Question about Vacuums
MRG 720-42/2 Hi, I have a vacuum Miele and the motor failed....and now I would like to buy a new one. The motor type is MRG 720-42/2 If you know where could I buy it, please let me know...... Many thanks is advance. Carlos Suarez suarezcelma@yahoo.com
reddevil6
  • 1673 Answers
SOURCE: oreck vaccum
The belt must not be running true to the pulley. You may need a brush roll, but also check the motor to make sure it isn't moving inward after the belt is put on.
Posted on May 20, 2008
reddevil6
  • 1673 Answers
SOURCE: Eureka Wide Track Superlite vacuum roller brush motor
Don't know if you can find something that will work, Eureka doesn't make these motors available thru them. Try some local shops or a place that sells small motors.
Posted on Jun 17, 2008
futureloginn
  • 734 Answers
SOURCE: Miele Solarus Canister Vacuum stopped working
Miele S251i Plus Bagged Canister VacuumMiele white star canister vacuum - won't turn on,...
I have the above canister vac, which after my son tried to vac the stairs, it rolled down the stairs on him, but still worked, after turned off/on. Then after turned off maybe 10-15 mins., stopped working when we tried the switch. My father in law is our fix it guy, but still having a problem with the switch. Is there a wiring guide we could look at?
Thank you!
ALevy
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You can try to call the factory for the Miele S251i schematics / wiring diagram @ the phone number and website listed below or I put a few pieces of information listed below that might help.
1. The vacuum cleaner switches off automatically
A temperature limiter switches the vacuum cleaner off automatically if it gets too hot. Some models have a warning light (triangle) which comes on to indicate that it has overheated. Allow the appliance to cool down for approx. 30 mins. and remove any blockages to the air path.
2. The "Change dustbag" indicator stays on even when a new bag has been inserted
To ensure the dustbag change indicator gives a correct reading, lift the floor nozzle or power head off the floor slightly to prevent the vacuum created in the suction tube from influencing the reading.
3. The exhaust filter indicator is red
Change the exhaust filter and then press "Reset" to switch off the indicator light.
http://miele.com 1-800-999-1360 Customer Care
Toll-Free Contact Information
For a repair order, please contact us at our toll-free number (800) 999-1360, Monday through Friday from 8:00am to 8:00pm, Eastern Standard Time (EST).
www.AVACcorp.com 1-800-328-9430
Posted on Dec 02, 2008
galati2k
  • 281 Answers
SOURCE: need a new motor
depends how old it is .if its quit a few years ol i would buy a new one.some of those oplder whirlwinds ar hard to find parts for and some are just not available anymore
Posted on May 05, 2009
SOURCE: PHILIPS MOBILO PLUS (vacuum)- How to remove motor cover?
I found a solution. At least on my Mobilo HR8572. There are two tabs on the top plastic parts that hold on to the bottom plastic part. These tabs are located above the wheels, if you look closely you will see thicker grey plastic. You have to put a big screwdriver under the top plastic part and move it outward. The tabs are 6mm thick so you have to bend it out considerably. It then pops open. Works a treat and all the motor and electrical components are easily accessible using a simple star driver
Posted on Apr 01, 2010
Where can I buy a motor for a Mangle B 890?
Fred, If you can disassemble, take motor to appliance/vacuum repair shop and they can order. Check links below if you want to order parts.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Miele B990E Rotary Iron
https://www.google.ca/url?sa=t&rct=j&q=&esrc=s&source=web&cd=6&cad=rja&uact=8&ved=0ahUKEwi58tvH35jLAhWDlh4KHeLIBkMQFgg5MAU&url=http%3A%2F%2Fwww.mieleusa.com%2FProduct%2FDetails%2F555&usg=AFQjCNFXEYlWKHs2CNOLMhTTHpfUroMBYw
Miele B890 Iron Parts
Miele B890 Iron Spares
Feb 27, 2016 | Vacuums
Cost to replace a motor on a miele s251i
Buy a new one. Motors cost almost as much as the unit.
May 03, 2014 | Miele S251i Plus Bagged Canister Vacuum
Where can I buy a new housing for my Miele S 143 upright vacccum? The nozzle part broke of while vacuming I tried to glue it but it doesn't hold. Thanks for any input
http://vacuums-intercoms.centralvacuumstores.com/search?w=new+hose&af=type%3Aproduct&asug=&x=0&y=0
Here is one place.  I hope it helps.
May 20, 2011 | Miele S143 Bagged Upright Vacuum
Miele vacuum cleaner keeps overheating and shutting off. It is only possible to use for about fifteen minutes at a time
Hi Lauren, how do you know if it is the circuit board? (the speed control buttons still work).
Mar 13, 2011 | Miele Vacuums
My nearly new Miele S710 vaccum cleaner just revs like mad when you switch it in but you get no suction. Could there be a drive belt between the electric motor and the vaccum pump that has come off or...
Yes this could be a case due to which there is no suction. I am posting an article which gives you a detailed description of how to open it and repair the internal parts.
http://www.sannerud.com/house/miele.html
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Jul 23, 2010 | Miele Vacuums
I need a new motor
red star was part of there low end line. not cost effective as miele parts prices are outrageous.
May 06, 2010 | Miele Red Star Bagged Canister Vacuum
Hi. Miele 5310 motor appears to have burnt out. Red light with ! is on and vacuum cleaner won't switch on
have a look at the switch first they can get worn but if thats not it look at the motor brush's if you have power to the motor but no "get up and go" no broom broom like! buy a new hover as a motor will cost you both arm's and one leg!!! plus its still needs to be fitted
hope this helps you? mike.t
Oct 20, 2009 | Miele Vacuums
My Miele bags for S241 vacuum cleaner have just been replaced by the new HyClean bag. There are less in the box and you can't empty them either - a mesh of cords being in the way. I knoe you're not...
The old style bags are not available any longer. The new HyClean bags have a larger capacity then the original style. You get the same amount of capacity out a box of the new bags as you did the box of the old. I know they are still expensive. I would recommend calling an internet company and trying to buy a quantity of bags at a time to see if you can get a little better price.
Sep 28, 2009 | Miele S4210 Sirius Bagged Canister Vacuum
Motor makes loud growling noise, no suction on model 270 i Miele canister style vacuum
Hi there SmartAlec from NelsonVacuums.com.au here. Unfortunately that normally means the motor has shot its bearings and/or its carbon brushes. I think it is time to purchase a new one. On the bright side there are some rreally great vacuums out there! If you want any help choosing a new machine send me a message. Happy Vacuuming :)
Sep 04, 2009 | Vacuums
Vacuums Logo
754 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
