IBM Selectric II bell doesn't work - Office Equipment & Supplies
  • 3594 Answers
SOURCE: Correcting IBM Selectric II Typewritter correcton ribbon won't engage
I'll try this again. On IBM Selectric correction you must press the correction kry then press the letter you are trying to correct.
DickyO
Posted on May 19, 2008
  • 3594 Answers
SOURCE: IBM Selectric II
R152
Sounds like you have a broken torquo limiter tension spring you should have it professionly serviced.
DickyO
Posted on Jul 11, 2008
JayBlair
  • 328 Answers
SOURCE: return key is stuck
Need more info. Many different possibilities.
Posted on Aug 12, 2008
JUSTOLDJIM
  • 453 Answers
SOURCE: Ribbon not advancing on Selectric II typewriter
Yoy can also check that the ribbon driver (the spicked post) is making contact with the ribbon the sometimes get sticky and dont close on the ribbon or close very slowley.
Posted on Nov 19, 2008
  • 3594 Answers
SOURCE: How to change the ribbon on an IBM selectric II
If this is acorrecting T/W there is ared lever to the rt. of the ribbon rotate it to the front of the ribbon, pull the old ribbon up and off, drop the new ribbon on the ribbon deck, thread the ribbon to the left of the shock wire right where it comes out of the cassette, thread through the lift guides on either side of the element, turn the knob ccw to take up the slack, check to be sure the ribbon is not folded or twisted, move the red lever back.
DickyO
Posted on Apr 30, 2009
Recommendation for IBM Repair Company
I Googled Typewriter repair Washington DC and got 4. I have no idea what they charge.
DickyO
Apr 02, 2014 | IBM Correcting Selectric II
IBM Selectric II jammed
The lubricants dryp over the years. Try spraying everything with WD40 you can't hurt it.
DickyO
Feb 23, 2013 | IBM Correcting Selectric II
On my ibm selectric II, the ball element is stuck and the cap came off. How do I get the ball off the post?
Take a razor blade and slide it under the remainderof the cap cut the cap off there are 5 connections, after removing the cap you will find a spring retainer pull it off.
DickyO
Feb 01, 2013 | IBM Correcting Selectric II
I have an IBM Selectric II. It types but does
The tab tensioner on the R. side is probably broken, not a bad job but you have to know how.
DickyO
Sep 12, 2009 | IBM Office Equipment & Supplies
IBM Selectric II right margin won't hold carriage
If the carrier stops but no bell the bell striker is brobably gummed up. It is located inside the case just above the tab set key, if you can get to it some WD40 should free it up.
DickyO
Jul 26, 2009 | IBM Office Equipment & Supplies
IBM Correcting Selectric II; correction ribbon frozen in front of typing ribbon.
Move the grey lever on the R. side of the carrier to the R. and remove correction tape, try the machine, if it seems to work OK install a new correction tape.
DickyO
May 28, 2009 | IBM Wheelwriter 30 Typewriter
IBM Selectric II problem
Yes, I did bring a small screwdriver from home and removed the ball. Thank you for your assistance.
Feb 05, 2009 | IBM Wheelwriter 30 Typewriter
IBM Selectric II
R152
DickyO
Jul 07, 2008 | Office Equipment & Supplies
IBM selectric I...88 charter type balls
All the selectric I & II's take the same elements the sel III uses a 96 char. one that is printed in yellow that isn't compatable.
DickyO
Jul 06, 2008 | IBM Wheelwriter 30 Typewriter
Selectric I and II type elements are identical (88 char) where Selectric III uses a different element (96 char). The 88 character element will have white lettering and the 96 character element will have yellow. Directly underneath the lift-up tab to remove the element will be a 3-digit number. That's the last 3 digits of the element's part number, which will be preceeded by 1167 for 88 character, or 1352 or 96 character. For example, if you have a '052" stamped on the element, and it's an 88 character style, the P/N will be 1167052.
The correcting mechanism is an intricate additional function of the backspace function. To test it/adjust it/or repair it requires the machine be hand-cycled using a hand cycle wheel which is screwed into the right hand side operational shaft. It's unlikely that an un-trained party would be successful repairing this..
May 15, 2008 | IBM Wheelwriter 30 Typewriter
52 people viewed this question
jasbo
jasbo
