Question about Vacuums
Instruction manual for VAX V125A all-terrain upright carpet washer
reddevil6
  • 1673 Answers
SOURCE: Vax problem
Could be a bad pump.
Posted on Feb 22, 2008
EwingElect
  • 276 Answers
SOURCE: VAX 2000 manual lost
If you want a manual for the Vax 2000 hopefully the one on the Australian website will help.
Try http://www.vax.com.au/Downloadsusermanual.html and you'll see V2000 listed.
Posted on Mar 31, 2009
SOURCE: water lesking from vax rapide carpet washer
i have been using a vax v26 carpet cleaner and the washing water is leaking from the bottom then the solution will not come out has the pump given up?
Posted on Jun 14, 2009
ukvacfan
  • 328 Answers
SOURCE: how do you use vax 2000 to shampoo carpets. do not
Set up is complicated unless you are patient.
Remove the paper dust bag from the bottom of the canister and then filter ring. Then put in the recovery bucket of which 4 litres of warm water should be added and a capful of floor cleaning solution.
Then remove the pump wire on top of the Vax motor where the blue filter circle is (keep the filter in, do not remove it!).
If the 2000 has a separate pump notch on the rim of the Vax motor head on the outside then you should plug the black cord in that has a washer screw type metal connector. Push, twist and lock in. Then the black cord which eventually leads to a clear pipe with the older clip on wash handle that has to be clipped to the main hose handle has to have the black and see through cord clipped to the main hose and eventually down the extension pipes until you get to the floor head. If you have the older style T shaped floor head the cord should slip into the floor head easily. Then either squeezing the trigger to release the cleaning solution in, switch the Vax on and hit the secondary pump button. This will pump the cleaning solution and water into the carpet. To stop the pump you can either lock the wash trigger to stop the liquid or squeeze the trigger to make sure no other liquid comes out. Generally you can see the foamy carpet solution flowing through the see through rubber hose and eventuallly through the floor head.
To **** up the rest of the carpet solution, stop the pump button and the Vax can be used to **** out all the dirty solution/water in the carpet. Its a big and tedious task generally!
See an alternative manual for the Vax 1000 which is an older model but similar to the 2000. It is free and in pdf downloadable form:
http://www.vax.co.uk/downloads/pdf/VaxGuideNo8a.pdf
Posted on Jun 19, 2009
skyblue67
  • 71 Answers
SOURCE: Do not have manual for Vax rapide carpet washer
Hi you caan usually get a user manual that you can download from this site
http://www.vax.co.uk/support/vacuum-cleaner-user-guides
Posted on Jul 19, 2009
Vax hoover suddenly hard to push on carpet
Make sure you have it set to carpet, other wise not sure
Mar 27, 2014 | Vax U89-P9-P Power 9 Pet Bagless Upright...
Carpet washer brushes stopped spinning
Unplug it, turn it over and there should be some thing stuck in the roller brush.
Mar 14, 2014 | VAX Appliances Vacuums
Vax upright carpet cleaner
could be blpcked
Feb 18, 2012 | Vacuums
I need an instruction manual for a Vax Rapide Classic carpet cleaner
i have recently been given a vax rapid deluxe unfortunatley it didnt come with the manual.my problem is the water isnt coming out ? please help
Sep 11, 2010 | Vacuums
Water lesking from vax rapide carpet washer
Jun 07, 2009 | Dirt Devil CE5500 Floor Keeper Upright...
VAX Petvax Operating Manual
Check Vax.co.uk they have an online user manual section.
Specificially:
Dont forget to rate appropriately, thanks.
Mar 27, 2009 | VAX Appliances Vax X5 Bagless Upright...
How do i attach the upolstery attachment?
Go to www.Hoover.com Click on carpet cleaners. Click on steam vac all terrain. Click on Learn more. Click on Download Instruction manual in pdf. It explains all. The hose is attached on the front of the recovery tank. under the hoover symbol.
Jan 30, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Vacuums Logo
383 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
