Question about Refrigerators
GE REFRIGERATOR GFSL6KEXCLS FLASHING 88-82 TRIED TO RESET AND FAILED. REFRIGERATOR RUNS . HOW DO YOU RESOLVE?
AFTER CHANGING LEFT SIDE FRENCH DOOR, (WITHOUT WATER) FOLLOWING OWNERS MANUAL TO REPLACE THE DOOR WE HAVE A CODE ON THE PANEL 88 82 WE CAN NOT RESET THE INTERNAL CONTROL SETTINGS PER MANUAL. ANY SUGGESTIONS BEFORE WE CALL THE REPAIR GUY. IT HAS BEEN 15 HOURS AND THE UNIT SEEMS TO BE RUNNING AND KEEPING ITEMS CHILLED AND FROZEN.
peyton32034
  • 410 Answers
SOURCE: GE ESS25XGMC WW Side by Side
its possible that your water tank has frozen up, try turning the refrig off and leave the doors open for about 10-15 mins and try it again. if that works just reset temp controls a little lower..
Posted on Dec 16, 2007
erpaalai
  • 999 Answers
SOURCE: Ge Profile Stainless Steel Refrigerator panel replacement
You can replace the doors but you will think you bought a new frig when you see what they cost. Most come as an assembly and are very expensive.
Eric
Posted on Jun 29, 2009
robmattie
SOURCE: GE French Door Frig control panel blinking temp #s
I had a very similar problem with our GE refrigerator. The main control board looked to be the culprit. I took out the board and did a visual inspection. Upon inspection I discovered that the (2) 470 micro farad capacitors were blown. I checked the power diode near these and it was still ok. I went to Radio Shack and picked up two 470 micro farad - 35V capacitors for and grand total of $2.60 and resoldered them myself. The refrigerator has been running great since. If you want to know more details email me and I will be happy to let you know what I know. I didn't want to pay $100 for a GE guy to replace a board either!
Posted on Aug 10, 2009
projdoc
  • 2237 Answers
SOURCE: Water build up on inside of fridge door of ge french door fridge
humid air in the house. any time you open the fridge, house air is sucked in. when you close it, the fridge cools the air and moisture from the warm air condenses on any cold surface. also check to see if there is a gap in the seal.
Posted on Aug 26, 2009
SOURCE: Water Dispenser not working
If the ice maker is working, and no water is coming out, the water line may be frozen.  This happened to me yesterday, and I followed the advice on ehow.com.  It worked like a charm! Take a hair dryer, and blow hot air up into the dispenser tube, holding the hair dryer about 8-10 inches away.  After about 5 minutes or so, a tiny chip of ice and a couple of drops may pop out.  Fill up a couple of glasses of water to flush it out, and you should be good!
Posted on Sep 26, 2009
Why does my refrigerator short out when I open the left door?
Something in the left door is shorting to ground. The constant movement of the door has worn thru a wire/wire bundle and that wire is touching metal.
Dec 07, 2017 | LG LRFD22850 Bottom Freezer Refrigerator...
GE refrigerator pfss6pkwbss flashing 88 82 after a brief power outage...any info on how to resolve? Tried unplugging for about 2 minutes, and this did not solve it. buttons on door panel do not work at...
To reset the panel display, press and hold the top left (Energy Saver) and top right (Alarm) buttons at the same time for about 10 seconds--the panel will beep and reset.
The panel will require a reset whenever the power is interrupted..
Feb 03, 2011 | Refrigerators
Plastic latch on left french door broken
Go to www.partselect.com put your model number in, click on the diagram. For the door. Should be part #PS1016086
/uploads/images/9_1_2014_3_03_11_am.png
Jan 30, 2011 | GE Profile PFS22SBSS Bottom Freezer French...
Dispense panel blinking 82-88 on right - left - steady 88 - unable to reset - water only dispensing
Hold Energy Button & Light Button for 10 seconds!! No repairs needed. Solution is not in manual.
Sep 19, 2009 | GE Refrigerators
Fridge works but doesn't isn't cooling
I will help but you need to confirm your model number. Is your model the one listed above your post? Let me know, Sea Breeze
Jun 19, 2009 | GE Profile PFS22SBSS Bottom Freezer French...
Freezer never cools consistently and compressor never goes off
I am posting this for the sake of curiosity. I want to know if it gets resolved.
Jun 18, 2009 | GE Profile PFS22SBSS Bottom Freezer French...
GE PFS22MISBBB freezer not cold enough. Temp won't reset.
replace the fan as quickly as possible it may be shorting and causing damage to your control board,
Mar 30, 2008 | GE PFS22SBSSS Stainless Steel French Door...
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
