Instructions for newlec panel heater
It is a panel heater with no model number
3 Suggested Answers
SOURCE: hi i require the full
Hi. This is a rebadged Megger LT7. The manual is here:
http://www.biddlemegger.com/biddle-ug/LT7_UG.pdf
Posted on Nov 30, 2011
  • 274 Answers
SOURCE: I meed instructions on newlec NLSH24AN HEATER
get a Haynes repair manual
Posted on Nov 24, 2014
Freezer is not getting cold
Can you remove the rear panel you see the ice buildup on the evaporator? I believe your refrigerator has a defective defrost element. You need to unplug refrigerator remove the panel and see what type of frost pattern you have. Here is a link to what you may see behind that panel=> HERE This is a link to what you said you see with frost on the rear panel=> HERE Can you confirm that your refrigerator model number is GSL25JFPBS? Look around the fresh food section door for your model number. Here is a photo HERE with the locations number 230 is the defrost heater=> WR51X10055 Defrost Heater Assembly
And location number 240 is the defrost thermostat=> WR50X10068 Defrost Thermostat
I would like to know what frost pattern and the true model number of your refrigerator so I can help you better. If it has the frosted over evaporator like in the photo above you can defrost with a hair drier and the refrigerator may cool again up to a week until you can replace the defrost heater and defrost thermostat. How to test these parts can be found on the same page as the part numbers I posted here, Thanks Sea Breeze
Jan 29, 2013 | GE GSL25JFPBS Side by Side Refrigerator
E02 comes up on display on my Siemans dishwasher
The model number is usually plated on the left inside panel of the door, however, that is not always true and could be at the back which is hard to get to unless you take the dishwasher out.
The E02 error with Siemens dishwashers would mean the washing is happening without the heater turning on. This means the dishes may not be coming clean, the wash cycle is long and dishes do not dry.
It is linked to heater relay in control unit being faulty and could be also related to the heater itself being faulty. Worst case both are to be replaced.
A very costly affair. Would help if you can find the model number.
Dec 29, 2012 | Dishwashers
I purchased a Rinnai Panel Heater EPH10DTW today from the GoodGuys. There was no instruction Book or Warranty Papers in the box Could I get an instruction off the Internet
Unfortunately, the model number you listed for the Rinnai Infrared heater, does not match any of the Rinnai heater models.Or it is a discontinued model. Check the Manufacturer's Data Plate on the side or rear of the unit for the exact model number and get back to me.
Thanks for choosing FixYa.
Aug 18, 2011 | Heating & Cooling
Where are the heating elements on an 80 gallon electric water heater? Model number : E 2 F8 0 H D 0 4 5 V
I don't know that model number.
Tank-type water heater elements are located behind panels on side of tank.
Open following link to help troubleshoot electric water heater problems:
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
The water heater label also shows element wattage, brand, voltage, serial number, and type of operation.
For example 5500W elements, non-simultaneous, 240V are typical ratings found on water heater.
5500 Watt would be replacement element size.
Non-simultaneous would indicate that both upper and lower element are not turned ON at same time.
240Volt is typical voltage for water heaters.
Serial number carries date-of-manufacture, based on brand.
For common brands:
http://waterheatertimer.org/pdf/WaterHeaterSerialNumberDecoder.pdf
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 13, 2011 | Whirlpool Water Heaters
I am looking for an instruction manual for the Dimplex OFC2411TIF Oil Heater
Carly, the owners manual for the model number you listed is not available online. However, if you call Dimplex USA, Technical Service 888-346-7539, they can help you.
Apr 06, 2011 | Dimplex EF12 Electric Wall Mounted Panel...
On the side of the ceremic panels, a piece has fallen off and the gas/heat is "spitting" out. this happens on the high selection only. are there replacements for the ceremic tiles? I have a wall...
It's time to clean the interior of the heater and replace the ceramic plaques. You can order the plaques ( I would replace all of them) from Master Distributors http://www.vanguardheaters.com/ However, the number your listed is the Serial Number, not the Model Number. The Model Number is on the side of the heater or on some metal tags that are attached to it. It should say, DESA International - Vanguard and have the Model Number and Serial Number on it, along with other vital info about the heater.
Hope this helps solve your problem.
Mar 10, 2011 | Heating & Cooling
My heater is not getting hot i can not tell if their is a pilot light or a reset button i don know what to do with the heater it is very different how can i heat my water heater
Reliance makes gas and electric water heaters.
http://www.reliancewaterheaters.com/
Best way to start is to look at label on side of tank.
Label has serial number, model number, plus it will say if heater is gas or electric.
Reliance water heater age is shown in serial number: first digit is letter, second two digits are numbers: for example numbers 02 would be the year 2002.
If water heater is 8-12 years old, it might be time to consider new tank.
Gas water heater has 3 inch metal flue pipe coming out of top of tank.
Gas pilot is probably off.
Relight pilot light: Most gas water heaters today have instructions on side of tank just above gas valve that say how to relight pilot light. Instructions vary by model.
If you have gas water heater that is older, it might be easier to call a plumber.
Electric water heater has panels on front.
Open top panel and push in red reset button.
If you have electric water heater of any age, you can usually fix it yourself same day:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Dec 03, 2010 | RELIANCE ELECTRIC WATER HEATER
My heat resistant glass panel broke. I need measurements.
no you need make model serial number then look on line at national energy for the parts, the numbers make etc are on the heater
Oct 02, 2010 | Vanguard International Blue Flame - Large...
HOW MANY BTU IS A RUDD ACHIEVER 90 PLUS FURNACE MODEL RCBA-6089GG24X1?
This is the Model number of your coil which is a 5-ton. Your heater Model number will be behind the front panel of the heater.
Jan 04, 2010 | Heating & Cooling
No model number...
If this is a split system, look on the side of the furnace, no luck? remove the front panel. look for a little plate or sticker label inside there somewhere. If you are in California, there is a Goodman (A.K.A.) Janitrol, in Ontario CA. They may be able to help. (sorry don't remember phone #)
Dec 27, 2007 | Goodman GDS80904BNA Open Flame Heater
Heating & Cooling Logo
93 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
