Question about iRiver E150 (4 GB) MP3 Player
My IRiver E150 4 gb blocked. It's says DESIGNED by IRIVER and it is getting strucked...what can i do?
My IRiver E150 4 gb blocked. It's says "DESIGNED by IRIVER" and it is getting strucked... what can i do? suggest me at vikramthepolite@yahoo.com
StuartB
  • 807 Answers
SOURCE: DRIVER IRIVER ifp-790
Try here:
http://www.opendrivers.com/driver/233084/iriver-ifp-790-ifp-795-ifp-799-mp3-player-firmware-v1.85-ums-version-free-download.html
Posted on Mar 31, 2008
  • 3 Answers
SOURCE: iRiver Music Manger not recognizing iRiver player when connected
OK, this problem was driving me almost to tears with frustration but have managed to bodge-solve it so hope this helps!
Right click My computer and select Properties.
Click on Hardware tab.
Click on Device Manager.
Hopefully there is a yellow question mark symbol against Iriver T30 listed under other devices or portable devices or something.
Right click this then select Update Driver.
Tell it that you are going to manually update the driver yourself.
Eventually you will have to select what type of device it is - select portable device.
Now click on MTP device and click next to install the driver.
Hopefully now it is recognised by XP in My Computer....
Good luck
H
Posted on Jun 23, 2009
SOURCE: I need to restore the system files for my H10 Iriver MP3 player
System Files Missing
To restore
the system files,
connect H10 to
recovery tool.
Posted on Oct 28, 2009
SOURCE: My IRiver E150 4 gb blocked.It's says Generating
Hi, I had the same problem with my Iriver E200. The cause is firmware corruption.
I solved this problem using this method:
1) connect your Iriver device to pc and open the disc of your player;
2) you can see various folders: open the folder named "system";
3) this folder contain a *sys file;
4) open this file using notepad;
5) go to the row "version = ...";
6) you have to modify this row by inserting an older version of firmware. For example if you have "version = 1.11", insert a smaller number, for example 1.07. Save the *.sys file edited. In this way you can force iplus3 to reinstall an uncorrupted version of firmware;
7) now open iplus3, go to Tools -> Portable device -> update firmware. You should be able to reinstall firmware.
Posted on Feb 13, 2010
YourZEN
  • 820 Answers
SOURCE: iRiver E150 Shuffle
Starting from the main menu.
Select Music.
In Music mode: Press and hold the > button to view the Options screen.
Select Play Mode.
Under Play Mode: select Shuffle or Shuffle + Repeat.
You can also look this up in the E150 manual. Download the English.zip file from next page:
http://www.iriverinc.com/lounge/loungeView.asp?selectPart=03&findWord=&sno=985&page=1&cateCode=03
Unzip the zip file, with WinZip or WinRar, to view the manual in pdf format, that can be opened with Adobe Reader.
Posted on Jul 24, 2010
Testimonial: "Thank you so much. I have been scouring the internet for days with no answers. It worked perfectly, very happy now. Thank you! (:"
I can not upload song in my e100.......... explain me all process of upload song in my ipod & not open in my computer.....
The iRiver E100 uses iRiver Plus 3 to manage music, pictures, and more. iRiver Plus 3 can be downloaded for free here:
http://local.iriver.com/mas/download/downloadView.asp?selectPart=cateCode&findWord=01&sno=852&page=1&cateCode=01
  1. Insert the installation CD into your PC to display the installation process screen.
  2. Select iriver plus 3 and click the Install button.
  3. Complete the installation process by following the on-screen instructions.
  4. Turn on the iRiver E100, and then plug it in to the computer using the USB cable.
  5. Open iRiver Plus 3.
  6. Select the desired files / folders in your PC and drag & drop Music, pictures, etc. to the drive which appears as the product.
If you would like, there is a manual available here:
http://211.39.137.201//download.asp?filename=2008111114270150302.zip&filepath=/file/Down/
Jan 23, 2011 | iRiver E150 (4 GB) MP3 Player
I have misplaced my iriver E150 user manual. Can you suggest where I can download a free copy please. thanks. Nikki
You can download the E150 manual from the manufacturer's web site at
Nov 04, 2010 | iRiver E150 (4 GB) MP3 Player
"file not supported" error after transferring a
Dude ,i'm having the same problem.my iriver E150 8 GB is also not playing any video.Anyone ,pleeease help
Oct 31, 2010 | iRiver E150 (4 GB) MP3 Player
Kde se?enu manuál k Iriver P7
please I don't understand this question. Could you please rephrase your sentences in a why that is understandable.
Thank you.
Feb 08, 2010 | iRiver P7 Multimedia Player 16 GB Digital...
Getting music off Iriver
Bronte,
When you change your firmware from the "manager" version to e.g. the Firmware v1.85 UMS version, you will no longer need to use the iriver manager software to move mp3's around, you can just drop them on or from your iriver. The disadvantages are that:
1. by upgrading to the UMS version, you will wipe ALL your current music, so it will NOT help you right now, only after you have upgraded to the UMS version and placed mp3's on there again. The iriver will behave like an external thumb-drive, so you can use it on any PC without the iriver manager.
2. The UMS firmware will ONLY run in USB 1.0 speeds, so it will take up to 36 minutes to fill the iriver up with 1 GB of music (or in my case podcasts).
Regards,
Robert Ilbrink
Dec 10, 2007 | iRiver iFP-799 MP3 Player
Opening for repair the iriver h10 20gb
I am having the same problem. Resetting it doesn't work and now it's locked all the time and I can't do anything with it! There are no suggestions on the iriver website. Have you got any other solutions to this problem?
Dec 07, 2007 | iRiver H10 MP3 Player
Copy heavy files fail from iRiver to Hard-Drive
That is too many songs to transfer at once - transfer less at a time
Oct 10, 2007 | iRiver H10 MP3 Player
iRiver E150 (4 GB) MP3 Player Logo
Top iRiver Audio Players & Recorders Experts
aliasger yq
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
