Question about Toshiba 2540CDT, 2545, 2545CDS (610074362708)
Enter BIOS settings - Toshiba 2540CDT, 2545, 2545CDS (610074362708)
  • 21 Answers
On starting tht unit just press tab or delete simultanueosly...
Posted on Feb 20, 2012
Acer aspire 5315 slow. Has windows 10. Boot up says Media test failure
This generally indicates a bad HDD...but enter the bios and make sure first boot device is NOT set to Network in the bios or maybe the hdd has gone and its looking for a operating system to load....
Check cable connections (reseat),
Check jumpers on hard drive for Master/Slave or CS settings,
Check BIOS settings for boot order,
And lastly have your BIOS rescan your HD or
Reset your BIOS to defaults.....
To enter the Bios (see your computer screen at power on, your manual, or manufacturer's web site) you probably have to press something like the DEL Key, or one of the F Keys at boot up time, but the actual Key varies from model to model. Many computers refer to this as "Entering Setup", Setup is just another term for the Bios.
Setting your Bios to any safe default settings may also fix this for you.
Feb 03, 2018 | Acer Computers & Internet
How to disable HDD Bios password in dell Optiplex 990?
The easy way to clear the bios password and reset bios is to take out the bios battery and start computer for about 10 seconds and then turn it back off and replace the battery. When you turn it back on you may need to go into the bios and reset everything the way you want it, and don't forget to rest the time and date.
You are welcome
Aug 30, 2015 | Dell Computers & Internet
How to change to a different date in advanced booting options
To change your system date through Advanced Booting options, you first need to enter BIOS setup menu of your system. To enter BIOS setup menu and to change your system date, you can follow the instructions below:
1.Boot your system and enter BIOS setup menu using the designated key. Though the key to enter BIOS may vary depending upon the computer manufacturer, usually keys like Delete, F12, F10, and F2 are designated to enable a user to enter BIOS setup. To know how to identify the key your system is designated to enter BIOS setup, you can refer to the image under "Method 1 of 3: Enter the BIOS" section on the following webpage:
Important: Following link is of a third-party website. We recommend you to update your security software thoroughly before clicking on the link.
http://www.wikihow.com/Change-Computer-BIOS-Settings
2.As soon as you identify the BIOS setup key, strike it rapidly and repeatedly (while the booting is on) till the time you enter BIOS setup menu. You may get just a few seconds to do this. If you are not able to enter BIOS setup menu by pressing the key repeatedly, reboot your system and follow the same steps again to enter BIOS setup menu.
Note: BIOS menu do not support mouse input. Hence, you will have to navigate through the menu using the arrow keys on your keyboard.
3.Once you enter BIOS setup menu, you can change the date of your system by going to "System Date" option. This option is generally located in the "Main" section of the menu.
Important: The layout of BIOS menu varies from manufacturer to manufacturer but most of them share a few common settings. If you are not able to detect "System Date" option in the "Main" section of the menu, you may need to look into other sections to locate the option.
To get a pictorial explanation of the above steps, you can refer to the following link:
Hope this will resolve your issue.
GuruAid.com
Aug 09, 2014 | Dell Microsoft Windows XP Home Edition
Power but no display
try going into bios blue screen press f2 or f10 or f12 on start up beep . change setting in video settings
  1. Watch for a "entering setup" message in the first few seconds after turning on your computer. This message varies greatly from computer to computer and also includes the key or keys you need to press to enter BIOS.
    Here are some common ways you might see this BIOS access message:
    • Press [key] to enter setup
    • Setup: [key]
    • Enter BIOS by pressing [key]
    • Press [key] to enter BIOS setup
    • Press [key] to access BIOS
    • Press [key] to access system configuration
  2. Quickly press the key or keys instructed by the previous message to get into BIOS
Oct 22, 2013 | Biostar Computers & Internet
Remove toshiba password from bios satellite 3000-x4
The Basic Input/Output System (BIOS) password is not set by default on Toshiba laptops. When set, the BIOS password must be entered every time you turn on your Toshiba or wake your system from Standby mode. If you forget the password, you cannot boot your system. Prevent having to enter a password or the results of forgetting the password by removing the BIOS password from your Toshiba laptop. Other types of passwords can be set, such as a Windows password, to prevent unauthorized access to your machine.
1. Turn off your Toshiba laptop.
2. Wait 30 seconds and turn your laptop back on.
3. Press "F2" repeatedly as soon your Toshiba laptop begins booting until the BIOS menu screen appears.
4. Enter your existing BIOS password and press "Enter."
5. Press "F2" again to enter the BIOS, if prompted.
6. Use your arrow keys to select the "Security" tab in the BIOS menu.
7. Use the arrow keys to select "Set User Password."
8. Press either "F5" or "F6," depending on your Toshiba laptop model, to open the Password section.
9. Enter the current password into the "Old Password" prompt and press "Enter."
10. Press "Enter" when the "New Password" prompt appears. Do not enter any text in this box.
11. Press "Enter" again to confirm the new password.
12. Press "F10" to save your changes and exit.
I hope you find it very helpful. Best regards.
Aug 16, 2011 | Computers & Internet
When i enter BIOS there is no way to set the boot device and just say after exit "install boot media and try again"
you can change a few settings in BIOS but as long as you can remember what changes you have made so if anything goes wrong you can restore bios to original settings
enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
hope this helps
Dec 15, 2010 | Evga H55V (111CDE630TR) Motherboard
How do i rmove a bio password out of my toshiba satellite m305-s 4910 laptop
B I O S P A S S W O R D
Setting the BIOS Password
There are two main varieties of BIOS used in Toshiba notebooks, each with its own unique method for setting and disabling a password. First, determine which type of BIOS is used in your notebook model, as follows:
Starting with the computer fully off, turn it on by pressing and releasing the power button.
Immediately and repeatedly tap the Esc key. If the message "Check System and press the F1 key" appears, then follow the "Esc key BIOS" procedure, below.
If the computer ignores the Esc key when it's powered-on, or if you see an invitation to press the F2 key to enter the BIOS Setup utility, follow the "F2 key BIOS" procedure, below.
Almost all Toshiba notebook computers will respond to either the Esc key or the F2 key when they're first powered-on. The Toshiba HWSetup program (found in the Windows Control Panel) may also be used for setting and disabling the BIOS password. See the HWSetup procedure, below.
To set a BIOS password, start the BIOS Setup program and enter a new password into the password field, per the detailed instructions below. Once a BIOS password is set, it will be necessary to enter it whenever the computer is started, restarted or reset. Choose a password that you can reliably recall, or make note of it in a secure location. If you forget the BIOS password, only a Toshiba Authorized Service Provider can remove it.
ESC key BIOS Password setting procedure
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the Esc key, until the message "Check system. Then press (F1) key" appears on the screen.
2. Press the F1 key. The BIOS setup program will appear.
3. Using the arrow keys or the tab key, move to the Password field, and highlight NOT REGISTERED.
4. Press the spacebar, and then enter a new password at the "Password = " prompt. Press the Enter key.
5. Enter the password again when the Setup program prompts for it, and press Enter. The Password field will change to REGISTERED.
6. Press the End key and then the Y key to save changes and exit the BIOS Setup program.
F2 key BIOS Password setting procedure
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the F2 key.
2. The BIOS setup program should appear. If Windows starts, shut down the computer and try step 1 again.
3. Use the arrow keys to move to the Security tab.
4. Use the arrow keys to select "Set User Password". (This 'User Password' is equivalent to what is otherwise called, in this document, a 'BIOS Password'.)
(It may be necessary to set a supervisor password before setting a user password. A Supervisor Password may be thought of as a backup mechanism -- if a User Password is forgotten, the Supervisor Password will allow access to the computer. The next section describes how to set a Supervisor Password.)
5. Press the F5 or the F6 key to navigate to the Password section. Type in a new password at the "Password = " prompt, and then press the Enter key.
6. Enter the password again when the Setup program prompts for it, and press Enter. The password field will now change to indicate that a password has been entered.
7. Optionally, set the Password on Boot feature to 'Enable'. Otherwise the computer may not prompt for the password at startup.
8. Press the F10 key to save changes and exit the BIOS Setup program.
HWSetup BIOS Password setting procedure (This method works for most notebook models.)
1. In Windows, click Start, then Control Panel (or Start, then Settings, then Control Panel).
2. In Control Panel, click on the icon for HWSetup or Toshiba Hardware Setup.
(If neither of these icons are present, download and install the Toshiba utilities for your model from the Service and Support Website, or use the appropriate BIOS Setup procedure above.)
3. Click on the Password tab.
4. Click to select Registered. Alternately, there may be a choice for User or Supervisor Password. Select one or the other
5. Enter a new password at the "Password = " prompt, and press the Enter key.
6. Enter the password again when the HWSetup program prompts for it, and press Enter. The Password field will now say REGISTERED or SET.
8. Close the HWSetup program.
_______________________________________________________________________
Removing the BIOS Password
Follow one of the procedures below to remove a BIOS Password. See the section 'Setting the BIOS Password', above, to determine which type of BIOS your computer has. Once the password is removed, the computer will no longer prompt for a password when it's started. Removing the BIOS Password requires you to enter it first. If you cannot recall the BIOS Password, only a Toshiba Authorized Service Provider can remove it.
ESC Key BIOS Password removing procedure
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the Esc key. The computer will display the "Password = " prompt.
2. Enter the correct password, and press the Enter key. The computer will display "Valid password entered, system is now starting up. Check system. Then press (F1) key"
3. Press the F1 key. The BIOS setup program will appear.
4. Using the arrow keys or the tab key, move to the password field, and highlight REGISTERED.
5. Press the spacebar, enter the correct password, and press the Enter key. The Password field will change to NOT REGISTERED.
F2 Key BIOS Password removing procedure
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the F2 key. The unit will display the "Password = " prompt.
2. Enter the correct password, press the Enter key. (You may need to press the F2 key after you hit the enter key.)
3. The BIOS setup program will appear.
4. Using the arrow keys, move to the Security tab, and to Set User Password.
5. Press the F5 or the F6 key to navigate to the Password section. Enter the current password at the Old Password prompt, and press Enter. At the New Password prompt, press Enter (without typing anything into the password field). At the Confirm Password prompt, press Enter again (without typing anything into the password field). The password should now be removed.
6. Press F10 to save and exit from the BIOS Setup program.
HWsetup BIOS Password removing procedure (This method works for most notebook models.)
4. Click to select Registered. Alternately, there may be a choice for User or Supervisor Password. Select one or the other.
5. Enter the current password at the "Password = " prompt, press the Enter key. If the HWSetup app prompts for the current password and then twice for the new password, simply press the enter key three times after entering the current password. By pressing the Enter key only, you are selecting no password.
6. HWSetup should now show that the password is Unregistered, which means there is no password set.
7. Close the HWSetup program.
Trus this is helpful. Please vote. :)
Dec 12, 2010 | YouTube Videos
BIOS SETTINGS
Usually you can enter on your BIOS Settings by pressing F2 or F11 on some PCs. When the computer boots, before it enters into your operatng system, press F2 or F11. Please rate if this would help you.
Feb 04, 2010 | HP Compaq ProLiant ML530 Server
Which keys let me enter my bios settings on my philphs MT1400 ?
WHEN U START UR COMPUTER, THEN AT THE TIME OF BOOTING, PRESS DEL KEY CONTINUE, UNTILL UR COMPUTER ENTER IN BIOS SETTINGS, U WILL SEE A BLUE COLOR SCREEN, WHEN UR PC WILL ENTER IN BIOS SETTINGS.
I HOPE U WILL GET THE SOLUTION.
Nov 07, 2009 | Computers & Internet
How to set the security lock in laptop
plz specify the model and make
and also specify if it is a physical lock or the lock on your windows
May 01, 2008 | Computers & Internet
Toshiba 2540CDT, 2545, 2545CDS (610074362708) Logo
35 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
