FixYa.com
Tags:
Jensen JHT525 System
Loud humming noise from subwoofer (by 6 users)
posted by Kenneth on Aug 23, 2006
When I turn the sub on it makes this loud humming like noise, all other speakers work fine, I opened the sub up and everything seems fine, nothing blown, any ideas?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
5 Other Users Have The Same Problem
Comment by Guest, posted on Jul 12, 2008
Experiencing low level audible hum - MOST notable when the PC is "off" and the speakers are left "on."
Comment by jcarterd2, posted on Jul 03, 2008
hum when power cable connected & power is turned off, blows fuse
worked for over 5 years, have made no changes to connection or cables, one day just started to hum.
Using ONKYO TX-SR500 AV Receiver, which has digial decording, subwoofer pre out connection, no speakers connected to subwoofer
Change electrical outlet, disconnected line-in cable (RCA), changed fuse,
reconnected power cable, unit powered off, still hummed, powered on, fuse blown
Is this repairable or fried?
Comment by Guest, posted on Jan 08, 2008
Using Yamaha DSP-AZ1 and IXOS prof cabling, there is still a humming noise raising the subwoofer's volume control. How can I be sure whether the amp of 78AS is working correctly?
Comment by Guest, posted on Nov 15, 2007
I have the same problem with the bassbite iii subwoofer that comes with the KLH HTA-4100 system. It has the humming noise no matter what I do or how high or low the volume control is. The sub worked before I moved and when I got to the new place i plugged it in and it just hums. My cables are all good and the same ones I used when it worked so I dont think it could be that. Opened it up looks good. Im going to try a much better branded cble 1st then im going to start replacing parts in the sub. Im an electrical technician so I should be able to get somewhere with it. Ill be sure to post again if i get any progress. _J
Comment by Jaejr51, posted on Nov 10, 2007
I have a Harmon Kardon HKTS14 subwoofer with the same problem, although I also sometimes get a screeching "fax" like sound from it as well. I am using the original cables to connect from the receiver (AS630), which are color coded purple. Should I try new cables, since these should be shielded?
JE
Best Solution
posted on Nov 12, 2006
Helpful (85)
dannydan
Rank:Apprentice Apprentice
Rating: 76%, 37 votes
You could either be using poor quality input cables or they may be damaged and hence pick up interference. I suggest you check your input cables for damage.
Use shielded cables from your source to your subwoofer. Your cables might be picking up this interference and transmitting them to the subwoofer amp.
This interference can be caused by other equipment (tvs, radios etc) emitting electromagnetic radiotionand Because the subwoofer has its own amp/powered (I hope I'm right in your case), the input cable might be picking up this interference and sending them to the amp alongside the music signal.
The amp then does what it knows best:- amplify the input signal. Which in this case is full of interference. Hence the humming.
Use good quality shielded cables.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jan 15, 2008
Thanks for Trying (70)
Guest
Guest
Rating: 0%, 0 votes
I work for Cerwin Vega and normally when this happens is ground looping problems, for the solution we would suggest our customers to purchase an adapter from a three prong to a two prong.
Solution #3
posted on Aug 29, 2007
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
I had same problem caused by a poorly grounded cable TV line. Try disconnecting the coax cable (the one which comes in from outside) from the back of your cable TV converter box. If the problem goes away, you probably have poorly grounded cable TV service. A $50 ground isolater filter will fix this (see model Model VRD-1FF at: http://www.jensen-transformers.com/iso_v...
I installed one recently and it works as promised... No degradation to digital cable/data service and the annoying hum is gone.
Solution #4
posted on May 02, 2007
Not Rated (0)
Woodthegr8
Rating: 0%, 0 votes
Hopefully your cables aren't damaged, because they're attached to the unit and very difficult to replace. I just had this same problem, and after reading the first suggestion checked my cables for damage and found nothing. However, a closer look at the back of my computer showed that the audio cable running between my sound card and my amp was only halfway in. After correcting the problem, the feedback disappeared. Good luck.
Solution #5
posted on Apr 15, 2007
Not Rated (0)
dsom
Rank:Wiz Wiz
Rating: 80%, 63 votes
I had the same problem with the relevant subwoofer. The problem could simply be about the placement of the rest of the speakers connected to your amplifier. You have to be able to place your fronts and rears in a position that doesn't cause any coincidence. The best placement for a 5.1 system is that fronts are towards you with the subwoofer in between, or next to the front-left, and the rears are just next to your seat. If you use a 2.1 (stereo with a subwoofer), it needs some fine-tuning on the subwoofer and the amplifier as well. I hardly stopped that irritating noise. Firstly, I set the frequency of the subwoofer to 100Hz; then turned the volume down to the quarter level. After all those, I turned up my amplifier's "subwoofer volume leveler" to maximum. I solved the problem. try it out..
Solution #6
posted on Jan 27, 2007
Not Rated (0)
peekay
Rating: 100%, 2 votes
if it is a powered sub you should lift the ground. you can do this by adding a three prong to two prong adapter. you know, like when you go to plug something in and the cord your plugging in has three prongs and the outlet your plugging in to only has two. it doesn't have the hole for the ground so you go get a little grey adapter that has three holes on one side and two prongs or tabs on the other.if that doesn't take the hum out (actually, is keeping the hum from getting in) you have a problem with the amplifier.
Solution #7
posted on Jan 19, 2007
Not Rated (0)
Gtyler
Rating: 70%, 1 votes
Hopfully you fixed your problem by now but just in case, in addition to what dannydan suggested you may also want to make sure you don't have a ground loop from the ac supply line(120VAC), try relocating the plug to a sepearte outlet on a seperate circuit if possible, or ensure your input cables are not runing next to some ac lines. The hum is usally caused by the EMI (Electromagnet Interference) from your ac lines. this is the 60 cycle hum we get from the 120 Volts 60 Hz lines.
Solution #8
posted on Jan 01, 2007
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
It also depends on where you have placed the base unit - if it is too close to the amplifier or other electrical devices, this will cause humming. Try moving it atleast a couple of feet away from any electrical devices.
This Problem Also Relates To: Jensen AS-2 Speaker Jensen JHT525 System Jensen JPS12 Subwoofer Kenwood KVS-64 Speaker Sony SA-FT1H TV Speakers Sony SA-VE325 System Sony SA-W305 Subwoofer
Can you Help with these Home Theater Speakers and Subwoofers problems?
Need to replace one of the 5.25
I bought a used Boston... Answer This...
sts96 speaker wire
speaker wire's not long enough Answer This...
turning off the speakers on my...
Iwant to turn off my speakers... Answer This...
Popping sound
Sub has an auto off when not... Answer This...
jht525- receiver necessary?
I currently have a JHT525... Answer This...
Repair Service
Find Home Theater Spe. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
