Question about Whirlpool Ovens
Whirlpool oven bake button doesn't work - Whirlpool Ovens
I just unplugged it then waited and plugged it. It worked for me.
Posted on Aug 23, 2012
  • Roze Waterson
    Roze Waterson Aug 23, 2012
SOURCE: whirlpool oven everthing works except the bake element
ask a local repair shop
Posted on Jun 06, 2009
rogrrabbit
  • 986 Answers
SOURCE: Whirlpool Oven Model GS440LEMQ bake eventually turns off
This is a control board problem... you must replace it to correct the problem. Best of luck.
Posted on Jan 01, 2010
SOURCE: whirlpool accubake oven problem
I had the same problem and followed the process listed above....yes, I did unplug/turn off the circuit and am alive to share this update! Right off I noticed that the ribbon cable was loose. For those who have tinkered around with other electronics such as a PC, etc., note that this ribbon cable is not secured by the connector (atleast in my case). Reseated the cable and turned the power on. Voila- the bake option works. Tested it by turning it on for 20-30 seconds. Touched the bake element and got proof that it was working fine (via a singe of the ring finger ;-)).
About three minutes or so later, the display started to beep with an error code - E0 F2. A shorted keypad is what it stands for. The clock was still operable. I could still select the bake option, broil option, etc. Ran a test bake cycle but it turned off after a minute or so and started to display the E0 F2 code again.
Started the process all over ie turn power off, take panel off, reseat ribbon cable. Turn power on and test by holding the Cancel button for five seconds. Still displays the E0 F2 error. Waited for 10 minutes but this time no more beeping or error display. Ran a preheat cycle for 4+ minutes without any problems. The oven warms up and the bake element glows red. Hopefully, all is well. Will see what it does when we bake something the next time.
Thanks to PropHeadTwo and others for their contributions.
Posted on Dec 18, 2008
barkencoa
  • 3463 Answers
SOURCE: Whirlpool double oven has a loud fan when baking
There will be some noise from the fan, but it should not be excessive, if it is really loud, then this is an indication that the fan is failing, and should be replaced ASAP.
Posted on Mar 12, 2010
  • 1891 Answers
SOURCE: bake button does not work.
if the buttons are the touch pads then your control has failed and you will have to replace it .mm
Posted on Jul 15, 2010
Frigidaire wall oven CPEB30S8CC2 lower element does not work
We have a Frigidaire CPE30S8CC2 with the bottom bake element not working. We tried to replace it with no luck. The old element does not look burnt out at all. The timer, clock and broil all work just fine. The bake button works and you can set the temp. it just doesn't actually heat up at all. There are no knobs on the controls for any cook top. it is all on a circuit board for overn only. help?
Jul 16, 2012 | Frigidaire Ovens
Whirlpool gas oven will not heat
most likely you have a bad ignitor,pull out the racks and remove the floor to the stove,turn on the bake,if the ignitor glows but it takes more than 40 seconds for the flame to light you have a bad ignitor even though it glows and if it doesn't glow at all the ignitor is bad,also if the broil lights on top and the bake doesn't change out the ignitor.next time send the model number and i can look up your machine to help you better.
Nov 15, 2011 | Whirlpool Ovens
E-1 & F-5 come on after about a minute when attempting to use self cleaning. the micro switches work & the solenoid has been replaced. could it be the ERC ?
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa
Oct 21, 2011 | Whirlpool GMC305PD Electric Single Oven
My whirlpool oven locke with F5 E1 what to do
Thanks
Oct 05, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Oven temp will not change
Most ovens have BAKE, BROIL and yours might have CONVECTION. Turn each on independently. If all don't work its one problem if only one doesn't its another
Also is it the gas doesn't ignite or it ignites then no temp change (or electric gets to xx degrees but doesn't get hotter?
Sep 04, 2011 | Wolf Range WKGD-2 Gas Double Oven
My oven is not baking properly. The tops of banana bread and cinnamon rolls are browned and bottoms still soggy.
It's possible the lower bake element is not working. If the oven takes a long time to come up to temperature, that's a good indication that a baking element (bottom, broil element is on top) is bad.
Apr 27, 2011 | Whirlpool GBS307PR Electric Single Oven
Broil turns ON when pressing BAKE button on RBS275PD Whirlppol oven
Our Whirlpool oven just started doing the same thing!!!! The Delay Start Time (setting it for one minute ahead) and then Start works just fine.  But we fried the tops of three loaves of homemade bread!!!!
Is Whirlpool just a bad brand for ovens?
Dec 07, 2007 | Whirlpool RBS275PD Electric Single Oven
Whirlpool oven issue
Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Oct 26, 2007 | Whirlpool RBS305PDS Electric Single Oven
Open Questions:
Ovens Logo
80 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
