Question about Music
I want to restore factory settings for the Korg PA 80
I purchased a used keyboard without knowing the setting were changed from English to another language and the sounds are different from the original factory settings.They are sounds I don't use for my type of playing.
  • 5603 Answers
SOURCE: korg pa-50 no sound from right speaker but has sound from left
Several things to check:
If the speakers are cut off when externaal cables are connected to line outs, possibly the jack sensing switch for the right channel thinks that a plug is in there... you might cycle one in and out to see if that might fix.
Another thing is they LIKELY have a PAN control setting and it might be set full left. The external MP3 would NOT be under PAN control, only the keyboard voices would be affected by it.
Posted on Feb 01, 2010
  • 5603 Answers
SOURCE: I am trying to get the LED darker so I can see it
Try as you might, there doesn't seem to be a contrast control on this unit.
Things to try:
Shielding from light.
Polarizer similar to those used for privacy on computer screens.
Try a color filter, possibly orange.
Maybe a good old umbrella as silly as it sounds... there just isn't any way to darken the display.
The display by the way is NOT and LED, but a LCD on this unit.
Posted on May 15, 2010
  • 1138 Answers
SOURCE: hi i im trying to
Your answer is here:http://www.korgpa.com/pa_root/en/products/pa800_soft.html Look under Utilities.
Posted on Oct 13, 2010
cosmin_bcr
SOURCE: Hi, I have korg
Korg pa 800 = poor quality product (I have the same problem) ,pa 2x it's better.
Posted on Oct 06, 2011
SOURCE: hello there how can i
press knob 1 and 2 and rec at the same time , then power on , then knob bank D , power off and on ,,,,, ready
Greetings Gerrie ( Holland )
Posted on Jan 31, 2012
I have a korg n1 and when I turn it on the display screen comes on but no words show up on it I was wondering how to fix it
It sounds like your ROM battery, which the ROM contains and stores the patches for the keyboard, has gone completely dead and your keyboard is dead in the water. However, if you can get a MIDI to USB converter and get the battery changed, then you can reload the patches back onto the keyboard.
I have worked on a Korg M1 Workstation and have had to replace the battery(CR2032) and then had to run a program called "MIDI-OX" which also gave me access to the patches needed in order to restore the keyboard to factory patch settings.
http://www.midiox.com/
Take a look at this AFTER you have gotten the battery replaced. I will tell you that replacing most batteries is a very intricate job as, the bottom of the keyboard has to be removed, as well as a lot of the internal boards. I had to draw a diagram and mark certain pieces so I would know where they went and in what order they have to be re-attached. My advice is take it to someone who works on electronics unless you want to DIY (not recommended) to get the battery replaced.
Hope this helps.
Apr 05, 2016 | Korg Music
My synth wont load when I power it on. can anyone help?
I suggest a hard reboot / initialize. Istructions are in your manual or on the Korg website
Jun 09, 2015 | Korg Pa800 Synthesizer
How to reset pa 50
The manual should the factory re-initialization procedure. If not contact Korg customer support
Dec 10, 2014 | Korg Pa50 Professional Arranger Keyboard...
Korg pa 800 gone dark
Sounds like your keyboard screen is going bad, You need to contact Korg and order one, you can do it yourself or they have authorized repair shop around your house.
Good luck
Jun 10, 2014 | Korg Pa800 Synthesizer
I have a korg pa 80 it have not sound
Initialization: N/A
Preload: Disk Load (6 Disk set available from korgpa.com)
ROM Check: Given on power up.
http://www.sweetwater.com/sweetcare/articles/initialize-reset-preload-korg-pa80-60
Apr 10, 2014 | Korg 37 MINI-KEY 8-VOICE...
I can`t load the OS in my KORG PA 80. No way to make it work. I think than the problem is the mother board.
Have you tried it with batteries? Are you sure the power supply is working correctly? It should not need the OS to operate as a keyboard disconnected from the computer.
The cable connection is just a MIDI cable that uses opto-isolators so the 2 items are electrically isolated from each other. The software driver for the Korg should load without problem. The Korg program itself may be looking for inputs that are not there when the keyboard is off and the program itself reaches a stop command.
If the PA80 will not work on just the power supply- the power supply can be the fault- it has an internal fuse. Finding a similar supply with the same coaxial plug wired the same polarity is the way to test it if the battery option is not available.
Mar 29, 2012 | Music
Music Logo
842 people viewed this question
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
