Question about LG 42LC2D 42 in. LCD HDTV
My LG 42LV4400 has a red light in the bottom left corner but it will not turn on.
Model # 42LV4400-UA Serial # 109RKZH7N845 It is only 2 months old and I have had no other problems with it. We watched it before bed last night and it just won't turn on this morning.
  • Jennifer Greenwood Feb 19, 2012
    We did try that and still nothing but thank you for the response.
    Novelist:
  • 181 Answers
Hello!
2 month and already quit? OK: first thing to do is to unplug TV off the power strip or wall outlet. Wait for a few minutes and plug the set back into the power source. Try to turn on the set manually, by touching sensors or buttons on control panel. some TVs have push buttons, some touch sensors. If your TV was set to "auto power on" mode, then don't touch anything after plugging set in. That's the only action you can do to "revive" the set. If you will be able to turn set on manually and "free standing" without any external connections, except power cord, check your remote control unit. 95% of consumers turn on their sets via "clickers". In case of complete failure, you might have month or 10 month left of factory warranty, depend on price you paid. Use it a.s.a.p! If needed. There is no magic button to heal broken circuitry.
Good luck,
Alex.
Posted on Feb 19, 2012
I have a LG TV model 60LN5400-UA. I attempted to turn on my TV and the red light on the bottom blinked red but there was no picture. Your help would be greatly appreciated.
hi the tv is stuck in standby, it's a power supply fault, capacitors could cause this also a mainboard fault could cause this, thanks
shaun
Mar 30, 2017 | LG Televison & Video
My LG 42LV4400-UA wont turn on... not showing any red light how it used to be when it was working properly.
Fault with the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Jul 14, 2015 | LG 42LV4400 42 in. HDTV
OK.. it seems i'm not having a lot of luck with TV's these days.. i have a LG 60PS60-UA plasma TV that won't power on. when I do i get a red light where the white light normally is when working corre
Hi, It also could be the inverter board(s) that have gone bad. Check them out. If the inverter board goes it will also turn the TV off.
These boards are on the left and right sides of the TV pannel.
Good Luck with your repairs.
Dec 19, 2014 | LG Televison & Video
I have a LG LED TV that the stand by light is on but the TV will not power up. The TV is 13 minths old.
I looked at the previous solution but I would be more apt to say you need to look at the capacitors on the power supply. It is a very common problem, especially for a TV that is on more than it is off. Simply pull the back cover and look at the capacitors on the power supply. It will be the board in the middle. If a couple of them are domed at the top or leaking then they need to be replaced. If you have someone that can do a little soldering for you the repair could be as cheap as $5.
Apr 08, 2013 | LG Televison & Video
Code for LG model 32LH250H-UA
Setup codes to check with LG brand TVs are: 0004 0050 0009 0005 0227 0338 0012 0057 0080 0156 Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1100 posts to different brand TVs now. Pull up older posts there.
Nov 02, 2012 | Brightstar UNIVERSAL TV REMOTE - FOR...
My lg mod# 42LV4400-UA tv will not turn on
LG had a serious quality problem with the main board and there is a bad solder joint on all original 42lv4400 and 47lv4400 units.It will manifest the problem either went it gets warmed up and then power down itself or never power up. The red light stays on and the TV does not respond to manual or Remote input.
A factory reset will not fix this problem. It takes a "NEW" main board. The big white label on the back panel has the original manufacture date and LG will send out a factory authorized technician to repair the unit within the first year after that manufacture date.call 800 243 0000 to schedule a home visit to get the repair done.
By the Way, a 42lv4400 main board will not work in a 47lv440 even though they look identical. The reverse is also true.
Jun 05, 2012 | LG 42LV4400 42-inch LED TV
My LG 42LV4400 led tv won't turn on. Even the
Someone must open it and check voltages on the power supply board as the first step.
Depending on what is found boards may have to be ordered and installed to KNOW which will fix or not fix the set.
Mar 14, 2012 | LG Televison & Video
LG 42LC2D 42 in. LCD HDTV Logo
1,099 people viewed this question
Computer Repairing
Computer Repairing
