Question about Zyxel NBG-415N Router
Low signal after firmware update
After updating the firmware of my NBG-415N router the wireless signal is extremely low, where it used to be very strong. Any help would be appreciated.
    Problem Solver:
  • 6 Answers
Set the router to low or medium, save, then set to high. This model does this occasionally after a firmware update.
Posted on Jul 01, 2009
    Genius:
  • 1,269 Answers
It is recommended to hard reset the router every after firmware update. Look for the reset button normally at the back of the router. Press and hold it down for 20 seconds then release, then unplug the power for about 30 seconds then plug it back in. That should fix it.
Posted on Oct 27, 2008
Access zyxel configure
From the manual:
Follow the steps below to log into the web configurator.
1 Start your web browser.
2 Type "http://" and the IP address of the ZyXEL Device (for example, the default is
192.168.1.1) in the Location or Address field. Press [ENTER].
3 The login screen appears. Select admin in the User Name field to log in as an
administrator.
4 Enter the associated password. The default administrative login password is "1234".
Link to manual:
ZyXEL Communications ZyXEL NBG 415N User Manual Chapter 2 The Web...
Jul 09, 2014 | Zyxel NBG-415N Router
My computer recognizes the wireless network that I have set up with my NBG-416N Router, and my internet works when I plug into the ethernet. However, I can not get any internet from my wireless.
Is it enabled on your laptop? It can be turned off! All laptops are different, some have a switch or on/off button for the wireless receiver, some use a keystroke/combination. Look for picture of radio signal on your F-keys, if you find it, hold down the FN key and tap the radio key, it will toggle it on then off.
Aug 26, 2011 | Zyxel NBG-415N Router
My signal strength is very low
You Can Try Changing the Wireless Channel on the Router you have 11 Different Channels Available.
> Steps to change the Channel
- Open Internet Browser on Hard wired computer & Go to 192.168.2.1
- Towards your Left Corner Under Wireless Click on Channel & Ssid
- Leave the Password Blank Click on Submit
- Change the Wireless Channel To Number 1 or 6 or 11.
- Click on Submit
- Check the Signal Strength
- If you Still Have Low Signal Strength you Can Try Updating the Firmware or Changing the Wireless Mode to G only... :)
Mar 06, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
ZyXEL NBG-419N Wirelss N Router. I'm having connection problems with this router. We have a laptop running Windows 7 and the kids play on X-Box live. It worked fine for a couple of months but now we...
When you get that symbol in Windows 7 it usually means that there is no internet connection. You can be connected to the wireless router but still not get on line if the wireless router has lost the internet connection. Probably your best bet will be to update the firmware on the NBG-419n. The only firmware sometimes had issues staying connected to the Internet through some modems. First you will need to download the firmare. Here is a direct link. Firmware Then you need to log into the router. It will be best if you are on a computer that is connected by Ethernet to one of the LAN ports on the router. Open up Internet Explorer and type '192.168.1.1' into the address bar. You should get the login page for the NBG-419n. Default password is 1234. Once logged in click on Expert Mode at the top right corner of the page. Then click on the maintenance icon on the left side of the screen, then click the Maintenance heading to drop down the list, then click on Firmware Upload. Once in there click Browse and select that BIN file. Then click Upload. The firmware upgrade should take a couple of minutes. Once it is done you may want to power cycle your modem for a couple of minutes and then see if you can get on line. This should help with any connectivity issues.
Feb 22, 2011 | Zyxel (91-004-361002) Wireless Router
Trying to setup wlan with wpa-2 psk but the router disconnect the computers all the time. I double checked the WPA-key. I tried wpa also, but he same problem. When using no security it works
HI,
Its the problem witht the Firmware of the router, ie error in the software installed inside the router..
Try updating the latest firmware from the manufacturer website..This should solve your issue..
Please rate this solution if this solves your issue, or leave me comment ill help further
RNJ VINODKUMAR
Dec 17, 2009 | Zyxel NBG-415N Router
NBG-419N can not connect to the internet thru router?
Have you connected your Zyxel to your cable/DSL modem? Is your access problem issue with Wireless computers? The first thing you must do with a new router is to set it up, using a CAT-5 cable connected to the router. Connect it to http://192.168.1.1 and proceed through the setup items, after logging in to the router. One of the more important items, Security, must be set up by choosing your network name (SSID) and security passwords --- I prefer using the WEP-PSK[TKIP] for its simplicity. You will need the passcode you choose whemn you try to access the router wirelessly, once this is set up. Not too much access unless this is done. Use this as a guide:
http://www.zyxel.com/guidemo/NBG419N/local/networkmap.html
Nov 10, 2009 | Zyxel NBG-415N Router
We've been using the MN-500 router for over 5 years without issue. Recently, the signal strength seems to have diminished. Router is in the basement. We used to be able to access from our first and second...
This is a common problem. There are two ways on how to fix this. First, update the firmware of your router. You can download the firmware from Microsoft download site.
Before you install the router's firmware, you must do a hard reset. Press the reset button at the back of the router for 30 seconds then unplug the power for another 30 seconds before you plug it back in.
Access the router's admin page through http://192.168.1.1 and look for firmware update settings.
After successfully updating the firmware, you must do a hard reset again. Reset for 30 seconds then power cycle it.
2nd
In fixing low signal strength, you'll just need to change the wireless channel on the router's admin page. Access the router's admin page through http://192.168.1.1 and look for wireless tab, change the channel to 11 and save the settings. If you have cordless phone you need to relocate its base away from the router.
Aug 05, 2009 | Microsoft Broadband Networking MN-500...
Very low signal (wireless maxg adsl gateway usr9108)
Have you tried changing the channel? This might help icrease your signal aslo avoid putting it near wall and if possible put somewhere higher (5-10 ft above the ground)
May 01, 2009 | U.S. Robotics USRobotics USR5461 Wireless...
When router set with security key, signal too low, end up on someone elses
desirabledes hello,
Please go to the edimax website and download the most recent firmware to the router:
http://www.edimax.com/en/support_download.php?pl1_id=1
Then, try to update the driver to your wireless lan card, this might be causing the problems.
Oct 12, 2008 | Edimax BR-6216Mg Wireless Router...
Zyxel NBG-415N Router Logo
409 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
