Question about Evenflo Baby Gear
Cant remember how to put toddler bed together and need screws
I have a toddler bed that says from 1990 but I dont have the right screws for it and I dont remember how to put it together right. I dont remember what the screws looked like or anything, i bought it for my daughter 4 years ago and I would like to use it for my son but I cant get it together. I think I have all the pieces, I have 2 inside and 2 outside rails and the head and foot boards, the wood part for the bed, and 5 legs but dont know if I should have five or more???
SOURCE: Converting to toddler bed
simplicityforchildren.com has replacement parts
Posted on Nov 18, 2007
SOURCE: Toddler Bed Side rail for Delta Luv 5-in-1 crib
Try calling the customer service number (212)-645-9033. I have not called them yet to get the conversion rails for our Delta Luv 5 in 1, but I'm hoping that they will know more than Babies R Us!!
Posted on Sep 29, 2008
SOURCE: changing from a crib to a toddler bed
1-Lower drop side to lower position. Then on the opposite side of the crib, remove stationary side. To remove stationary side, press the small tab on the end hardware(brown plastic piece that connects the rail to the frame) and then pull rail up.
2-Before reinstalling the conversion safety rail(csr), remove the mattress support bolt that is on the side the the csr opening will be(the foot of the bed). A new bolt will be used to reattach the mattress support in the next step.
3-Slide csr hardware onto the hardware on the crib ends. Insert two 1/4-20x2" bolts into each end. One bolt will replace the mattress support removed in step 2. Be sure to put the bolt back through the mattress support bracket before screwing into the end.
I have the instruction page with pictures if you would like a copy emailed.
jmsmith2003@msn.com
Posted on Nov 09, 2008
SOURCE: Bed rails for Delta Martine Crib
I have this crib for my own child. I ended up buying a guard rail from Walmart. If you tie a knot in the strap after putting it through the rails and then tuck the disc between the side of the crib and the bottom of it, it seems to work just fine. Child has been using it as a toddler bed for well over a year now and there has never been an issue. Chiild is a restless sleeper too. So, I know it works.
Posted on Apr 07, 2009
SOURCE: Model 4624-1 Delta Luv Crib
If its like mine, you just remove the front panel that went up and down. Then lower the wood mattress support to the lowest level. You are now ready for the toddler bed. Once you want to convert to a double bed frame. You have to purchase a metal frame that holds the bed. Then attach the back and the front to the metal frame. This should like a sleigh bed. Good Luck, Nicol
Posted on May 06, 2009
Dorel #TB-722W
Here is a pdf for a Dorel toddler bed.
It should help you put your one together, even if it isn't exactly the model that you have.
Good Luck
http://www.krenim.org/jeff/WM1646-Dorel-Asia-SRL-Toddler-Bed.pdf
Sep 05, 2012 | Baby Gear
I have vicki 4 in 1 convertible bed.i dont have the manual
Hello! This is Products America. We service most crib hardware. The number to Sorelle is 201-531-1919. You could call them and see if they still have a copy that they could send you.
Oct 05, 2009 | Sorelle Vicki
Cars Toddler Bed problem
mcdevito75 here, Use the contact info in the istruction manual you have, and speak with Disney.
Jun 06, 2009 | Disney Pixar Cars Toddler Bed
Delta luv jasmine 4852 crib 5-1......why no TODDLER bed instructions
Hello!
I understand your frustration as I have put many children's toys, cribs etc. together over the years. It appears that the extra piece that you will need will be a twin bed frame. It is not included.9b1e880.jpg
Oct 08, 2008 | Delta Luv Jasmine 4852 Crib
Convert crib to toddler bed
I finally found my instructions!! It's actually really easy to convert to a toddler bed:
Step one: Take out four screws (two on each side) of the front railing and top bar. They are the screws holding the front railing and the top bar to the side of the crib and the dresser.
Step two: Lower the mattress to the lowest setting.
Step three: Place the toddler bed railing in place. It can go either way depending on which side of the crib your toddler sleeps. We put the taller part of the toddler railing closest to the dresser because that is where our son's head usually is.
Step four: You'll need 4 1.5 inch hexagonal screws to screw in the toddler railing. After 2.5 years, I could only find two of them, so I used two 1.5 inch regular screws that came with the crib. On the taller part of the toddler railing -- the screws go into the 1st and the fifth holes. On the shorter side of the railing, the screws go into the 3rd and the 5th holes.
That's it.. You've now got a toddler bed!
Apr 26, 2008 | JCPenney All-in-One Nursery Crib
Crib together
I have lexington 3-1 crib would like to change to toddler bed
Nov 11, 2007 | Childesigns Madison Crib
How to convert crib to bed
I have the opposite problem - I can put it together as a toddler bed. The trick with that is that you put one of the long screws through both the hole at the SHORT end of the toddler bed side AND the metal flange from the springs into that end of the crib. The other long screw goes through the raised end of the toddler side into the end of the crib - where the child's head would be.
Is there supposed to be a plastic piece at the top of both ends of the crib on the side that does NOT go up and down? I can't seem to figure out how to put the crib side on.
Nov 03, 2007 | Childesigns Bellmont Crib
Baby Gear Logo
49 people viewed this question
Top Evenflo Baby Gear Experts
Joyce Nokleby
Shehu Pro
Shehu Pro
Rick Moore
Rick Moore
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
