Question about Cameras
Kodak 260 digital camera wont power up with batteries. Works OK with AC adapter
  • 928 Answers
It is possible that the battery contacts are dirty or the battery that you are using is already defective. You can try to clean the battery contacts and if that does not work try to replace the battery.
Posted on Oct 26, 2008
Will the battery recharge inside the camera while it is plugged into a power source?
Kodak EasyShare Z650 zoom digital cameraUser guide
Battery charging options Visit www.kodak.com/go/z650accessories for:
Kodak EasyShare camera dock series 3 - powers your camera, transfers pictures, and charges the Kodak Ni-MH rechargeable digital camera battery.
Kodak EasyShare printer dock series 3 - powers your camera, makes 4 x 6-in. (10 x 15 cm) prints with or without a computer, transfers pictures, and charges the Kodak Ni-MH rechargeable digital camera battery.
Kodak 3-volt AC adapter - powers your camera.
IMPORTANT: Do not use the AC adapter included with the Kodak EasyShare camera dock or printer dock to power your camera.
Mar 22, 2016 | Kodak EasyShare Z650 Digital Camera
WHEN camera is turned on the lens goes out and back continuously
Check if the lens can come out completely. Just a little obstruction, can cause the lens to move back to a "safe" position. Did you check the battery, if it is still ok? Does the display give any warning?
Do you have a Kodak 3-volt AC adapter (sold separately)? You could connect the adapter and look if the camera will work then.
To make sure the battery is ok, you could take a multimeter and check the voltage of the battery. The voltage should be a little (few tenths of a volt) above the voltage on the battery, when measured with a multimeter.
Nov 04, 2013 | Kodak EasyShare C330 Digital Camera
My kodak easyshare wont turn on anymore and it worked fine the other week ive tried putting new batteries in it and it still wont turn on i dont kno what to do or how to fix it and its a great camera ive...
Try removing the batteries then either plugging your camera in with the AC adapter or the docking station. Try cleaning the contacts from the battery and the battery compartment of the camera.If your camera works with either one of these then you have a problem with either the batteries or the battery contacts. If your camera doesn't work with the AC adapter then you will have to send the camera in for repair.
Oct 01, 2010 | Kodak EasyShare C180 Digital Camera
My Kodak Easyshare V1233 will only power up when plugged into the wall charger. Even after staying on the charger it will not power on unless plugged in.
Kodak has 3 types of charger that can be connected to a wall socket
USB AC Adapter - is especially useful when traveling, away from your computer, or just plain on-the-go. Connect your camera's USB cable to the adapter and plug it into a wall outlet to conveniently charge your camera.
5V AC Adapter - Provides in-camera charging for all KODAK EASYSHARE M and V Series Digital Cameras
Input: AC 100-240 V 50/60 Hz Output : DC 5.0 V
3V AC Adapter - Provides direct power to your camera but it will not charge the camera battery
Input: AC 100-240 V 50/60 Hz Output : DC 3.0 V
* You need to check the type of adapter your using. If your using the 5V AC adapter or USB adapter and the camera won't charge the battery contact kodak support line 1 800 235 6325 (23KODAK) for possible repair.
Nov 16, 2009 | Kodak Easyshare V1233 12.1MP Digital...
Not turning on kodak 12mp v1253
Your camera is only compatible with: 5V AC adapter with power cord(s) for in-camera battery charging
Unfortunantly If you used 12V the repair will be OoW
If your cam use manufactors rechargeble batt.:
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 12, 2009 | Kodak Easyshare C182 12MP Digital Camera
Kodak v803 wont turn on
i had the same problem, if you try to turn the lens in as if you turning a dile, the lens will go back in manually once you have the lens completly in again, as if the camera is switched off, then turn the camera back on at the power button and the camera will operate as normal, this worked for me i hope it works for you too.
Jul 28, 2009 | Kodak V803 Digital Camera
Zoom wont work
double-check the battery first, as zoom needs more power.
if battery is ok then there is possibility of loose connection/ dry solder inside or some component gone faulty.
contact your vendor or kodak support if still in warranty.
May 31, 2009 | Kodak EasyShare C913 Digital Camera
Kodak Camera V610 easy share
Hi!
This is what I need you to try..
If you're using a 5v ac adapter to charge the camera's battery - please hook it to the camera WITHOUT THE BATTERY in it. The 5v ac adapter can be an alternative power supply.
Turn on the camera - check if it would do the same thing - like lighting up, making a noise (attempting to extend the lens) and closes. If it does, the camera needs to be sent in for repair.
visit www.kodak.com/go/itg to arrange repair
If you are using a photoframe dock2 or camera dock series 3 to recharge the camera's batt - use its 5v ac adapter. It will work with the cam. Make sure, the batt is not in it to check the cam's condition, isolating the possible interference of the battery.
If the camera works fine - when the AC adapter is attached, no battery in it - consider buying a new battery.
V610 is a very nice camera, but it was manufactured in 2006. If you have not replaced the battery yet, it might just need to be replaced. Even Li-ion rechargeable batteries wear out eventually - it can only last up to 300 charging cycles.
If you're using a batt that is less than a year old, the cam might just need to be sent in for service.
Nov 24, 2008 | Kodak EasyShare V610 Digital Camera
Won't go on
Hey ghgyu,
I would first make sure you have the batteries installed correctly. If you are using a camera dock or you have an AC adapter cord I would try removing the batteries and try turning the camera on while connected to the camera dock or plugged into an outlet with the AC adapter cord. If the camera works this way I would then try cleaning the battery contacts with a soft cloth or an eraser. If none of this works I would have the camera looked at by an authorized service technician. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 09, 2008 | Kodak EasyShare DX6440 Digital Camera
Error E11 with DC4800 camera
This error "may" be associated with a battery problem. Is it possible that the battery is not charging properly.
Other things to try are as follows
1. Connect the camera to the AC adapter or insert onto the Camera Dock and press the Power button on the camera
2.
  • Remove all sources of power (batteries and AC Adapter) from the camera.
  • Remove the Kodak Picture Card or Compactflash Card.
  • Wait a few seconds.
  • Press the Power button twice.
  • Connect the appropriate Kodak AC Adapter to the camera.
NOTE: If you don't have the correct AC adapter, insert a set of fresh or fully charged batteries, according to the User's Guide.
3. The COMPACTFLASH Card could be corrupt. Reformat the card using a card reader or a PCMCIA card adapter in a notebook computer. ***Remember, reformatting erases all information from the card***
4. Try a different CF card as I have seen them fail causling errors.
Jul 01, 2008 | Kodak Cameras
Cameras Logo
42 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
