Question about Vtech Audio Players & Recorders
KidiJamz Studio microphone wiring
Need wiring schematic or guide for the 4 microphone solder points correlating with the 4 microphone cable wires (1 black, 1 red, 1 tan/orange(?), 1 ground wire) for the Vtech KidiJamz Studio microphone cable (kids pulled the wire out of the back of the microphone so I can't tell which of the 4 wires went to which of the 4 solder contact points on the IC inside the microphone). Much thanks, -rb
Posted on Feb 10, 2013
  • Joseph
    Joseph Jan 07, 2014
    mine was 1=Blue --- 2=Brown/Tan --- 3=Shield --- 4=Red
  • Joseph
    Joseph Jan 07, 2014
    It was really helpful but I had a little trouble seeing the photo. Here is a labeled version
The one I fixed was:
1 = Blue
2= Brown/Tan
3= Shield
4=Red
I had to strip the plastic so that I could install the wire into the holding place with the screw. Then I soldered after the main wire was in place.
Posted on Jan 07, 2014
rix20601
  • 24 Answers
SOURCE: gemini djm-1 gooseneck microphone repair question
No problem! 2=RED 3=Black 1=White The wire without a color is ground. It can be soldered to pin 1 if necessary. Hope this helps.
Posted on Nov 16, 2006
RCtech
  • 55 Answers
SOURCE: astatic noise canceling microphone to 4 pin cobra 29 ltd classic
According to the astatic wiring hand book it is not used. I would leave it terminated but long enough that if you find your having noise when you receive you could still ground it. I'm pretty sure you don't need it.
Goodluck
Rob
Posted on Dec 07, 2008
SOURCE: Astatic 636l microphone Cobra 29ltd classic
pin 1= sh & bl
pin 2= wh
pin 3= red
pin 4= blk
yellow = not used or put on pin 4
Posted on Dec 18, 2008
SOURCE: Astatic 636L Wiring
how do I wire a d 104 to a keen wood tm 221a radio
Posted on Jan 25, 2009
robotek
  • 1512 Answers
SOURCE: wires in the microphone at the point where you
There are many standards of microphone connectivity with 3 pin XLR (cannon) style plugs. It depends on where in the world you are as to the favoured standard,
Your microphone usesthe following::
Pin
1 ground (white) 2 +ve or hot (red) 3 -ve or return (black)
Another way to work out what wires connect to what, is to remove the cover of one of your XLR-XLR microphone cables exposing the connections it favours, plug the connector into the mics scoket , and use the connections to the cable guide you in resoldering the connections back on.
The same connections can be veiwed in the user manual here
Please rate this solution. Cheers
regards robotek
Posted on Jul 15, 2009
I need a wiring diagram for the mic end of a audio technica at822 the wires all broke at the solder points
This is the only thing I could find online:
1 - shield
2 - left (hot)
3 - left
4 - right (hot)
5 - right
Apr 09, 2015 | Audio Technica Audio Players & Recorders
I'm trying to wire a cobra for wire microphone to
If you look at the back of the Dyn plug from left to right the solder points are 1-4-2-5-3 and you will need to know which wire on your Cobra (or any other) is the transmit and receive wires. You can use a impedance/ohm meter to find them. The code for wiring up a generic mic to this radio is 4-Audio,1-Shield,2-N/C,5-Receive, 3-Transmit
Sep 16, 2014 | Radio Communications
Keeps saying turn off message with new batteries
Ours had the same issue. I took the Vtech Kidijamz apart. The power button has its own little board. I unscrewed that. It connects to the next board via two wires. I reflowed the solder for all the connections for those two wires (four solder points total). Issue fixed. FYI: reflowing solder just means heating each solder point (with a soldering iron) until the solder gets soft and then removing the iron to let the solder cool and thus harden.
Oct 05, 2013 | Vtech KidiJamz Studio
Vtech KidiJamz keyboard: keeps saying turn off message (Let's jam again later..) and then turning off even with new batteries in place.
When soldering the wires back to the prongs where the mic cable is inserted, which prong does the red wire go to and which prong does the blue wire go to?
hi...soldering of wire terminals for your microphone is not that complicated even you switch the wires it would not do any damage at all..as long as the voice coil is good and has reading of 400-550 ohms..it would still works... TIPS: some voice coil even when has a resistance reading and due to long usage may have lower volume even you adjust the amps..if this is your problem better to buy new voice coil...please rate and vote..good day
Feb 18, 2011 | Shure SM58 Professional Microphone
The wiring for the wired SM58 microphone is in the User Guide. The User Guide can be downloaded from the Shure website.
May 21, 2010 | Shure SM58 Professional Microphone
I have a Cobra 21- 23 channel CB and the wires pulled out of the plug. The mike wire has red,yellow black,blue,whiteand a ground. My plug has only four prongs to solder to. What four colors do I use?
Hello there
Here is the diagram for you
Cobra 29LTD, 29LTD ST, 29WX ST
Documentation Project
CBTricks.com
TIPS:
You need to have Acrobat Reader version 5 or newer installed to view the files with pdf_1.gif icon.
If the files with jpg.gif or gif.gif icon will not display see the Site FAQ for help on printing, viewing and using this information.
Click Picture to See Close-up
DIAGRAMS
Page 1 to 11
Page 12 to 34
29LTD
29 LTD Classic Schematic Diagram pdf_1.gif(Courtesy of Rick Jackson)
Mic Wiring
Stock
1- Shield
2- Audio
3- Transmit
4- Receive
Astatic (4 wire)
1- Shield
2- White
3- Red
4- Black
Astatic (6 wire)
1- Shield & Blue
2- White
3- Red
4- Black
Yellow NC
Daiwa EM-500
Cobra CA Series
1- Shield & Black
2- Red
3- White
4- Blue
Galaxy DC-521S (4 wire)
1- Shield
2- Yellow
3- Red
4- Black
Galaxy CB-660EI
1- Shield & Black
2- White
3- Red
4- Blue
Sadelta
1- Shield
2- White
3- Brown
4- Green
Turner
1- Shield & Red
2- White
3- Blue
4- Black
Yellow NC
Nov 17, 2009 | Cobra 29 LTD CB Radio
Wires in the microphone at the point where you connect to the lead have come appart and i need to solder them back on, Black, red and white wires. Which in which order do i solder them onto the connecter...
Pin
regards robotek
Jul 15, 2009 | Behringer XM1800S Professional Microphone
Recently I dropped my Beta 87A mic and the 2 wires that connect the mic itself came disconnected from the mic. I want to know how to resolder the mic.Thanks in advance. Norbert
I take it they are the wires to the diaphragm not the cable (XLR) connector.Be very carefull when soldering the wires back on. A small solder iron with a pointed tip works best. The positve terminal should be marked with a small red dot.The red wire goes there and the black on the negative. Be carefull and take your time.
Apr 27, 2009 | Shure Beta 87A Microphone Microphone
Cable break!
1. clear cut off the damaged section,
2..solder or ideally wire-wound the connections,
3. insulate the wires with plastic tape, or plastic sheet,
4. shield the wires with aluminum foils,
5. wrap up the outer.
6. done.
good luck
pc-cook
Nov 19, 2007 | Fishman Full Circle Upright Bass Pickup...
518 people viewed this question
Top Vtech Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Vtech Audio Player and Recorder Expert? Answer questions, earn points and help others
