26, 2008
  • matt Stahulak Oct 27, 2008
    never hurts to give them a call u said it was not even a year old right?
I have a Dell 2400 Desktop that all of a sudden won't access the login screen. It powers on then the hard drive makes noise with the green lights blinking but it then says press F1 to continue but
First thing, check to see if the is a floppy disk in the floppy drive, if so removes this disk. If there was no disk in the floppy drive then it may be a hard disk problem.
Check the BIOS to see if the hard disk is detected, if not open the case and re-seat the data cable on the hard drive and also where it connects to the motherboard disk controller.
If it still gives this error message and the BIOS does not detect this hard drive, then the hard drive is probably faulty.
To get the computer operating again, install a new hard drive in your computer and then install Windows on this hard drive plus the computer's device drivers and your programs.
Nov 05, 2012 | Computers & Internet
Tip
No Hard disk detected / boootable device
<span>When the computer/laptop cannot see a boot file/disk on either the hard disk or floppy drive it gives an error message </span>- <span>"No bootable device. Insert boot disk and press any key"</span><span><br /><br />First thing, check to see if the is a floppy disk inthe floppy drive, if so removes this disk.</span><br /><span>If there was no disk in the floppy drive then it maybe a hard disk problem.<br />Check the BIOS to see if the hard disk is detected, if not open the case and re-seat the data cable on the hard drive and also where it connects to the motherboard disk controller.<br />If it still gives this error message and the BIOS does not detect this hard drive, then the hard drive is probably faulty.<br /><br />A further check on the hard drive, remove the hard drive and connect it to an USB hard drive adapter and connect it to a working computer's USB port, if this computer does not detect it as an external storage device then the hard drive is faulty.<br /><br />To get the computer operating again, install a new hard drive in your computer and then install Windows on this hard drive plus the computer's device drivers and your programs.</span>
on Jan 17, 2011 | Computers & Internet
It goes right from the loading screen to this Boot Menu.
It's not showing you even have a hard drive to boot to. If your sure you have a hard drive it may need to be reseated. There is either a cover underneath the laptop or a slide out tray on the side. Unscrew the cover/tray and pull out the hard drive then just put it back in and try to start it. Hope this helps. If not u probably have a dead hard drive. But the computer is still good.
Oct 23, 2012 | Computers & Internet
I have a Lenovo H430 Desktop & i Got a Seagate 3Tb Internal Hard Drive & i can't get the computer to detect the hard drive & everything i have tried & even Seagate tried nothing wo
hi..there...
why your lenovo H430 Desktop cannot detect your internal Hard Drive Seagate 3 TB ..because your Lenovo only support maximum 2TB Internal Hard Drive..
so the best thing to solve your problem is replace your hard drive and use only maximum 2 TB for your internal hard drive..
that's will make your lenovo works again
Aug 24, 2012 | Computers & Internet
I have an emachines e442-v634 w/ Windows 7 Home Premium installed. I tried to remove the bottom cover when the machine stopped working with a blue error screen and, I think a cable or wire got...
I would suggest you check the BIOS if everything is detected properly. Like the hard drive and the memory. If both are working properly and being detected by BIOS properly, then you just might need to install your Windows 7 thru USB. You might need to use a different computer to convert your Win 7 OS DVD to USB installer.
1. Use a different computer w/ DVD 2. Use ISO software to convert the Win7 DVD to ISO 3. Download the converter from this link click here or directly from this link 4. Make sure you have an available USB Flash Disk that has a capacity of 4GB or higher. 5. Once you're done converting the Win7 DVD to an ISO file, use the tool above to convert the ISO file into a USB installer.
This will only work if your hard drive is properly detected. Bootmgr error means 2 things, either the hard drive is not detected or corrupted windows installation.
Hope this helps!
Sep 21, 2011 | Computers & Internet
I want to install a new scsi but when my os windows small business server 2003 it gives me "setup either detected multiple disk in your machine that are indistinguishable or detected raw disk(s). Setup has...
using the ACU (array configuration utility) create a raid 0 with this drive after the hard drive is being formatted and is configured as raid 0 (no redundant) restart the server and the hard drive should be detected as a new logical volume with a assigned letter "D" "E"
ACU
Jul 30, 2010 | HP ProLiant ML370 G3 Server
Hp pavillion dv6915n - no hard drive detected
We do not say that the hard drive is damage maybe the IDE was faulty already. You may open your laptop and check the hard drive. Try to replace the IDE to check if the hard drive is good.
Mar 31, 2010 | HP Pavilion dv6915nr Notebook
Maxtor 3200 was working fine. Suddenly my
Try connecting it to another computer.
If it is not detected, then either the disk-drive "inside" the unit is dead, or the "adapter" (USB-to-Disk-Drive) inside the unit is dead.
If the latter, disassemble the case, remove the disk-drive, and attach it as an "internal" hard-drive to your computer.
Nov 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
All drive not detected
Check your power supply that its working or not. If its working then
Please check all the cable inside your system and then try attaching 1 by 1 i.e. attach first hard disk and than start your machine and see that it is detecting or not.
If its detecting then attach cd-rom and start your machine.
If its not detecting then remove hard disk and attach CD-ROM only.
If CD-ROM is also not detected then there is problem with your cable.
Mar 16, 2009 | ASUS P4V8X-X Motherboard
New 160 gig hard drive, can't load XP on Fujitsu S6210
Insert the new hard drive in your laptop, boot up and go into the BIOS.
Check if the hard disk setting is set to Auto (detect). Check the system configuration and see if it detects the hard disk.
If there is a hard disk diagnostic utility within the BIOS, run it to check the hard disk.
You can also test the hard disk by booting up with a boot floppy disk, run fdisk.exe to see if can display, create a partition, and format the hard drive etc.
If not of this works then it is highly possible that you have a faulty disk controller in your laptop.
Dec 18, 2008 | Fujitsu S6210 Notebook
Samsung SpinPoint V80 SV1203N 120 GB ATA-133 Hard Drive Logo
219 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
