Question about RCA 6' Video/Optical Combo Cable -- DT6VHP
Tv will not change channels
The tv will not go into the scan channel in the memu after the power went off early one morning.
  • Debra Ethridge Aug 25, 2006
    I unpluged the tv for over 12 hours and took the batteries out of the remote at the same time and I held down the #1 key on the remote to drain the microprocessor inside the remote. The channel numbers appear on the tv screen, but will not change the channel. I have gone into the menu several times setting up the tv, but nothing changes. We turn on the VCR in order to change the channels. Everything else works fine on the remote and tv except for changing channels.
    President:
  • 3,130 Answers
Unplug unit from the wall for several hours and try again
Posted on Aug 23, 2006
  • Larry  Dillon
    Larry Dillon Aug 29, 2006
    Sorry my magic wand is in the shop. Take the unit into the shop!!
Stuck on one channel
Is it the tv's remote? Change the batteries
are you on a cable box? You need to use the providers channel changer. Tv is made to stay on one channel like channel 3 and the cable box runs the different channels.
Dec 01, 2015 | Vizio L32 32 in. LCD HDTV
My universal remote went out and somehow the tv-a Sansui-got switched from channel 3. How can I get it back to channel 3 so the converter will work? I tried changing channels manually at the tv but it...
Look in the owner's manual for instructions on having the TV scan channels. Make sure the converter is on before starting the scan. If that doesn't work, you'll have to buy or borrow a universal remote to take care of it (enter 3, 03 or 003 on the remote control). This will happen every time you remove power to the set, whether it is unplugged or you have a power failure, so start saving up for a new remote control.
Dec 07, 2010 | Sansui 27" TV
I rescanned my mothers TV this morning then went through all the channels to make sure they were all present.Everything was fine until I went through the channels again and found that I had lost ITV1.The...
Try to manually add cahn 3 or 4 to the lineup. if there is a reciver installed with a coax cable then it should show up on cahn 3 or 4. also you can also try entering the cahn number manually such as pressing zero, three on the keypad or whichever chan you a re trying to access.
Nov 04, 2009 | DISH Network 311 DTV Receiver
No picture - 65535 shows on screen
My 42" Dynex just did the same thing. 65535 NO SIGNAL.
The channel label for this said "ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ"
I went to menu... Channels .... Set for Cable TV... Scan Channels.
It rescanned. It took twice as long as normal to scan.
After the scan completed it worked fine except of one thing.
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ stuck on the screen.
I shut the TV off, then things returned to normal.
Hope this helps.
Notes:
This TV is only 6 weeks old.
Cable hook up.
It is -plugged into a brand new UPS power supply.
I used the sleep timer to shut off TV. The 65535 problem occured the next time the TV was powered up.
Nov 22, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
VIzio channels won't change
press the menu button in the middle of your remote and scroll over to the middle tab that's labled "TV" and then scroll down to "auto search". click on this option by pressing the right arrow key on your remote so that your T.V. and "re-scan for channels. It might take awile. I took me about 5 minutes but for majority of the time it was stuck on 45% while it was scanning.
Jun 28, 2008 | Vizio L32 32 in. LCD HDTV
Changes Channels
Need to know model number and date of manu.  You may have bad control assy due to spills or cleaning of screen and liquid went into screen and buttons. will effect remote also
www.classtorations.com
Jun 03, 2008 | RCA P52937 52" Rear Projection Television
My tv
My tv will not turn on. We had been away for a week and no power interuption at home. We have unpluged the tv for short and long periods of time . We we attempt to turn the power on it cuts off by itself.
Mar 01, 2008 | Televison & Video
Cannot watch channels past 13
Your tuner settings must be set on broadcast instead of cable. Below channel 13, they use the same frequencies so it doesn't matter. Find the tuner settings page in the menus and change the cable/air setting.
Jan 06, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Tv wil not change channels unless vcr is on
You must go into the menu, go to the channel setup and do a channel scan.. Your TV simply lost the channel memory. Good Luck
Aug 16, 2006 | RCA 6' Video/Optical Combo Cable -- DT6VHP
Televison & Video Logo
60 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
