Question about Maytag Refrigerators
Mfi2067aeb water and ice stopped working
Making lots of noise in previous weeks, water flow was slowing, heard a loud pop noise and a couple hors later i noticed the water and ice would not come out when the lever was pressed. fridge and freezer are woking fine. I cleaned all around and under and replaced the filter, What now?
HVACRH20
  • 237 Answers
SOURCE: water dripping from freezer to fridge
Sounds like the drain for the defrost cycle water may be plugged and you eventually overflow water. See if you can find the little drain hole for the coil defrost water and check for dirty/plugged. Try to pour hot water in the drain area and see if it runs out the drain fast (if real slow it's a problem). Make sure the water is also going down to the holding pan near the bottom area/compressor area (that's where it evaporates later). Let me know what you find.
Posted on Nov 30, 2006
catriver
  • 878 Answers
SOURCE: Maytag MFD2561HES
Texas, sounds like your water reservoir is frozen up. Remove your 2 cripser drawers, you will see the reservoir behind them. Take a hair dryer and go over the tank and tubing ends. See if the water starts flowing. I find a lot of frozen water reservoirs on these french door models. They have a insulation kit for them. Catriver.
Posted on Sep 29, 2007
  • 150 Answers
SOURCE: SAMSUNG RS253BAWW NOT WORKING
the ice maker wont cycle untill the temp of the ice is around 10 degrees so if the freezer is at 15 or 20 due to some other malfunction then you will see the maker full of ice but it wont harvest and make another batch. so you could have a sensor bad, control malfunction, refrigeration issue, compressor, defrost system malfunction(you mentioned ice build up)
Posted on May 08, 2008
  • 33 Answers
SOURCE: Amana Side-by-Side Fridge Model SBD21VPSE
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
Posted on Nov 29, 2008
appldoctom
  • 311 Answers
SOURCE: amana side-by-side fridge freezer only cold at the bottom
yes the evap fan in the frezer should be running when the compressor is running[it may not for a minute or so as it starts up.Amana's are good for the connectors at the evap fan motor comming apart.the connectors are white and will look like its together but when you pull it will come apart.i would always cut the connector out and use a wire nut so wont happen again.if any other questions please email thru FixYa and i will be glad to help. God bless ,tom
Posted on Jan 30, 2009
Why is ice maker loud when filling tray and water flow slows down?
perhaps you need to leave it turned on all the time . thry were not made to be run as a part time unit .
Apr 04, 2016 | Refrigerators
Why would my ice maker stop making ice?
Diagnostics does not tell you the water valve opens it only tells you the power was applied to the water valve
APPLIANCE 911
Jan 07, 2016 | Frigidaire Gallery Stainless Steel French...
Refrigerator not as cold as it should be, freezer too cold and has some frost
check the fan should be run in freezer & its air flow clear to refrigerator side,no blockage items or ice in its way oy of air flow
Jul 07, 2014 | Amana Refrigerators
Kenmore model# 106.9547651 ice maker has stopped working; water dispenser works.
A valve controls water flow into the ice trays. It is a common source of the trouble you describe. You may be able to get an overhaul kit for just the valve
Dec 26, 2012 | Kenmore Side by Side Refrigerator
We have a GE profile side by side refrigerator with the freezer on the bottom (model PFSS6PKW). It's not quite 4 years old yet, but we've been having issues with low water pressure from the water...
you may have a restriction in the water line ( after the valve and it may be in the water storage tank .. it may be ice and it will block the line some what . to slow the flow .. if not ice it may be sediment / these are the most common found .. .. i would clean the lines or replace them .. . if pressure is ok at the main inlet line .. ..mm hope this helps mm
Jul 11, 2011 | GE Refrigerators
My Maytag refrigerator makes a loud popping noise. It woke me up at 1 am. Refridgerator is 10 years old no ice maker. The sound is pretty loud. Is this a bad sign? Is there any danger here? Should I be...
the popping noise you're talking about, could it just be your self-defroster in operation,sometimes if there a lot of ice and it operates a long time, there could be expansion noises,such as the refrigerator walls expanding/contracting from the heat of the defroster,if it's water you will hear a sizzling popping sound,nothing to fear dear
Dec 08, 2009 | Maytag MSD2756G Side by Side Refrigerator
The the refrigerator just stop working
a new fridge is probibly needed. The sounds you heard was possibly the reeds in the compressor that were going bad. Good Luck
Dave
Jul 24, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Zanussi Electrolux frost free fridge/freezer - freezer defrosting
My husband left the freezer door open a couple of months ago, causing ice to form. The loud rattling noise was the fan hitting the ice. The reason why the temperature started to rise but the noise stopped was because the fan had got stuck in a block of ice and was no longer working. Simple solution - defrost the freezer for 24 hours. Touch wood, it is all working fine now!
Aug 29, 2008 | Zanussi ZI921 / 8FF Bottom Freezer...
Loud periodic buzzing
Are you sure this noise is not just the ice maker trying to cycle without water? If it is not turned off it will dry cycle every 15 min or so.
Jan 18, 2008 | Samsung RB2155 Bottom Freezer Refrigerator
Kenmore side by side refrigerator
Check the water valve in back of refrig.. u have a double valve... one side for water the other side for your ice maker.. make sure ice maker valve is working.
Sep 11, 2007 | Kenmore 57029 Side by Side Refrigerator
Refrigerators Logo
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
