Question about Sharp LC-32SB21U 32 in. LCD TV
Manual switch ok but remote not fundtion sharo tv
  • Sharp Master
  • 681 Answers
A very easy way to check your TV remote control. See the remote controls transmitting LED ie. Infra red LED through your mobile phone's camera and press different keys on the remote control. If the remote is working you will see the IR led flashing on the mobile phone screen.
Posted on Jul 28, 2015
    Problem Solver:
  • 5 Answers
Be assured that fault does not lie with the remote handset itself. In that case repair or replace it.Remote control system has two parts. One is the remote hand set and the other lies within the TV or other device for which remote controller is being used. The hand set transmits commands in shape of singnals of particular frequency and pulses per second depending on the key pressed. The other part of the remote system lying within the TV receives, decodes and responds according to the commands received in shape of signals of particular frequency and pulses of paricular width and sequence. The remote controller uses invisible infra red light as the carrier of the signal. As the light moves in straight path, no obstacles should block straight line of sight path between the remote hand set (the transmitter) and IR sensor window (part of the receiver). Hence remove the blockage from the front side of the TV.Check if the IR sensor is not defective. Check if the associated circuit and components inside the TV are not defective.Check if the TV has any switch for selecting only manual mode and locking the remote mode.Hope, some sytematic exercise will bear the successful result.
Posted on Feb 20, 2012
My hisense tv seems to be locked
remote batteries ok
switch off at wall unplug
plug back in ...switch on
see where it starts up at
menu or ok should take it back
search online for its user manual if you dont have one
Mar 07, 2017 | Hisense Televison & Video
I need to fix the direct drive record player on my Electro Brand Retro Cd Am/fm With Turntable 45rpm, 78rpm, Built - In Speakers Model 9263, I dont have the manual and can not find it online.
Are you certain it's a direct drive model, because DD models with 78 speed are not common at all? If it is a DD model then you need to check that power is getting to the motor. There could be a switch that's not turning it on somewhere inside the unit.
May 15, 2015 | Drive Audio Players & Recorders
Sharo tv code
0029,0022.
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Aug 10, 2014 | Sharp Aquos Televison & Video
Sansui platinum plus tv
Are you using a remote control or the switches on the TV?
If using a remote;
First turn the TV off at the power point then wait for 10 seconds.
Then turn the TV back on
Then attempt top adjust the volume using the manual settings on the side or bottom of your TV, if that works then you may have a remote that either needs new batteries or does not work.?
Can you turn the TV on and Off with the remote control?
Can you change channels with the remote control?
If you can do both the above it would appear that the remote is working OK.
Does this fix the problem?
Jun 30, 2014 | Televison & Video
Working tv with no remote
Try website 1-800-Remotes Factory original.To buy an exact remote.
Mar 14, 2010 | Thomson 28VK25US TV
TV service menu
press OK on the remote and OK on the TV panel at the same time, after 5 to 10 seconds, the service menu EZ adjust should appear.
another step is to press menu on remote and menu on tv at the same time..
Feb 01, 2010 | Televison & Video
Invue system for an 02 suburban.
First you can download a manual for your model from Rosen's site. It explains all the on screen programing you can do. You'll need a fundtioning remote to do this I think. You can get one from a local Rosen dealer for about $35 (see deaker finder on Rosen's site. Yes your sound does come through the radio on 88.7 or 88.9FM througha modulator installed inside your dash. Otherwise you use infrared wireless earphones (Wal-Mart sells them). The "Speaker" button on the passenger side of the LCD screeen turns the car speakers on or offf.
Oct 23, 2008 | Rosen inVUE II Video Ent. Sys '00-'02...
Sharp LC-32SB21U 32 in. LCD TV Logo
247 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
