Question about Admiral AW22 Top Load Washer
Admiral washer is doing a lot of vibrating...it is level
Admiral washer started vibrating , it is level and a little over 1 year old
    Scholar:
  • 116 Answers
Possibly a worn drive belt on the underside of the machine, causing the drum not to get to full speed, clothes will be wetter after sping plus vibrates heavily - replace belt.
Tilt machine back for access to underside, simply pull belt off and replace, tension is automatic on motor.
Posted on Nov 09, 2008
My admiral washer does not work on wash cycle. It will rinse and spin on any cycle but wash
hi Marilyn.
this is what i have found but not sure if this will help you out,if not go to the link at the bottom and see if it helps you out.
Step 1
Make sure the washer's cord is plugged in to a functioning outlet if the Admiral washer won't fill with water. Check your circuit breaker to make sure the power is on and reset it if necessary. Reset the dial and start the washer again. Turn both of the washer's faucets on to full power. Untangle any inlet hoses to remove clogs. If this doesn't work, your hose filter screens could be clogged. Disconnect the hoses from the washer and clean the screens of any residue.
Step 2
Close the washer's lid completely if the Admiral washer will not agitate. The washer will not start if the lid is open. Restart the washer by setting the control dial to the desired cycle. Momentary pauses during cycles can be expected. You may need to wait a minute or two to see if the washer starts. Check the circuit breaker to make sure the washer is getting power. Reset the circuit breaker if necessary.
Step 3
Check and reset the circuit breaker as above if the Admiral washer will not spin or drain. Untangle any of the washer's hoses to allow water into the machine. Check your drains for clogs that may be preventing water to move into the washing machine. Close the lid and restart the washer. The washer will not start if the lid is not completely closed. If there are excessive soap bubbles in the washer, the washer may have locked up because of this. Wash the load again without adding detergent.
Step 4
Rearrange the laundry so it is evenly distributed if the Admiral washer stops or if laundry is still wet at the end of a cycle. Untangle any laundry from the center post in the wash tub. Select the correct water level for the amount of laundry. Select a normal spin cycle for jeans, towels or other heavy loads. Close the lid and start the washer.
Step 5
Check the hoses to make sure they are tightly connected to the Admiral washer if it leaks water. If they are loose, tighten them with a screwdriver. Make sure the drain hose is secured to the drainage area. Avoid putting too much laundry in your machine or soaking laundry for over 30 minutes.
Step 6
Make sure the Admiral washer is on a level plane if it is excessively noisy. If it is not on even ground, move the washer so that it is level. Remember that some washer noise is normal. Thin floors can cause the washer to vibrate and move about and the noise level may rise and fall depending on the speed of the cycle.
admiral washer does not work on wash cycle Google Search
Nov 25, 2017 | Washing Machines
Lg top load washer 1 year old, vibrates violently during spin. Checked an adjusted level, no help.
they have springs and shock absorbers in the machine to help stabilize the load when spinning. since the washer is so new, i would guess one or the other has just come loose. take top off and check. online videos will show you how
Feb 24, 2016 | LG WT4801CW Top Load Washers
Our Kenmnore Oasis Model 110.2703 washer gets out of balance with all size loads and stops due to excessive vibration. The washer was checked with a level as required by the manual and is level. The...
Raise the lid by depressing the clips that are about 2" in from each side. See the white plastic "balls" that lie in sockets on top of the suspension rods? Lift them up and clean the socket and ball on each corner, apply new grease and you should be in good shape. Two people make this a whole lot easier.
Jan 13, 2011 | Kenmore Oasis 27042 Top Load Washer
Are Admiral washers poor quality/
MY KENMORE IS 15 YEARS OLD AND GOING STRONG STILL. PERSONALLY DON'T CARE FOR ALL THIS FANCY SCHMANCY DIGITAL COMPUTERIZED WASHER TECHNO. IT'S YOUR CHOICE IN THE END. GOOD LUCK
Apr 24, 2009 | Admiral AW22 Top Load Washer
Washing machine vibrates really bad during the final spin
make sure your machine is level in both directions
Apr 02, 2009 | Admiral AW22 Top Load Washer
Bad vibrations/shaking with LG washing machine WM2032HW
What's the exact model of your washing machine? I'll need this to get you exact part numbers.
If you're looking for a quick and cheap fix that works. Try installing a rubber anti-vibration pad under the washer. I've had the best luck with a pad called Silent Feet. They are pretty hard to find in stores but Amazon.com carries the full line of Silent Feet anti-vibration pads. They will provide you with the best results short of replacing the full shock isolation assembly in the washer. And they cost a lot less.
Mar 03, 2009 | LG WM-2032H Front Load Washer
Very loud bearing noise in spin cycle on five year old admiral washer
there are just two possible causes 1;; is the main motor bearings.2;;the main carrier bearings in which your drum runs.you might find it cheaper to replace the whole washer.hope this helps.adrian
Feb 24, 2009 | Admiral AW22 Top Load Washer
Washplate problem Kenmore Elite Calypso washer
Hello genny2626
Welcome,
You said,your 6 year old Kenmore elite top loader's wash plate doesn't seem to go through its proper motions. When the lid is closed and the washer has filled and the agitating cycle begins, you can hear a vibrating noise as if the plate is trying to move on the gentle cycle, but when the lid is opened, nothing has moved at all. The drain and spin work fine, and the machine goes through an entire cycle without error messages, but the clothes aren't clean. You said, you have heard a lot of horror stories of how expensive these washers are to repair, so would like an idea of what's wrong beforehand.
Here are a list of common vibration noises
Noisy, vibrating, off-balance
 Is the washer level? Does the washer rock when pushed
against the corners?
The washer must be level. The front and rear feet must be in
firm contact with the floor. Check that the locknuts are
tightened. See “Level the Washer.”
 Is the floor flexing, sagging or not level?
Flooring that flexes or is uneven can contribute to noise and
vibration of the washer. A ³⁄₄" (1.9 cm) piece of plywood under
the washer will reduce the sounds. See “Location
Requirements.”
 Is the load balanced?
Evenly distribute the load in the washer basket and make
sure the height of the load does not exceed the top row of
basket holes. See “Starting Your Washer.”
 Do you hear clicking or other noises when the cycle
changes from washing to draining or spinning?
When the drive system shifts or the washer basket settles
between cycles you may hear noises that are different from
your previous washer. These are normal washer noises.
 Is the washer gurgling or humming?
Is the washer level? The wash load
should be balanced and not overloaded. The washer must be
level. The front feet should be properly installed and the nuts
tightened. Reset the rear leveling legs (if needed). See the
Installation Instructions.
Did you completely remove the yellow shipping strap with
cotter pins? See the Installation Instructions.
• Are the gears engaging after the drain and before spin, or
is the upper part of agitator clicking during wash? These
Let me know if any of these are the solution!
Huuum
Oct 13, 2008 | Kenmore Elite HE4 Electric Dryer
Admiral AW20 Top load washing machine
Dear Friend,
ngfam1 here for you!
I am happy to be of assistance!
Have someone help you to level the machine using a spirit level on top of the washer and adjust the legs up or down accordingly!
Other wise you need factory service!
If your not sure what you are doing stop... and call service!!!!!!!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. Please give me a good rating here in fixya.com before you sign out!
Aug 06, 2008 | Admiral AW22 Top Load Washer
Off Balance
1. Check all the filtration system...ie pump and all hose's and connetions there after...one of the most common is a coin where the drain hose connects to the back of the machine.
2. Age of the machine could mean the suspension is getting soft...only fix is 4 new suspention rods.
3. Balance switch Adjustment..most modern washers do not have this thou...not sure for your model
Jan 03, 2008 | Admiral AW22 Top Load Washer
Admiral AW22 Top Load Washer Logo
238 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
