Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Keep getting kicked off xbox live
I keep getting kicked off xbox live about 5 min after i start up an xbox360. this started 2 happen once i switched from a linksys router to a belkin router
  • 1,269 Answers
You should reduce the MTU of your router. You can simply call Belkin support for them to assist you on how to reduce the MTU.
Posted on Oct 27, 2008
Opening NAT with belkin wireless router xbox360
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
Goto : my blog for more information about belkin routers (Page is still under construction )
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Jul 29, 2010 | Zyxel P660HW-D1 Router
I have a belkin n modem router and it keeps kicking the xbox off line. is it the xbox live or my new router
it is the problem with router....the firewall built-in in the router will not allow certain gaming devices to go online...for this purpose you need to forward certain ports in the belkin router...for the list of port numbers to be forwarded, contact xbox vendor....once you got those port numbers, you can call 24x7 toll free belkin tech support(1800-2-235546)(1800-2-belkin) and ask them to assist u to forward ports... or you can can connect a computer to one of the wired ports(1 to 4) and open internet explorer and type in address bar and hit "enter key". you ll see belkin router setup page...on the left side you ll find "virtual servers" that link(if it asks password, leave it blank and click submit) fill the IP address of your xbox in that form and type the port numbers and select appropriate (tcp/udp)... also click on"firewall" in left and disable it.... also click on DMZ in left and type your xbox ip address there and enable it... thats it.... you are done with that...
Apr 13, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
My son's new Xbox Live cannot / will not connect with our wireless router, even though it recognizes it. I have a Belkin 802.11b
1) Get connected to belkin's wireless network or wired network
2) Once you get connected, it may not be able to go online on XBox Live
3) Go to any computer that is going online with the router
4) Type in in the address bar of your Internet explorer
5) This will open up router interface(here we have to do some settings)
6) In the left hand side column, click on FIREWALL.
7) Leave the password blank in login page and disable the FIREWALL. Click on Apply Changes.
8) Under FIREWALL(in the left hand side column), click on DMZ
9) Make a "check" on enable and under Private IP: Click on Apply Changes.
10) Now go to Xbox, under network settings, choose IP settings, and select manual configuration
11) Now select manual configuration for DNS settings.
Primary DNS:
Secondary DNS:
12) Restart both Belkin and Xbox
13) It should connect to XBox Live now...
Jan 17, 2010 | Belkin (F5D8231-4) Wireless Router...
Whenever i start the vuze client i cannot surf the internet!!! I have a brand new Belkin N wireless modem router.
I also have this problem i.e whenever I start Vuze my Internent connetion is cut - I can't search Vuze and it takes 20 mins for my connection to be restored once I've closed Vuze - my ISP is Tiscali - anyone got any ideas?
Jan 10, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
I have a Linksys WRT160N, and xbox live wont even connect?
If your only using this router for Xbox Live id Ditch is I had this same router had nothing but Problems heres a link with a list of compatible routers.
Sep 20, 2009 | Linksys WRT160N Wireless Router
XBOX360 Wireless Adaptor does not see my already set-up wireless network. I have Verizon FIOS as my ISP and a Linksys Wireless-G WRT54G Router. I can plug an Ethernet cord into one of the ports on the...
Please follow the steps below to setup your Xbox with your Linksys Router:
  1. With your Xbox powered down, take an Ethernet cable and plug it into a numbered port on the router, and plug the other end into the Xbox.
  2. After you have your Xbox connected to the router, start up the Xbox without a CD in the tray.
  3. After you start the unit, you should arrive at the “Xbox Dashboard”. Select the Xbox Live option and press the “a” button on the controller.
  4. After “Xbox Live” loads select the Network Setup and press the “a” button your controller.
  5. On the “IP Address” settings, you can choose “Automatic” or “Manual”, make sure it’s Automatic.
  6. Select the Connect option and press the “a” button on the controller.
After you use the “Connect” option, the Xbox will detect the network cable, and will ask you if you want to connect to Xbox Live.
Aug 17, 2009 | Linksys Wireless-G WRT54G Router
Xbox Live Can't Connect to Friends
Hi akemccarthy
you may need to open the ports for the linksys Router aswell
because the linksys links the belkin to the internet there using a shared connection
once youve fowarded the ports properly check to see if you have enabled the UPNP on both of the routers if they have any
heres a website showing how to port forward the ports you need opening
Dec 18, 2008 | Microsoft Xbox 360 Console
Opening the NAT connection for Xbox 360 working through 2 routers
  1. How do you connect your Linksys router to Belkin router? Do you connect your Linksys router to the Internet/WAN port of the Belkin?
  2. If so, what is the Internet connection type set in your Belkin router? Is it dynamic?
  3. If the Belkin router is set to dynamic IP and if it is obtaining an IP address from your Linksys router(you may check the status page of your Belkin router and look for IP address), then you may need to forward or set that IP address as the DMZ to your Linksys router. Make sure that XBOX is still configured as the DMZ host in your Belkin
Hope this helps!
Nov 15, 2008 | Computers & Internet
Nat type
I have the same router (WRT300N) and this is what I did. I don't know if it will work for more than one Xbox360.
- Go to the Setting of the router.
- Applications & Gaming
- DMZ
. Enable the DMZ
. Choice the Mac Adress under the Destination.
. If you don't know the Mac Adress of your Xbox360 click on the tab: DHCP CLIENT TABLE
.Now from there choice your Xbox360 ( the Xbox360 won't have a Client Name but hopefully you only have your Xbox360 and your computer)
and now save your setting and restart your Xbox360 and there you go NAT open. This also help if you get any kind of  LAG while someone is on the computer using the internet, your Xbox360 will be high priorty to the router.
Apr 05, 2008 | Linksys WRT300N Wireless Router
Xbox360 Live
you will need to call tech support for linksys on this one xbox might have diff setup that may need configed
Sep 23, 2007 | Linksys Wireless-N WRT150N Router
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
811 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
