Question about Frigidaire FGHB2844L
Ice marker not making ice - Frigidaire FGHB2844L
We recently had a water supply connected to our Whirlpool refrigerator model GB2FHDXWB02. After ~ 18 hours no water has entered the ice maker? What is the problem? Can I manually initiate water going into...
Make sure you actually turn the icemaker on, there is a arm that you have to trip in side that will activate the solenoid that make water enter the ice marker. Also keep in mind that the air in the line has to work out so give it 24 hours to make it to the ice maker. You should see the hose in the back of the frig, that runs from the solenoid to the ice maker. Also check the ice maker itself to make sure it is plugged in completely. Good luck
Jan 09, 2015 | Whirlpool Refrigerators
Why is water not going to ice maker
Check the hose to the ice maker and make sure its not plugged and then check the switch from the ice maker to make sure power is activating the solenoid that turns on the water. If solenoid is good then your ice marker is bad
Jan 04, 2015 | Kenmore Refrigerators
Ice marker not working
I had a problem with mine when a piece of ice jammed the comb that ejects the cubes. No ice being made until the jamming ice cube was removed.
Nov 07, 2013 | GE Profile PSW26P Stainless Steel Side by...
Ice marker stopped making ice
There is a test button underneath of the motor side of the ice maker. Unplug your refrigerator for 5 minutes then push the test button on the ice maker if it doesn't move you need an ice maker if it does move and you still don't get any water the metal tube that supplies the water to the ice maker is frozen up and blocking water from coming into the mold.
Nov 07, 2013 | Samsung Refrigerators
I have a Maytag frid m#PBF2255HEW (bottom freeze w/ice maker. My ice marker currently works but after dumping a tray of ice it "leaks" water into the tray causing all of the ice in tray to be one...
Sounds like the water inlet solenoid is getting stuck open, this is assuming you ice cubes are normal to large in size, Small would indicate the ice maker is leaking, You can try just replacing this valve , It's the valve that connects to the water hose behind your refrigerator and is fastened to the lower corner of refrigerator. Otherwise you can purchase the entire ice maker and solenoid kit for around 65.00 Hope this helps
May 18, 2011 | Refrigerators
My ice marker will not stop making ice the arm
This problem is going to be the ice maker itself. The arm you are talking about is the shut-off mechanism for the ice machine. Just before the ice machine starts to make ice, the arm slowly rises. Then the arm falls down, if there is ice blocking the arm from falling all the way down it will not make ice because there is plenty! If the arm is able to fall down completely, the ice machine will make ice like normal. If your ice maker is making ice regardless of the arms position, something is wrong with the ice maker. Depending on who replaces this, it could cost anywhere from $100 to $200.
May 28, 2010 | Roper RS22AQXKQ Side by Side Refrigerator
Ge ice marker no 120v to seloniod water valve
It sounds like the plug-in for the solenoid valve is not making contact with the terminals on the solenoid . You can either buy a new connector or cut the plug for the solenoid and crimp 1/4 inch sta-cons (insulated type) to the wires.
Sep 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The ice marker does not make ice. Have looked
If theres water in the line going to the fridge and the ice maker works , most of the times the water valve ( solenoid) that opens when the ice maker needs water , is leaking or doesn't work.
Aug 14, 2009 | Refrigerators
Frigidaire FGHB2844L Logo
41 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
