Question about Philips 37PF5521D 37 in. HD-Ready LCD Television
Power board for 37pf5521d
Tv won't turn on, just clicks and green light flsahes
    Novelist:
  • 181 Answers
Hello!
You don't need to replace power supply in most cases. If you can to the board itself, it buried deep under metal shield, up side down, remove it from the set by unscrewing 6 machine screws, unplugging few plastic connectors. Be careful, connectors are fragile, gently move those in every direction, while pulling out male part of connectors. You will find at least 1 "bloated" electrolytic capacitor, remove and replace those. It's good have "in circuit" capacitor checker to determine quality of "hot side" of power supply capacitors. If you won't find and replace those, small: 1mf 10mf or 22mf, your set will start up, might even work fine for a while, then will quit for good! I've seen that happen! If you don't have capacitor gizmo, then replace all small electrolytic capacitors on "hot" side of power supply. "hot" is that side, what connects to main power in plug area, contents one large capacitor, I.C. chip diver, power mosfet, etc. worst case scenario: if you can't replace those parts yourself, remove the board and take to local TV repair shop. It won't cost you that much to do so, compare to complete TV repair.
Good luck,
Alex.
Posted on Feb 19, 2012
2 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: 37PF9731D/10 - when turned on the tv power light
The clicking sound is from the main power supply relay being turning on and off, it is driven by hte main board and it gets the power from the standby power supply board.
You need to check the main powwer supply board and the standby power supply board voltages.
Check the resistor in the main power supply board also
Please see my pictures here: http://s807.photobucket.com/albums/yy352/budm/Philips/Philips%2037PF9631D_37/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Jun 16, 2011
Sony bravia won't stay on 52w4100, clicks with green light three thimes then shuts off and blinks red 6 times
Sounds like a power board reset switch gone bad. Have the power board replaced.
Good Luck Ed Pinero
Feb 03, 2013 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
My emerson lc320em1f tv won't turn on.
Calm down, Calm down! Your power supply board is at fault. On the power supply, you have a bad diode. Location of this diode is D639. Replace it with an NTE 5087A. Thanks for asking, Matt of Martins TV Repair.
Jan 27, 2013 | Televison & Video
Green flashing light on receiver of pioneer elite 434pu tv won't turn on
most likely a bad power supply and boards or service info for these sets is hard to come by. Not a do it yourself fix for most people.
Apr 22, 2012 | Televison & Video
HDMI/ DVI inputs failed approx. one month after connection of Denon home theater receiver with HDMI pass-through feature "on." Gear successfully re-connected via component video...
hi welcome to fixya
i want to clarify first the problem sir so as of now the problem with your tv won't power on then you are using again the old main board is that right ? when you use the new replacement main board the tv is functioning will the only problem is that the HDMI / DVI inputs doesn't work. and now you encountered power supply problem like won't start up or something that cut the supply in which the stand by indicator is turn off so as my idea it has a problem with the old board. but before you come up with the board making sure all the connectors coming from the power supply is properly connected to the main board as will as flexible and lvds cable for the T-con board is properly inserted.just let me know if is that what you are asking for so i can give you additional solution thanks for consulting the fixya.
Aug 30, 2011 | Televison & Video
We have a 46 inch sharp tv model number 46SB54U won't turn on. The green timer light is flashing. We just replaced the power supply board thinking that was the problem. TV still won't turn on...
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will helpout ......
Jun 25, 2011 | Sharp LC46SB54U 46 in. LCD TV
37PF9731D/10 - when turned on the tv power light remains green but no picture or sound. Just a clicking sound - like it does normally when swiching on from being on standbay. It reapts the attempt to turn...
Jun 16, 2011 | Philips 37PF9731D 37 in. HD-Ready LCD...
Hi my philips flat tv won't turn on? The green
Power supply board is dead.Tries Websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
You can change the power board yourself , it very simple, but must taken to avoid high voltages in panel, please note
May 06, 2011 | Philips Televison & Video
Open Questions:
See all Philips 37PF5521D 37 in. HD-Ready LCD Television Questions
Philips 37PF5521D 37 in. HD-Ready LCD Television Logo
126 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
