Dvd drive detection problem
Hi.. i have a samsung dvd drive which is not getting detected in my system even in device manager.Wat might be the problem? Any solutions for this??
  • 27,725 Answers
click start Control panel administrative tools computer management device manager scroll to cd/dvd rom drives + to expand could be a yellow question or exclamation mark ? ! or a red X right click update drivers
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard
you need only do the registry check if you cant see the drive/s in windows explorer/my computer
to check the registry
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Posted on Feb 29, 2012
5 Suggested Answers
SOURCE: dvd drive detection problem
I have an hp dv2422la with the same problem and just discovered something after trying many solutions with drivers and configuration. It is a problem of the fisical design of the dvd rom, If you open it by stiking a wire or stick in the little hole you will be able to open the drive and realize the cable under the cd carriage is maybe the same way that mine. It is not secured enogh and it is bent and scracht so that the information to the computer is going crazy, sometimes works and some others not, am I right or not?????? let me know please
Posted on Apr 22, 2008
  • 272 Answers
SOURCE: Windows Media Center cannot detect a video DVD in
Unless you use a DVD player software like power dvd or others, you can not watch dvd on your media player. This is a copywrite and license related issue. DVD players are paid players and this is why, microsoft can not include it on windows.
If you are not willing to buy a player now, try vlc media player instad (click here to get ) . Its free ofcource.
Posted on Apr 26, 2009
beast_b9
  • 113 Answers
SOURCE: DVD ROM not working properly
Can you check whether you Disc Drive is well connected ?
to check the device :
Right click on my Computer
Select Properties
Check your Dvd/cd drives.. whether everything is connected.
If not try re-installing the device or to update it.
second solution:
go to computer management -> disk management
see if your drive is listed in right window
for xp read this
did you install drivers for that , i had samsung try to install new firmware
Posted on Apr 30, 2009
rhinoking1
  • 85 Answers
SOURCE: Acer eXtenza 5620z , wont detect or play DVD
This is just a registry error ez to fix, click "start" "run" type in "regedit" click "ok" in the left field click the "+" next to "Hkey_Local_Machine" + next to "System" + next to "CurrantControlSet" + next to "Control" + next to "Class" then click on {4D36E965-E235-11CE-BFC1-08002BE10318} in the right field, "right click" on "Upper Filters" click "Delete" then "right click" on "Lower Filters" click " delete" restart PC. GL hope this helps you.
Posted on Jun 20, 2009
I have a toshiba l355d and it is not showing that the dvd drive is even connected to the computer. Even in device manager. I have tried taking the dvd player out, cleaned connections and it does the
You have done all thing I would have suggested and if the BIOS does not detect this DVD drive then it is faulty and needs to be replaced.
If the BIOS detects the DVD drive then the DVD driver needs re-installing.
You can download the DVD and device drivers for your model laptop from the Toshiba WEB site from their download page. Make sure you enter the model of your laptop so you can get the correct drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
Feb 12, 2013 | Toshiba TS-L632 DVD±RW Burner
My drive wont read anything. I am trying to install MS office from a DVD. my device manager says it's working properly and I tried the Microsoft Fixit and that didn't work
Device Manager states that it is working properly because it is detected by the computer. However, device manager has no capability of check if there's a problem with the lense of the DVD Drive. You can try a diffent CD to check if the problem is with the MS office CD or with the drive. If the DVD Drive still cant read any other disk it only means that it has a bad lense and you need to replace the DVD Drive.
Thanks for using Fixya.
Jan 31, 2011 | Samsung SD 616E (729507925578) Internal...
Can not detech and write
there could be a problem with the usb check if you are able to use any other humb drive or flash drive on the sysem if none is getting detected then just go to device manager and uninstall all the usb drivers and then resart the system it will get installed automatically nothing to worry then you can again try and see if it gets detected in the system tray and als after it gets detected install the dvd software to use it to write/read
Oct 26, 2010 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
My Compaz Presaro 2200 suddenly won't recognize its internal CD-DVD drive?
Right Click on "My Computer" icon
Select "Manage"
Click on "Device Manager"
Right click on the Computer name
and Click "Scan for Hardware changes"
Check now if your CD-DVD drive is detected or not.
If not,now Click on "Start" button
Select "All programs"
Select "Accessories"
Select "System tools"
Select "System restore"
Select a restore point or days when you know  your system was working fine.
System restore will complete afetr reboot,and it will detect your CD-DVD drive untill and unless your CD-DVD drive got malfunction.
If the problem still persists,Remove the DVD drive and place it again and restart the system and check if the operating system detect your DVD drive.If not, replace the DVD drive.
Jan 01, 2010 | Compaq Computers & Internet
No dvd/cd-rom driver detected my system can not detect cd/dvd drivers
Hi
Could you clarify, is this a laptop or a desktop computer? Please check device manager and tell me what do you see there, right click on my computer or computer which you will find either on the desktop or in the start menu. Select Manage. Then on the left side, see the device manager, now look on the right, do you see any unknown devices or any with ? yellow mark on them? how about cd/dvd drives?
Dec 13, 2009 | Dell Office Equipment & Supplies
DVD/GD Rom not detected by system under my computer, device mmanager or in BIOS.
having that the PC could not configer the dvd rom then you must install it with its drive software .the thing is that the operating program has no drive for it
May 25, 2009 | Computers & Internet
Dvd rw is not detected in windows xp in my toshiba a75 laptop
Kindly follow the following steps..
1. Go to Device manager. Click on the + sign beside IDE drives. Right click on the dvd drive and select uninstall. Restart the computer. It should get installed automatically as it is a generic driver.
2. Go to run > type regedit > go to the following key
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\
Select the folder that says ( 4D36E965.....
on the right hand side delete the file that says "Upper filters" and "Lower filters"
3. Go to device manager > click on the + sign beside IDE ATA ATAPI Controllers > right click on Secondary IDE channel and select uninstall. Do the same with Primary IDE channel. Restart the computer.
4. Reseat the dvd drive.
Hops this helps..
Regards,
Anup
Apr 07, 2009 | Toshiba A75-S125 Satellite Notebook
Optiarc dvd rw ad-7560A ATA device won't play cd or DVD
delete the existing drivers and re-install drivers by downloading from official site of your laptop/desktop
restart and it should help you ...letme know wat happens
harish
Feb 19, 2009 | Computers & Internet
Vista Won't Detecting My DVD Drive
ok go into windows devic manager and see if the dvd drive shows up there it might have a little ! in a yellow triangle if it does dont worry it should offer a soultion to get to device manager go to (start type device manager and then click on it)
also try installing the device driver again hope this helps
Jul 19, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
