Question about Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360)
Xbox 360 wireless adapter
I got a wireles adapter 3 weeks ago and it work fine all of a sudden it doesnt work at all. i try plugging it in and the light on the adapter turns green for a split second then turns red why wont it work?
  • 3 more comments
  • Anonymous Dec 10, 2008
    I've had my wireless adapter for some time. A year maybe a little less. I was playing on Sunday and it worked fine, then on Wednesday it stopped working. I scanned it for networks and it comes up with nothing even though the router is just in the other room. The light is red but when I turn the xbox on it turns green for a split sec.
  • marcjones9 Dec 13, 2008
    ive had it 4 like a yr. it worked but when i moved it stopped working
  • oudavid1 Dec 26, 2008
    its red for a second, less than that, as soon as i plug it in, any port, and type of usb.
  • brayanhernan Mar 20, 2009
    the gren light apears for a secon ond then goes away
  • shpankey Mar 25, 2009
    network adapter quite working. red light on all the time now.
My network adaptor arrived today. I'm just updating it now...I plugged it in and it worked fine, started the xbox live update, then stopped. I checked and a red light was on. I unplugged it and put it back in, the same thing happened to me, a green light flashed up for a split second. So i wiggled it about a bit and managed to get it to work now...give it a go.
Posted on Dec 30, 2008
Hardware diffuculties send it back
Posted on Nov 30, 2008
I cant connect to xbox live
The red meant it was ready for configuration. If there is no light it means it is not receiving power. Try plugging it in again, or plugging it in to a front USB slot. If it still doesn't work your adapter has a defect and should be replaced.
Dec 30, 2009 | Microsoft Wireless Network Adapter Xbox...
Xbox 360 Wireless adapter no power
try to use the front USB ports if this wont fix it you will have to send the adapter back to the CO or the store where you got it
Jul 20, 2009 | Microsoft Xbox 360 Console
Xbox360 picture is too bright
I just had this same issue when i bought an Xbox 360 a week ago or so. Everything was WAY too bright but only on the Xbox. After some checking and rearranging of cords i found that the RF Modulator (adapter) i was using was set to the wrong resistance (Ohms) as i plugged in the Wii and had the same issue. I would say check the resistance setting and channel on the adapter, also making sure to NOT use "Y" rca cables to have more than one thing plugged into the same input.
Hope this helps ^_^.
Apr 10, 2009 | Microsoft Xbox 360 Elite Console
Are all xbox 360's able to connect to wireless broadband
Yes, with the wireless adapter, and wireless router, any Xbox 360 can go wireless.
Go to "My Xbox" -> "Network Settings" -> "Configure Network", the Xbox will ask you a few things about your network, and that's it. You should be connected pretty easily.
Mar 19, 2009 | Microsoft Xbox 360 Console
My light stays red never turns green
This means that it hasnt connected to a wireless router. Make sure your router is wireless, that you have searched for you network and found it. If this still doesnt work then make sure that your routers wireless capabilities are working and try entering the settings in manually to the xbox 360 network settings.
Jan 17, 2009 | Microsoft Wireless Network Adapter Xbox...
X box 360 wireless adapter
go to amazon.com look at theyre adapters for the xbox they say it works for $45.00
Jan 02, 2009 | Microsoft Wireless Network Adapter Xbox...
Xbox wirless adapter
I had the same problem last week. Xbox Support says I need a new adapter, so I figured I would tinker around with the broken one. On the USB connector itself, there is a outer stainless shroud, and the inner black piece with the gold contacts on it. What happens is the wifi adapter contacts no longer touch the console contacts, hence the light never comes on and the console doesn't recognize it. I stuck a screwdriver between the stainless shroud and the black connector plate, and made the gap a little bigger, now the adapter works perfectly. I think this is a design flaw, as I never move the console or adapter, but over time, the pressure from the USB cable makes the contacts loose and it eventually no longer touches. Saved me $100 bucks.
Dec 30, 2008 | Microsoft Wireless Network Adapter Xbox...
Xbox adapter
your problem may be as simple as auto sign in disabled, you have probally alredy solved this but i will let everyone else know the solution if you whack the guide button, and go over to settings, if your using the xbox NXE dashboard, then click Profile, Then scroll down to auto sign-in and click there, and there shoul be a xbox live bit, make sure its enabled other wise you have to do it manually.
Nov 09, 2008 | Microsoft Wireless Network Adapter Xbox...
Xbox 360 wireless network adapter
Turn off the console. Take out the adapter and plug it into the ports on the front of the xbox 360. if this doesnt work, you will need a new on.e
Jun 23, 2008 | Microsoft Wireless Network Adapter Xbox...
Open Questions:
See all Microsoft Wireless Network Adapter Xbox 360 Questions
Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360) Logo
538 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
