Question about GE CFSP5RKBSS French Door Refrirator
Ge cfsp5rkbb ss water dispenser not working - GE CFSP5RKBSS French Door Refrirator
SOURCE: No water flow
I had the same problem.  The water lines in the freezer door had frozen up.  I defrosted the freezer, and the water flows great now.
Posted on Jan 24, 2009
wheelshot
  • 102 Answers
SOURCE: water dispenser doesn't work on ge hotpoint freezer
Here recently I have run into 2 of these units that do this and have found that the dispenser line is frozen in the freezer door. The way to test this is to remove the kick plate under the doors (It is easiest to open both doors to do this) Disconnect the union in the water line leading to the door by pushing in on the waterline and pulling in on the end of the fitting. When the line is apart, close the doors and push in on the paddle as to fill a cup with water. If you get water out of the line under the door then your line in your door is frozen and you will either need to replace your door or let the unit thaw for 24 hours with the doors open. Cheaper to thaw. If no water comes out under the door when paddle is pressed then you will need to replace the water valve as long as you have 120 volts at the valve when actuated.
Posted on Apr 11, 2009
SOURCE: I replaced the water filter for my GE GSH25JSTA SS
I have had the same problem with the same model several times in the past. It also happens to me within a few days of replacing the water filter.
In my case, I believe the water line in the freezer door has become frozen. I usually let the freezer thaw for a couple of hours, and my water works again.
I have had constant problems with this model. I would recommend trying to sell your fridge now while it's still running, before the real headaches begin (mine has died 2x in the past six months, and I have not even had it for 2.5 years yet). No more GE's in my house.
Posted on Jul 20, 2009
aasc
  • 1606 Answers
SOURCE: RE: GE model #gsh25jsrf ss. The water does not
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
Posted on Nov 01, 2009
aasc
  • 1606 Answers
SOURCE: My GE SS Side by Side Refrigerator is not
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . GE also has a dispensor heater , to help keep this from happening again , if , the water line is frozen . Pt # WR49X10173 .
BB ..... refrigerators are not your AoE .
Posted on Dec 16, 2009
Water dispenser stopped giving water. how do I get water to start coming back out?
have you tried cleaning the filter dispense or replacing it and/or trouble shoot your own refrigerator and then enter your model number
Dec 27, 2014 | GE Refrigerators
Can water/ice dispenser be fixed without replacing door
Go to www.repairclinic.com and enter GSS25SGRSS. With luck, you will be presented with a list of common replacement parts/assemblies and will be able to determine whether the dispenser is available as a separate assembly.
Nov 08, 2017 | GE GSS25SGRSS Side by Side Refrigerator
Frozen water reservoir in GE Eterna refrig model GESL25XGRBS-SS...the water dispenser doesn't work, although the ice dispenser is just fine. We turned off refrig for a few hours and the water dispenser...
According to factory experts, the water line is freezing in the door. There is no easy or cheap solution...they can replace the door for $300 is what I was told. The line is routed in such a way that it is not insulated enough from the cold of the freezer. Take off the bottom fan grill in front, take water line apart and cycle the water. It will pump out but not go through door. Buy a new door or go to the faucet.
Dec 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a 2004 side by side GSH22SGRB SS and the water will not dispense. The valve is working and the reservoir is full. The lock is off. Any suggestions?
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad.
Oct 21, 2009 | GE Profile PSW26P Stainless Steel Side by...
PSS26PSTA SS - Only dispenses crushed ice.
Remove the ice dispenser bucket. You will see a square hole at the back wall with a horizontal rod in it. You should be able to move it up and down with you fingers. If not, it may just be frozen. Warm it with a hair blower and try again. If still no luck, the WR62X58 dispenser solenoid may be burnt out / melted and need to be replaced. It is attached to the metal just above and behind that square hole. The removable tray at the bottom of the dispenser recess is a part number WR17X12133 for a PSS26PSTA SS. Contact any GE servicing dealer or general appliance servicer near you to get one. You can get parts direct from GE also, but the won't be any cheaper, and you may pay more shipping and handling.
Nov 20, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
In operative water dispenser.
I have GE side by side refrigerator - 2004 model GSH25SGRB SS. From the blog I found out the problem is with frozen water line. If I keep the door water would dispense ( thawing). Or if you disconnect at the bottom ( take the grill out and disconnect) the water would dispense.
I placed a call to GE. The service person came. He said GE could fix with a 3 watt heater. He opened the panel. Pasted a heater. It came in a Y shape form. He connected that to the internal wiring. After some time the water started working.
Part $40. Labor for 15 min work = $210. Total = $250.
This is really should be a recall case. No part broken. They had to design a heater to solve this problem. What a rediculus thing is this. I am trying to call GE and ask to refund.
What a cheat GE!!. F them.
Feb 11, 2008 | Refrigerators
GE CFSP5RKBSS French Door Refrirator Logo
125 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
