Question about RCA HD52W59 HDTV Projection Television
I have a RCA model HD52W59, and am replacing the flyback transformer.
How do you get the wires out of the old flyback transformer, so you can install them in the new one. I have tried your web site fixya and it keep sending to post my solution. I want help, I DON'T have any help, I want help.
  • 2 more comments
  • prof64 Nov 02, 2008
    It didn't come out. Took the boot completely off. It got hot at one time so I was thinking it might have melted it tight.
  • prof64 Nov 05, 2008
    Yes it is off of the board.
  • jason May 11, 2010
    the best way is to pry off the face of it where the adjusments ( screen , brightness) are , then you should be able to get to the connections
    but it ( flyback) has to be unsoldered from the board before you can get the face off
    is it out of the board?
    still need help?
    Problem Solver:
  • 9 Answers
Try pulling the boots back and use a twisting/pulling motion.
Posted on Nov 01, 2008
  • coreweave Nov 03, 2008
    The wires will come out. They will get stuck but you will have to use some force to pull it out. Hold onto the flyback transformer while tugging on the wires so you don't disturb the pins or damage the board. If you still cannot remove them, cutting the wires and replacing them would be your other option.
Where is the flybac located in a rca hd52w59
Hello
Flyback transformer other wise called Line output transformer {LOT} is actually a step up transformer, which supplies extra high tension voltages to the guns. It can be locatee on the main printed circuit board. 2_7_2012_5_19_59_pm.jpgJust see the different views of the main board of your RCA TV. You can see the flyback transformer at the left top corner, look like a large black componen; with a ferrite "U" type core goes though it. It is the LOT. Line Output Transformer, otheriwse called as Flyback Transofrmer. OK.
Feb 07, 2012 | RCA Televison & Video
Spraying sound and tv shuts off
the flyback transformer or the Box cap CL031 is arching and will need replacement the flyback is most likley of the two. You can get flyback transformer with instructions from www.tvrepairworld.com
Jan 18, 2012 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 flyback transformer
your model uses the 270125 flyback if both wires are red. If one is red and the other black then you have the 259296 flyback.
Mar 21, 2010 | RCA HD52W59 HDTV Projection Television
Top and bottom of picture is bowed.Images are doubled and letters
one more question , could or can you access the convergence menu ?
the fuse will be next to the flyback transformer ( high voltage ) and ill look tan in color( 3 of them )
also the flyback pins have to be resoldered also
Feb 03, 2009 | RCA HD52W59 HDTV Projection Television
Replacing the flyback
If your model is a HD52W59 the wires are part of the new transformer and have to be changed at the tripler and screen control block
Jan 21, 2009 | RCA HD52W59 HDTV Projection Television
RCA ITC 222 Deflection board
DONT DO THIS. these wire carry several thosand volts. depending on the type of flybacks the wires can be removed at the other end of the wire. i tell you what i do at the shop very carefully remove unsolder the flyback.
Dec 07, 2008 | RCA HD52W59 HDTV Projection Television
I am replacing the flyback transformer
You should post here pictures of old transformer and point out what wire you want to remove, then I can give you an idea what to do as flyback transformer is not in front of me.
Oct 27, 2008 | RCA HD52W59 HDTV Projection Television
Blinking light ptoo ing sound
small wire goes in the small hole on top of flyback
hv wire goes in the hole on the left of that hole
Jun 29, 2008 | RCA HD52W59 HDTV Projection Television
Rca hd52w59 convergence problem
there is a special fuse on the power deflection board. when blown this causes the processor to think it a crt tv. The fuse calle fl231 is a small brown rectangular fuse in the middle of 3 just like it next to the flyback transformer the big black thing with the large red wire comeing out. ussally it blows because the solder connections on the flyback. WARNING high voltages are generated by flyback. be careful please
Dec 27, 2007 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
369 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
