Question about Olympus Stylus 710 Digital Camera
Flap that closes memory card broken
Are there any replacements parts for the flap, also the cord for the charger is lost. Please let me know what kind of cords are compatible. Thank you.
  • Anonymous Nov 29, 2008
    I have exactly the same problems with the camera. I dropped it and the flap broke, also I can not find the cord for charger! Please help!
  • 928 Answers
To be sure that you get the right parts you can go to the link below then go to the Store. This is the official parts store of Olympus
http://www.olympusamerica.com/cpg_section/cpg_servicerepair.asp
Posted on Oct 26, 2008
Charging port doesnt work
If your laptop charger seems broken, it's most likely because the battery will not charge. You plug in the cord, the lights come on, but the charging light doesn't change or blinks repeatedly. When you remove the power cord, the laptop shuts off instantly due to the depleted battery. There's more than one cause for this, and it's not always a broken charger.
Check the connection between the charger and the laptop. It should fit firmly in the DC jack without wiggling. If it is loose, use electrical tape to hold it in place so the charger can receive power. This is a temporary fix, however, because a faulty connection can create sparks and cause a fire or injury. A loose connection will just get worse over time, so have it sent to a DC jack specialist as soon as possible. Turn off the laptop and flip it upside down. Locate the latch that secures the battery and slide open. The battery should pop out; give it a tug if it doesn't. Apply a small amount of rubbing alcohol (Methylated Spirits)to the tip of a cotton swab and use it to clean the battery's connectors. Dirt can build up and interfere with the connection, giving the appearance of a broken charger. Let the alcohol dry completely and re-insert the battery. Slide the latch to secure it and plug in the power cord to test it. See if the laptop powers on with the charger only and battery removed. If it does, the battery is the likely culprit and should be replaced. If the charger is truly broken, the only thing to do is to replace it or the power cord attached to it. Look on the bottom and write down the part number. Call the laptop manufacturer for a replacement charger or search for the part number on eBay. If you purchase from anyone other than the original manufacturer, ask for genuine parts to reduce the possibility of problems. Troubleshoot Mag Safe adaptors
http://support.apple.com/kb/ts1713
Feb 09, 2013 | Samsung " 17.3"" Laptop - 4GB Memory -...
It is not accepting memory cards,instead it pushes it outwards.
Most probably your memory card slot is broken and spring inside is damaged so it pushes up so better change your memory card slot..!
Please let me know if you need any further assistance.
Kind regards
Roy
Dec 28, 2010 | Sony Ericsson W700i Cellular Phone
How to use a memory stick right from the start
hi
  • Understand how a Memory Stick Pro works. The small card saves information from a portable device. You can save, delete and rewrite to the card as many times as you want. You can also remove the card and insert it into another device. For example, you can save photos from a camera, then insert the memory card into your laptop to view or download the images.
  • Step 2 Make sure you buy a memory card that matches the demands of your electronic device. The cards have different saving speeds and data-holding capacities. Generally speaking, the more data the card can hold and the faster its speed, the more expensive the memory card. Check your electronic device's product information for recommendations on the best type and size of memory card.
  • Step 3 Insert the Memory Stick Pro into the electronic device. Most devices have a small flap or cover on its side that holds the card. The memory card slides into a slot under the flap. Gently push in the card and close the flap.
  • Step 4 Save to the memory card. Once the card is installed, many devices know to save new data to the card. In some cases, however, you may need to specify where to save files, either to a built-in hard drive or to the memory card.
  • Step 5 To remove the card, open the flap and gently press the card in. The card should then pop out of the slot for easy removal. The card can now be inserted into another device.
  • vote me if your setisfied
    Jun 29, 2010 | SanDisk 2GB Memory Stick Micro M2 Memory...
    How do I repair a toshiba m305 that has a flicker at the bottom of the screen
    Unplug AC Charger. Kindly check the bottom part of the display if it still flickering while the ac adapter is unplugged. If system stops flickering issue was due to unstable charger, you may need to reseat the power cord or maybe replace the ac adapter itself.
    On the other hand if display still flickers after you disconnect the charger kindly reinstall the display
    driver. Since I don't have any idea what operating system youre using right now, I put all the link for all the available os for the graphic card driver.
    For windows 7 (both 32 and 64 bit) Click here
    For Win vista os with Intel Graphic card Click here.
    For Win vista os with ATI Graphic card Click here.
    For Win XP os with Intel Graphic card Click here.
    Make sure to restart the computer after the installation. If same problem occured, please contact the computer manufacturer to have the video card replaced.
    Should you have any other questions please leave a comment.
    Cheers~
    Jun 21, 2010 | Toshiba Satellite M305-S4826 Laptop
    Sd card is detected but cant open
    I find that the easiest place to find files on a HDD or SD card that i connect but the drive comes up is by going right click on computer and going to the manage option.
    I then go down to disk management and look for the storage that I have added.
    Then right click on "change drive letter and path" and add give the storage a drive letter
    For some reason the computer sometimes does not complete this part which leaves the drive unreadable
    It is always a good thing to do to go to device drivers to check that you can see the drivers for the device being installed. This can be achieved by removing and replacing the storage device while device manager is open
    May 26, 2010 | SanDisk 2GB microSD Memory Card
    Plastic ice shoot is broken. How do I remove the old one?
    The ice shoot just snapps of of the arm . Pt # 2180224 . Once off , you will see how to snap back on . Usually an ice guide ( ice shoot ) will not allow the flap to close if shoot is broken .
    Jul 19, 2009 | Whirlpool 19.6 cu. ft. Upright Freezer...
    Dont Know Where??
    Most LG phones have a spot for the memory card behind the battery. Remove the battery and you will see where the memory card slides in.
    Jul 14, 2009 | Leviton Combo Switch Neon Lght - 5226-I -...
    Lost the slide/flap that holds the battery and memory card in
    I have a used one from a camera I serviced. Google my username... ;)
    Jan 15, 2008 | Casio EXILIM EX-Z1000 Digital Camera
    Olympus Stylus 710 Digital Camera Logo
    23 people viewed this question
    Top Olympus Cameras Experts
    Willem.
    Willem.
    Steven Wander
    Steven Wander
    Are you an Olympus Camera Expert? Answer questions, earn points and help others
