Question about JVC Televison & Video
I have a HD 61 FH 96 JVC that is dirty between the screen and plastic outer covering can I clean between this covering
Can I clean between the outer cover and the inner screen
  • 3 Answers
SOURCE: Cracked screen
rmaura,
My Toshiba TE55T11 also has a broken screen. I contacted the Toshiba hot line in Australia and they said that they don't make screens for this TV anymore. so i just got a new Toshiba 72CM9UA.
I hope this info is useful!
Posted on Apr 20, 2008
SOURCE: cleaning JVC rear projection screen (behind cover)
You will have to do some dissassembling of the cabinet to remove the screen and bezel assembly. If you are will to do this I can give you the directions.
Posted on May 11, 2008
welcomejee
  • 10594 Answers
SOURCE: Cleaning the screen cover on my sony big screen
To clean its front screen, you should not open front cover as its complicated procedure. just take off its back cover as its shown in picture and use air-blower to clean dust. Then use soft cotton cloth to clean its screen from internal and 3 bulbs / lenses (CRTs) and job is done.
Need further help, let me know.
Bye.
Posted on Sep 13, 2008
Bappa170873
  • 505 Answers
SOURCE: i have jvc 61 hd
You need to change the Input mode of your TV to HDMI and also the device you will connect to the TV should aslso be slected to HDMI.
There is nothing seperately that needs to be activated.
Thanks
Posted on Nov 28, 2008
SUPERMAN_B_1
  • 294 Answers
SOURCE: cleaning tv screen protector cover
MAKE SURE YOU USE A LINT FREE CLOTH AND NO ALCOHOL OR OTHER CLEANING PRODUCTS,IF ITS A LCD I WOULD'NT RECAMEND TAKING THE COVER OFF
Posted on Mar 07, 2009
How do I remove the outer plastic cover on the head lite assembly
the outer shell is not separable from the housing. you will have to replace the complete headlight shell.
Sep 28, 2014 | Jeep Grand Cherokee Cars & Trucks
Crack in plastic screen cover the theatre 61 jvc
As Long As The Primary Projection Screen Is Not Damaged The Picture Should Still Be Ok..The Screen Cover Can Be Replaced At Your Option..
Sep 11, 2014 | Televison & Video
Clean lens and screen
LCD rear projection almost never need cleaning---is model number here correct? If so do not even attempt to clean the lens and screens on this type of set scratch if you touch them hard.
Real question would be what issue do you have with the set?
Apr 17, 2012 | JVC HD-61FN97 61" Television
The clear plastic cover that covers my screen broke
There are several different sheets of plastic that cover your screen. The outside one is the screen protector, the middle one is the lenticular screen, and the inside one is the fresnel screen. All are available at Encompass.com
Apr 22, 2010 | Toshiba 61H71 61" Rear Projection...
I have a 56" JVC rear projections HD ILA tv.
Turn tv off and unplug it. Take the access door off either side of the tv. Use a dust cleaning tool like a swiffer with an extension (or make one). Clean off lens (most likely the problem). I have the same thing that happens to my JVC 61". You can use a vacuum with extension if your VERY careful.
May 07, 2009 | JVC Televison & Video
HD-56G787 JVC HD-ILA Help me clean the mirror!
pop the front strip under frnt of screen off. remove screws around back edge off screen and under the frnt of th screen. Usa a micro fiber cloth to clen screen.
Apr 25, 2009 | JVC HD-56G787 Television
Need owner's manual
Click JVC Support to download owner's manual of HD-61FH97 TV
Apr 13, 2009 | JVC HD-61Z575 61" Rear Projection...
My screen has shadow spots that look to be on the inside of the
you may be able to clean the lenses but if that dosent work it usually means its there for good
Jan 02, 2009 | JVC HD-61G787 61" Television
I need to get a plastic screen for my tv where can i get it
I can help! Go to www.sears.com the parts dept and have make and model ready
This should fix ya right up!
(please use ratings this is what keeps this site free)
thank you
Dec 13, 2008 | JVC HD-61FN97 61" Television
Replacement of front plastic screen
well, unless you are really really lucky and could find the same model at the local tip, you will need to ot\rder and replace the part through a repair center or parts center of sorts, quite costly
Aug 05, 2008 | JVC HD-61FN97 61" Television
Televison & Video Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
