Question about Gateway FPD1960 19" Flat Panel LCD Monitor
Monitor blinks after sleep mode - Gateway FPD1960 19" Flat Panel LCD Monitor
  • 1,684 Answers
The most common cause of flashing or wavy display is a weakened or failing power supply caused by bad capacitors. This is easy to repair. Here is a link to repair information for the power supply board.
http://www.ccl-la.com/catalog/product_info.php?cPath=21_30&products_id=206
I hope this helps, if so please rate my solution.
BuddyMc
Posted on Feb 21, 2012
Viewsonic v1930wm
Sounds like the unit needs repair.
Jun 23, 2014 | ViewSonic VX924 19" LCD Monitor
My monitor won't come out of sleep mode
Try unplugging the power cord from the monitor for 10 seconds and plugging it back in.
Jan 31, 2018 | Westinghouse Computers & Internet
LCD AOC 2436Swa is stuck on active-off mode
tried to unplug the unit and don,t use for a while to reset the power supply as will as the main board.
Jan 08, 2013 | AOC 2436swa 23.6" 16:9 Lcd Monitor, 5 Ms -...
My screen symtoms are a little different on my L1975NW.
I am guessing the LED power indicator blinks green then becomes steady when the screen "turns on" (shows video). The problem is most likely a failing backlight power supply. That's why there is a 30 minute delay. Try to disable sleep mode and see whether that helps.
Aug 30, 2012 | Westinghouse L1975NW Monitor
Our Flat screen monitor comes on for a few moments and turns right back off any idea why it can be doing that?
it turns on as a "self-check" but if it doesn't get a correct input signal it goes to sleep.
Or you might have it going to sleep in settings.
Check to see if the power light stays on or blinks when it goes off. blinking means sleep mode
Apr 16, 2010 | Computers & Internet
Power on and monitor goes to sleep mode
You need to try it on another PC, alos verify if the VGA cable is good. If nothing change, then you need to open it up, first thing to look for are the capacitors in the power supply. Look for cpas with bulging top/seal, see example of failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Post back what you find so we can guide you further.
Mar 19, 2010 | Acer AL2216W LCD Monitor
Monitor goes into sleep mode after a few seconds
This is normaly cause by incorrect power management settings.
check power management setting in both windows and your computers bios
you will not need to worry about the power management settings of the bios when an operating system such as windows is loaded.
Loch Hiam
Az.
Sep 18, 2008 | HP Pavilion a620n (PC028A) PC Desktop
Hyundai LCD monitor L70N Stuck in sleep mode?
push and hold the power button... then hit the settings button on the monitor and goto power>sleep mode
Jun 17, 2008 | Hyundai ImageQuest L70N 17" LCD Monitor
Flat monitor is stuck in sleep mode
difficult to say what is sleep mode yellow light green ight blinking light pleas elaborate
May 10, 2008 | Computers & Internet
Won't come out of sleep mode
Have you tried getting a second monitor ? then using it to get to the desktop and go to power options and set your monitor to never turn off? after that is done try your monitor again and see if that works.
Feb 07, 2008 | KDS Radius RAD-7 17" Flat Panel LCD...
Gateway FPD1960 19" Flat Panel LCD Monitor Logo
41 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
