Question about Sony KP43T75GRAY 43" Rear Projection Television
Part of Picture is black
I had to reset the TV to Cable/Antenna after watching a DVD. but something happened. Cable stations come on but show a black rectangle in the bottom half of the picture. How do I get that off, so I can see the whole picture?
  • 12many Oct 30, 2008
    It was in the menu changes. Thanks
  • 1,030 Answers
Chances are your close captioning has been turned on go into cutomer menu setup and see if it on.
Posted on Oct 29, 2008
I'm trying to hook up my DVD player to my TV but my TV doesn't have a yellow jack only red and black
If your TV doesn't have a Video IN jack (Yellow) then you would have to attach your dvd by antenna (Coaxial) cable. What does the DVD have on the back ? EG: Video Out is Yellow, Red is Right Audio, White is Left Audio. If your DVD has Ant in & Ant Out you can use a coaxial cable from Ant out to your tv's antenna In socket and put your antenna cable (from your wall socket) to Ant in on the dvd. Turn on the dvd and put your tv on a blank station and tune your tv till you see the dvd screen . lock it in and that becomes your DVD channel to watch your dvd's.
Hope this is some help.
Sep 07, 2015 | RCA Televison & Video
HI, you can do these troubleshooting steps and get back to me..
Check the video connection of any devices plugged into the LCD television. If you can hear sound but are seeing no picture while trying to use something like a DVD player or cable box, the problem is probably that a wire is loose somewhere. Check the yellow video cables running from the DVD player to the TV and make sure everything is plugged in firmly and where it should be. Also check the coaxial cable running from the cable box (or cable outlet) to the television and make sure that wire is also screwed in securely.
Check the image settings on your television and make sure everything is set properly. Certain settings like "Picture" or "Brightness," if set to one extreme, can make the picture appear completely black. This could cause you to simply hear television shows but not be able to see them. Reset all picture settings on the TV to their original factory default settings to see if that fixes the problem.
Try another channel. If you're watching TV and not getting a picture, the first thing you should do is check a variety of random channels to make sure it is a problem with your TV and not with your television signal. If it is a problem with the television signal it is the fault of the TV station or cable service provider and there isn't anything you can do yourself to fix it.
Try the DVD on another DVD player. If you're trying to play a DVD and can't see any images, make sure the disc isn't defective. Try it on another DVD player or a computer DVD drive and make sure the disc works in the first place.
Hope it helped ..
Jun 17, 2011 | Televison & Video
I don't think there is any problem with your TV. I think problem is from your cable receiver or antenna depending on the cable network that you are using.
To confirm, connect your TV to a DVD player and let's see if there is going to be sound and picture on your TV. If TV works perfectly with the DVD, then it means your antenna or cable receiver/decoder needs to be check. There might be a temporal network problem with your network provider.
Let me know the outcome of connecting the TV to a DVD player so that I can tell you the way forward.
Your sincerely.
May 16, 2011 | JVC HD-61Z456 Television
Plasma tv will turn on with picture (from DVD player but not cable box) for about 1 minute then tv cuts off and red light blinks about 14 times.
Try unplugging the outside cable line from the box and plug it directly into the TV and do a channel autosearch.You should at least get some basic cable stations.If you do get them,something is wrong with the cable box.If you don't get anything,it's something in the TV,maybe something as simple as the coaxial antenna connection(hopefully).I am assuming the DVD is plugged into the external input jacks?(red,white,yellow cords).If the DVD is not hooked up that way please let me know.Good luck!
Aug 06, 2010 | Panasonic TCP50G25 50 in. TV
Loss of Digital Shows??
U have cable's or dish's boxs?unplug,replug the box for the software to down load to upgrade.Unplug,replug the tv.Go to the menu set for Air or Cable then rescan all channels
Oct 26, 2009 | iLO V27DMBX Television
Toshiba 32a43 32' picture garbled mess
If you can get the tv to display the blue blackground(usually happens when there is no antenna or cable feed to tv) check to see if the whole screen is a solid blue, if it shows discolored areas around the screen then you might have to "demag" the screen. See if you can rent a demad coil from a tv shop and with tv on turn the coil in circular movements all over the front of screen till blue is solid.good luck!
Aug 03, 2009 | Toshiba 32A43 32" TV
How to get from standard TV to Cable TV?
Should use remote to bring up the menu. Go to channel search and it will ask you if for ant or cable. This is where you will select for antenna or cable.
Feb 15, 2009 | Televison & Video
Picture not clear when playing a recorded program from dvd
I had a similar problem with an Insignia converter box. This is confusing but . . . I was told by an Insignia person that you can only program the channel that you have on and cannot record a different channel. My output channel is 3. My roof antenna is attached to my converter box "From Antenna" jack. Attach the converter's "To TV (RF)" jack to your VCR's "Antenna Input" jack. Attach "Antenna Output" jack to TV "Antenna Input". You will see your programs on your output channel, but if your VCR is like mine, your VCR may not recognize anything but your output channel, no matter which station is actually showing on the TV. If I want to record a show on channel 7 while I'm gone, I have to make sure the converter station is on 7 and that I choose channel 3 as my channel to record. You cannot program shows to be taped on different stations unless you physically change it on the converter box. I put my VCR on "Record" and flipped the stations from one to the next from my converter remote control and I taped exactly what was on the screen from one station to the next. You cannot tape one thing and watch another. Clear as mud??? Hopefully, not.
Jan 02, 2009 | Insignia Digital-to-Analog Converter for...
No sound or tv signal
Probably need the TUNER either fixed or replaced.
Apr 27, 2008 | Toshiba CZ27V51 27" TV
Sony KP43T75GRAY 43" Rear Projection Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
