I can not log in, it says usb datatraveler unable to log in the secured area. another application has an open connection to your datatraveler. worked on windows xp, but with windows 7 does not and i have no longer have windows xp computer, my whole pictures is in data traveler
You might be better using a computer with xp to save your photos to another device or even burn them to a disk
windows 7 i have found if i use a data traveller on xp then try to use it on windows 7 it will always say it needs to be formatted do you want to format now
so i have designated certain data drives to my xp and others to my windows 7 although i have found that i can use small ones on each computer 1gb to 2GB
if you right click in the bottom toolbar when this is happening select task manager under applications you will see whats running if you dont want it to be running select end now also under processes see whats ticking over the same will apply
if you can get it to be recognised it might ask to be formatted
hope this helps
SOURCE: MFC application in kingston data traveller encountered problem and needs to be closed
how did you try to format ?, try to unistall the driver when complete put the drive back in usb port. if that doesnt work keep the drive in port and open my computer right click on your thumb drive and go to properties click on tools and try error checking. this is probably where you try to format. once test is done pull drive out and reboot then put drive back in
SOURCE: SecureTraveler MFC Application has encountered a problem
it is infected with virus, check it with updated virus remover
SOURCE: kingston 2gb datatraveler malfunctioned
there is absolutely no problem in your pc .
your pen drive is faulty.
